2017-05-19 - Kernels, LibreOffice, Mesa, Thunderbird, Cinnamon (Stable Update)
Themen Author - Moderator
- Kernel: 6.12
- Hat sich bedankt: 32 Mal
Hi community,
we are happy to present Cinnamon v3.46 to our distribution. It comes with new features, a ton of fixes and refinements. Also a brand new spices website7 was created to get applets and desklets easy to install. We also updated most of our kernels and pushed out the latest LibreOffice and Thunderbird. We have also the lastest KDE-Framework and Mesa-Stack added to this update-pack.
Please give us feedback as usual and report any issues you may see with this update.
Current supported Kernels
linux310 3.10.105
linux312 3.12.74 [EOL]
linux316 3.16.42
linux318 3.18.53 [EOL]
linux41 4.1.39
linux44 4.4.68
linux48 4.8.17 [EOL]
linux49 4.9.28
linux410 4.10.16
linux411 4.11.1
linux-RT-LTS 4.4.66_rt79 (x86_64)
linux-RT 4.9.27_rt18 (x86_64)
Package Updates (Fri May 19 06:07:01 CEST 2017)
stable community i686: 269 new and 244 removed package(s)
stable community x86_64: 287 new and 261 removed package(s)
stable core i686: 22 new and 22 removed package(s)
stable core x86_64: 22 new and 22 removed package(s)
stable extra i686: 360 new and 353 removed package(s)
stable extra x86_64: 360 new and 353 removed package(s)
stable multilib x86_64: 6 new and 2 removed package(s)
A detailed list of package changes can be found here.
Quelle
linux310 3.10.105
linux316 3.16.42
linux41 4.1.39
linux44 4.4.68
linux49 4.9.28
linux410 4.10.16
linux411 4.11.1
Quelle
- Kernel: 6.12
Re: 2017-05-19 - Kernels, LibreOffice, Mesa, Thunderbird, Cinnamon (Stable Update)
Die Gnome Einstellungen waren etwas verstellt (Dock, Icongröße und die obere Leiste).
Aber sonst ist alles gut.
System:  Host: dirk-pc Kernel: 4.11.1-1-MANJARO x86_64 (64 bit)
     Desktop: Gnome 3.24.2 Distro: Manjaro Linux
- Kernel: 5.15 / 6.0
- GPU Treiber: Intel i915
- Hat sich bedankt: 15 Mal
- Danksagung erhalten: 36 Mal
Alles problemlos erledigt. Lightning natürlich wieder englisch. Abhilfe, entfernen und wieder von der Add-on-Seite neu installieren.
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft!
- Erfahrenes Foren Mitglied
alles gut und ratz fatz erledigt. Immer im tty, einfach besser.
- Kernel: 510
- Hat sich bedankt: 51 Mal
- Danksagung erhalten: 12 Mal
Auf allen meinen Manjaros ohne Probleme durchgelaufen. Super Sache. Vielen Dank an alle, die Manjaro fit halten!
[quote="dphn"]
Nur um Mißverständnissen vorzubeugen; Du bevorzugst die virtuelle Konsole tty dem XFCE-Terminal- warum?
- Kernel: 5.XX
- GPU Treiber: NVIDIA 495.XXX
- Hat sich bedankt: 1 Mal
Hallöchen
Auch bei uns auf 2 Rechnern mit KDE, ohne Probleme montiert.
Manjaro wird auch mit Plasma 5 immer zuverlässiger. Läuft bei uns inzwischen wieder als Hauptsystem. War ja nach der Umstellung von KDE 4 auf Plasma 5 nicht immer zu empfehlen.
Gruß Olli
- CPU: Intel Core i5-6200U
- Hat sich bedankt: 5 Mal
- Danksagung erhalten: 1 Mal
Im englischsprachigen Forum sind verschiedene Probleme aufgetaucht, während hier alles glatt zu laufen scheint. Oder gibt es hier auch Erfahrungen mit folgenden Problemen:
Hi, since the latest Update the Hardware Keys for Brightness are not working any more. This Problem I saw on 4 different Notebooktypes. Any Solution?
Since this update Octopi no longer detects/shows AUR packages needing update.
Oddly enough Octopi Notifier warns there are AUR updates available.
After the update Steam no longer works with firejail due to this bug.
Otherwise a smooth update.
After this update, notifications stopped working in xfce for me. No matter what theme I use, they pop up as text only in the upper-left corner of the screen
Octopi does not detect AUR package updates, Also KDE takes a bit longer to load.
VMware Workstation don't work by a segfault error.
Hier der Link zum englischsprachigen Forum: https://forum.manjaro.org/t/stable-upda ... n/24059/69
Octopi zeigt keine Updates mehr aus dem AUR. Der Octopi Notifier blinkt aber und sagt, dass 9 Aktualisierungen verfügbar sind.
Ich habe das mal hier versucht zu melden: https://bugs.manjaro.org/index.php?do=d ... ask_id=199
Zuletzt geändert von Peter am Freitag 26. Mai 2017, 11:26, insgesamt 1-mal geändert.
- Neues Foren Mitglied
geht mir seit tagen genauso. lösung hab ich allerdings keine. selbst yaourt im terminal macht nichts, wirft nur folgendes raus:
curl error: Problem with the SSL CA cert (path? access rights?)
[quote="Peter"]
[quote="Peter"]
Eine Software [tt]Exodus[/tt] aus dem AUR hab ich in octopi im AUR gesucht und da wurde mir auch angezeigt, dass das Paket veraltet ist und ich konnte die neue Version installieren.
