2016-08-30 - NetworkManager, Haskell, Plasma 5.7.4 (Unstable Update)
Hi community,
Since we managed to put out our second final review of Manjaro Ellada, we are already working on our next release we codenamed Fringilla. With this update we try to fix the known networkmanager issues, updated Plasma to 5.7.4, added some Haskell packages and updated all our settings for Manjaro-tools 0.13.5.
Archlinux upstream fixes are now from: Thu Aug 30 21:28 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Additional it would be good to test one of our preview install medias to check these changes on a fresh install.
Kind regards,
Troubleshoots
Issues with updating MATE
LibreOffice and GTK3
GTK3
ufw
steam
Reference: Archlinux wiki
Current supported kernels
Linux310 3.10.102
Linux312 3.12.62
Linux314 3.14.77
Linux316 3.16.37
Linux318 3.18.40
Linux41 4.1.31
Linux44 4.4.19
Linux46 4.6.7 [EOL]
Linux47 4.7.2
Linux-RT-LTS 4.4.17_rt25
Linux-RT 4.6.7_rt11
Quelle
