[Stable Update] 2024-05-13 - Kernels, Plasma 6, Gnome 46, LxQT 2.0, Nvidia, Pacman
Nein, hatte keine Probleme mit dem Update
4
36%
1
9%
6
55%
Insgesamt abgegebene Stimmen: 11
Notable Package Updates
Kernel updates
including linux-firmware updates
Core packages
Mkinitcpio 38.1
Systemd is at 255.5
Desktop updates
:gnome: GNOME 46.1 12
Plasma 6 6.0.4 40
KDE Gear got refreshed to 24.02.2 2
KDE Frameworks at 6.1.0 6
LxQt 2.0.0 6 gained Qt6 support
Office Updates
LibreOffice got renewed to 24.2.3 and 7.6.6 2
Firefox 125.0.3 1
Thunderbird got renewed to 115.10.2 1
Graphic related
NVIDIA driver renewed to 550.78 21
Mesa updated to 24.0.6 3
Xorg Server updated to 21.1.13 2
Gaming related
inputplumber 0.21.2
hhd 2.6.4 1
hhd-ui 2.2.3 1
adjustor 2.1.5 1
HandyGCCS supports now GDF-G2102_F03D_V1.0_240314b MCU firmware
gamescope plus got renewed to 3.13.16.9.plus1 2
steam-deckify defaults now to Wayland also on the Plasma 6 session
Package Management related
pacman got updated to 6.1.0 1, which includes dropped SyncFirst option
all packages got updated, including libpamac. However there seems to be an issue 11 which may freeze the UI of Pamac
libpamac gained support to use libalpm internal download engine 1 for downloading files
OS Installer
Calamares 3.3.6 2
Virtualization
VirtualBox is now at 7.0.18
Wine is updated to 9.8
New major release of QEMU 9.0.0 4
Misc
We dropped various packages related to unmaintained community editions; i.e, Awesome, Bspwm, Budgie, Deepin, MATE, Openbox, etc.)
various Python and Haskell package updates and fixes
Python 3.12 6 rebuilds
Kodi updated to 21.0 2
A list of all package changes can be found here 9
Additional Info
Python 3.12 info
Info about AUR packages
Get our latest daily developer images now from Github: Plasma 5, GNOME 1, XFCE. You can get the latest stable releases 12 of Manjaro from CDN77 5.
Our current supported kernels
linux419 4.19.313
linux54 5.4.275
linux510 5.10.216
linux515 5.15.158
linux61 6.1.90
linux66 6.6.30
linux68 6.8.9
linux69 6.9.0-rc7
linux61-rt 6.1.83_rt28
linux66-rt 6.6.23_rt28
linux67-rt 6.7_rt6
Package Changes (Tue May 7 14:51:30 CEST 2024)
testing core x86_64: 22 new and 23 removed package(s)
testing multilib x86_64: 28 new and 28 removed package(s)
testing extra x86_64: 1070 new and 1058 removed package(s)
Overlay Package Changes
testing core x86_64: 26 new and 35 removed package(s)
testing extra x86_64: 123 new and 129 removed package(s)
Mehr dazu und Quelle unter folgendem Link:
https://forum.manjaro.org/t/stable-upda ... -updates-3
charly700
CPU: Intel Core i5-10400
Hat sich bedankt: 116 Mal
Danksagung erhalten: 37 Mal
Re: [Stable Update] 2024-05-13 - Kernels, Plasma 6, Gnome 46, LxQT 2.0, Nvidia, Pacman
Beitrag von charly700 »
Habe bei meinem Vater das Update erledigt. Lief so weit ohne Probleme durch. Aber es wurde Python auch aktualisiert und danach habe ich Puddletag neu installiert. Leider lässt es sich nicht mehr starten. Kann jetzt nicht sagen, ob noch andere Pythonprogramme davon betroffen sind.
Warum ist es so schwer, Pythonprogramme am Laufen zu halten? Habe natürlich alles so gemacht, wie es auf der Seite im Manjaroforum angegeben wurde. Die Pythonpakete wurden neu erstellt. Aber wie oben schon erwähnt, lässt sich Puddletag danach nicht mehr starten.
jacl
GPU: Mesa Intel® UHD Graphics
Kernel: ...always the newest
Desktop-Variante: KDE-Plasma
Hat sich bedankt: 4 Mal
Danksagung erhalten: 15 Mal
Beitrag von jacl »
Bei mir hat sich nach dem Update khotkeys 5.27.11-1 und systemd-kcm 1.2.1-8 zu Fremdpaketen verschoben. Kann ich diese beiden Pakete ohne bedenken löschen?
Ich habe die Befürchtung, dass nach dem Löschen Probleme auftreten. Was kann ich tun um diese Pakete (Programme) dort weg bekomme?
Zum besseren Verständnis siehe Screenshot.
Zuletzt geändert von jacl am Dienstag 14. Mai 2024, 07:10, insgesamt 1-mal geändert.
jacl
Beitrag von jacl »
Hat sich erledigt. Konnte beide Pakete ohne anschließenden Schwierigkeiten löschen.
Sind Relikte (KDE 5 oder so), daher keine Probleme...
regards Jacl 👍
ManTuxer
CPU: Intel Core i7-9750H
Hat sich bedankt: 46 Mal
Danksagung erhalten: 75 Mal
Beitrag von ManTuxer »
charly700 hat geschrieben: Montag 13. Mai 2024, 17:42 ...und danach habe ich Puddletag neu installiert. Leider lässt es sich nicht mehr starten...
Installiere dir puddletag-git! Das funktioniert.
Danksagung erhalten: 343 Mal
Das heutige "kleine" Update hat bei mir den Epic Game Launcher (Luitris) abstürzen lassen.
Irgendein Fehler mit der Unreal Engine.
Nach einem Neustart funktionierte Epic wieder, musste mich jedoch neu anmelden.
Bis jetzt keine weiteren Probleme.
charly700
ManTuxer hat geschrieben: Dienstag 14. Mai 2024, 08:21
Danke. Wen ich bei meinem Vater bin, werde ich es testen bzw. falls ich das Update heute bei mir noch mache, dann bei mir.
charly700
Edit: Die GIT Version funktioniert bei mir jetzt zwar, aber es ist ein helles Theme, obwohl es bei mir dunkel sein sollte.
Edit2: Das muss ein anderes Problem sein. Es gibt mehrere Programme, die hell anstatt dunkel sind. Unter anderem auch VirtualBox.
ManTuxer
Hallo @charly700
Das stellst du in den Qt5-Einstellungen ein. Was hast du dort ausgewählt? Da immer mehr Programme auf QT6 umstellen, kannst du auch diese Einstellungen so übernehmen.
Bei mir sieht es so aus wie auf auf dem angehängten Bild und damit werden alle Qt-Anwendungen auch dunkel dargestellt.
charly700
Danke, hat geklappt. Frage mich nur, warum vorher schon mal korrekte Einstellungen nach einem Update so verändert werden, dass es einfach nicht mehr passt.
Turoy
CPU: AMD Ryzen 7 5700G
GPU: AMD Ryzen 7 5700G
Hat sich bedankt: 120 Mal
Danksagung erhalten: 6 Mal
Beitrag von Turoy »
Hmh,
und bei Krusader gibt's auch SCHON WIEDER Probleme mit dem Update. So wie viele andere Fehler mehr. In nem anderen Thread habe ich gefragt welche Laien da bei Manjaro immer diese fehlerhaften Updates machen ??
Bei einem 2. Update Versuch hat dich gerade "electron24" in einer Endlos-Schleife aufgehängt.
Eigentlich bin ich von Ubuntu zu Krusader gewechselt wegen den vielen Schwierigkeiten, die bei JEDEM Distributionswechsel immer auftreten, und weil Manjaro auch für solche Programme Updates macht, die vom Nutzer erst zusätzlich installiert wurden.
Aber bei den aktuell ANDAUERND auftretenden Fehlern bei Manjaro ist es vielleicht doch bei Ubuntu besser. Lieber funktionierende Alt-Versionen von Programmen, als Updates die andauernd zu Fehler führen. Wählt man bei Ubuntu die LTS Version, so hat wenigstens nur alle paar Jahre Probleme ansatt bei jedem kleineren Update ...
Gruß Turoy
charly700
Du regst dich auf, wen du Krusader (ein Dateimanager für KDE bzw. Plasma) nutze, aber mit XFCE.
Das kann ich nicht verstehen. Wenn ich mich für eine DE entscheide, dann nehme ich auch die grundlegenden Programme, die mit dieser daherkommen.
Wenn man die zu Vermischen anfängt, dann kommen halt oft solche ungewollten Probleme dabei raus.
Ist aber nur meine Meinung dazu.
MichaelP
CPU: AMD Ryzen 9 5900X
GPU: NVIDIA GTX 3080 Ti
Kernel: 6.7.0
Desktop-Variante: KDE 5.27.10
GPU Treiber: NVIDIA 545.29.06
Hat sich bedankt: 17 Mal
Danksagung erhalten: 28 Mal
Beitrag von MichaelP »
bin auch irgendwann von UBUNTU zu Manjaro gewechselt, das wäre aber ein unfairer Vergleich....
Besser paßt EndeavourOS, ist ja auch ein Rolling-Arch-Derivat. Der ganze Wechsel von KDE 5.x zu 6 in EOS ging bei mir geräuschlos schon mit 6.02 - warum ::) ? K.A.! Wobei "Rolling" bei Manjaro immer mehr "Stolpering" wird... und die Developer immer frecher...oder verzweifelter?
O-Ton als DEV-Antwort zum 6er KDE-Update - ein User wolle sich keine weitere Neu-Installation antun: "If you go, close the door silent". :o
Naja, das sollte der User befolgen, alles andere verursacht ggf. Development-Schlafstörungen o.ä. >:D
Ich hatte diesmal "fast" Glück, nur ein Blackscreen ^-^ (Kernel 6.7 - NVIDIA). Timeshift, zurück auf 6.6, 6.7 gelöscht, dann lief das Update durch.
Ein paar Programme starteten nicht, bei den meisten half ein Reinstall (nicht nur AUR-Progs!).
Im Moment verweigern noch hartnäckig Spectacle und OBS-Studio den Start, vielleicht hat einer von Euch noch einen Tipp hierfür :D ?
Ansonsten - gelassen bleiben, abwarten... oder leise die Tür schließen ^-^
Gruß Michael
HALx
CPU: i7Ultra-155H
GPU: Intel Arc
Kernel: 6.8
Beitrag von HALx »
Der allerschönste Bug bisher. Nach dem Wechsel auf Plasma6 und den Kernel 6.9 wird bei meinen MeteorLake Systemen ein CPU-Kern geklaut der hat dann nur noch 21 das ist wieder ein kurioser Bug und die alte Regel für mich niemals einen frischen Release X.0 Kernel zu nutzen wird bestätigt. Aktuelle Systeme sind bei Linux auch nicht immer von Vorteil. Das hat direkt mit Plasma6 wohl nichts zu tun denn bei Kernel 6.8 sind Sie alle wieder da. Für mich schon einmal der schönste Bug des Jahres wird schwer zu toppen sein. Bei Intels MeteorLake ist vom Kernel her noch viel Luft nach oben.
Kernel 6.9 dmesg Ausgabe:
CPU topo: Boot CPU APIC ID not the first enumerated APIC ID: 20 > 10
CPU topo: Crash kernel detected. Disabling real BSP to prevent machine INIT
ACPI: X2APIC_NMI (uid[0xffffffff] high level lint[0x1])
IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: Using ACPI (MADT) for SMP configuration information
ACPI: HPET id: 0x8086a201 base: 0xfed00000
e820: update [mem 0x5c906000-0x5c940fff] usable ==> reserved
TSC deadline timer available
CPU topo: Max. logical packages: 1
CPU topo: Max. logical dies: 1
CPU topo: Max. dies per package: 1
CPU topo: Max. threads per core: 2
CPU topo: Num. cores per package: 16
CPU topo: Num. threads per package: 21
CPU topo: Allowing 21 present CPUs plus 0 hotplug CPUs
CPU topo: Rejected CPUs 1
Fangi
CPU: Ryzen 2700
GPU: Radeon RX-580
Kernel: 5.15, 6.1, 6.6, 6.12.17-1 LTS
Desktop-Variante: X-Cinnamon
GPU Treiber: Mesa 24.3.4-arch 1.1 radv
Hat sich bedankt: 21 Mal
Danksagung erhalten: 4 Mal
Beitrag von Fangi »
Turoy hat geschrieben: Mittwoch 15. Mai 2024, 15:55 Hmh,
Bei mir lief das bisher größte Update (6,3GB) erst einmal fehlerfrei durch. Danach hatte ich allerdings Probleme mit Electron 25, dass dann ewig weiter lief (es wurde eine bestimmtes Repo kopiert und wurde und wurde nicht fertig) ich habe das dann einfach über Nacht weiter laufen lassen. Ich habe zur Zeit ein festes Datenkontingent von 250GB monatlich, das war dann Morgens aufgebraucht. Nach dem ich dann Morgens noch zweimal 25GB nachgebucht habe und es immer noch nicht fertig war, habe ich nachgesehen, was ich an Electron-Versionen auf dem System habe. Da auf meinem System dann mittlerweile auch Electron 26 vorhanden war, habe ich Electron 25 gelöscht und damit mein Problem gelöst. Das hat mich 50,-€ Lehrgeld gekostet und den größten Teil meines Datenkontingents... ;)
AUR ist halt einfach mit Vorsicht zu genießen. Manjaro ist für mich immer noch die absolut allererste Wahl, ich liebe es :)
