Probleme bei der Monitorumschaltung Thema ist als GELÖST markiert
Die_Kralle
CPU: Intel Core i7-4700HQ
Kernel: 6.6.5-1-MANJARO
Desktop-Variante: XFCE 4.18
Hat sich bedankt: 34 Mal
Beitrag von Die_Kralle »
inxi -Fz
  Kernel: 6.5.0-1-MANJARO arch: x86_64 bits: 64 Desktop: Xfce v: 4.18.1
    Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: G750JS v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: G750JS v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: G750JS.208 date: 07/17/2014
Battery:
  ID-1: BAT0 charge: 48.4 Wh (98.6%) condition: 49.1/77.0 Wh (63.8%)
    volts: 14.8 min: 14.8
CPU:
  Info: quad core model: Intel Core i7-4700HQ bits: 64 type: MT MCP cache:
    L2: 1024 KiB
  Speed (MHz): avg: 871 min/max: 800/3400 cores: 1: 1200 2: 800 3: 970
    4: 800 5: 800 6: 800 7: 800 8: 800
    v: kernel
  Device-2: NVIDIA GK104M [GeForce GTX 870M] driver: N/A
  Device-3: Chicony USB2.0 HD UVC WebCam driver: uvcvideo type: USB
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0 driver: X:
    loaded: intel unloaded: nvidia dri: i965 gpu: i915 resolution: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.1.6-2 renderer: Mesa Intel HD Graphics 4600
    (HSW GT2)
Audio:
    driver: snd_hda_intel
  API: ALSA v: k6.5.0-1-MANJARO status: kernel-api
Network:
  Device-1: Broadcom BCM4352 802.11ac Wireless Network Adapter driver: N/A
  Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet driver: alx
Bluetooth:
  Device-1: IMC Networks BCM20702A0 driver: btusb type: USB
Drives:
  Local Storage: total: 1.6 TiB used: 909.06 GiB (55.6%)
  ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541515A9E630
  ID-2: /dev/sdb vendor: SanDisk model: SD5SE2256G1002E size: 238.47 GiB
Partition:
  ID-1: / size: 233.38 GiB used: 123.3 GiB (52.8%) fs: ext4 dev: /dev/sdb2
  ID-2: /boot/efi size: 299.4 MiB used: 300 KiB (0.1%) fs: vfat
    dev: /dev/sdb1
Swap:
Sensors:
  System Temperatures: cpu: 55.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2500
Info:
  Processes: 276 Uptime: 1m Memory: total: 32 GiB note: est.
  available: 30.8 GiB used: 3.16 GiB (10.3%) Shell: Bash inxi: 3.3.29
wenn ich mittels
xfce4-display-settings --minimal
zwischen Zwei-Monitor-Betrieb und nur Notebook-Betrieb umschalte, dann ist mein Desktop komplett leer und reagiert auf nichts mehr. Es hilft nur ein gewaltsames Abschalten und Wiedereinschalten des Notebooks. Jahrelang war das kein Problem. Es scheint durch irgendein Update oder eine App zu diesem Problem zu kommen. Wie kann ich die Ursache finden?
Gruß Heiko
Zuletzt geändert von Die_Kralle am Samstag 7. Oktober 2023, 12:11, insgesamt 2-mal geändert.
Die_Kralle
Re: Probleme bei der Monitorumschaltung
Wieder einmal ein Problem das nur ich habe?
Gruß Heiko
Zeig mal:
echo $XDG_SESSION_TYPE
Sollte dort wayland stehen und nicht x11, probiere das mal aus:
viewtopic.php?t=4394&hilit=wayland&start=15#p32398
Laut deiner inxi Ausgabe
ist deine Grafikkarte nicht installiert der Treiber nvidia ist nicht geladen.
Damit nicht alles mehrfach überlegt wird, -> dieses X-Post:
https://forum.manjaro.org/t/probleme-be ... ung/148869
Die_Kralle
danke für die Tipps, aber Manjaro-XFCE lies sich nicht mehr zu einer Zusammenarbeit überreden.
Habe ich am Login-Schirm auf "Wayland" gewechselt, erhielt ich noch Zugriff zum System.
Ich entschied mich für eine Neuinstallation und ärgere mich jetzt mir abbrechenden Build-Modi herum.
Gruß Heiko
Die_Kralle
LaGGGer hat geschrieben: ↑Montag 2. Oktober 2023, 10:06 Sollte dort wayland stehen und nicht x11, probiere das mal aus:
Bei mir steht da X11.
Gruß Heiko
Die_Kralle
country hat geschrieben: ↑Montag 2. Oktober 2023, 23:34 Laut deiner inxi Ausgabe
Nach diesem Bild, ist da doch ein Treiber installiert?
Gruß Heiko
Die_Kralle
ich habe das Thema wieder aufgemacht und Eure Fragen beantwortet.
Am Login, habe ich jetzt auch Wayland mehr zur Auswahl.
Aber trotz Neuinstallation, ist das Problem noch immer das gleiche.
Ich habe Links einen externen HDMI-Monitor stehen und wenn ich mittel CRTL+ALT+P vom erweiterten Bildschirm zurück auf "Nur Notebook" wechsel, dann habe ich nur den Desktop-Hintergrund und mehr nicht.
Wenn man die Tastenkombi dann weiter nutzt, wird das immer schlimmer.
Arbeitsflächen habe ich nur eine.
Das ist echt nervig.
Gruß Heiko
Da du jetzt neu installiert hast, würde ich gerne nochmal deine Inxi Ausgabe sehen.
Und:
mhwd -l
Wieso ist bei dir immer noch Wayland installiert? Passiert das automatisch? Ich habe das nicht zur Auswahl.
Und sollte man nicht den NVidia Optimus Treiber bei Hybrid GraKa nutzen? Bumblebee ist doch veraltet, wenn ich mich recht erinnere.
Hier wurde dir das schonmal mitgeteilt. Bist du dem Link gefolgt der dort gepostet wurde und dich damit beschäftigt?:
https://forum.manjaro.org/t/erledigt-pr ... g/148869/7
Ausseredem steht da auch:
Ich würde versuchen bumblebee loszuwerden.
und an anderer Stelle::
Xfce hat (noch) keinen wayland support.
Der NVidia Treiber 3.90 ist veraltet, laut dieser Seite ist zumindest der 4.19 kompatibel:
https://linux-hardware.org/?id=pci:10de-119f-1043-21bb
Mit diesem Befehl wird automatisch der richtige Treiber für dein System installiert:
sudo mhwd -a pci nonfree 0300
Sollte der beste/richtige Treiber schon installiert sein, bricht die Installation automatisch ab.
Die_Kralle
 inxi -Fz
  Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 Desktop: Xfce v: 4.18.1
    BIOS: American Megatrends v: G750JS.208 date: 07/17/2014
Battery:
  ID-1: BAT0 charge: 49.1 Wh (100.0%) condition: 49.1/77.0 Wh (63.8%)
CPU:
    L2: 1024 KiB
  Speed (MHz): avg: 1582 min/max: 800/3400 cores: 1: 800 2: 800 3: 3400
    4: 1267 5: 2396 6: 800 7: 2395 8: 800
    v: kernel
  Display: x11 server: X.org v: 1.21.1.8 driver: X: loaded: intel dri: i965
    gpu: i915 resolution: <missing: xdpyinfo/xrandr> resolution: 1920x1080
  API: EGL v: 1.5 drivers: crocus,swrast platforms: x11,surfaceless,device
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.8-manjaro1.1
    renderer: Mesa Intel HD Graphics 4600 (HSW GT2)
Audio:
  API: ALSA v: k6.5.5-1-MANJARO status: kernel-api
Network:
  Device-1: Broadcom BCM4352 802.11ac Wireless Network Adapter driver: wl
  IF: wlp3s0 state: dormant mac: <filter>
Bluetooth:
  Report: btmgmt ID: hci0 state: up address: <filter> bt-v: 4.0
Drives:
  Local Storage: total: 1.6 TiB used: 801.85 GiB (49.0%)
Partition:
  ID-1: / size: 233.67 GiB used: 23.57 GiB (10.1%) fs: ext4 dev: /dev/sdb1
Swap:
Sensors:
  System Temperatures: cpu: 54.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2200
Info:
  Processes: 244 Uptime: 7h 32m Memory: total: 32 GiB available: 31.23 GiB
  used: 2.68 GiB (8.6%) Shell: Bash inxi: 3.3.30
mhwd -l
> 0000:03:00.0 (0200:14e4:43b1) Network controller Broadcom:
                  NAME               VERSION          FREEDRIVER           TYPE
   network-broadcom-wl            2018.10.07               false            PCI
> 0000:01:00.0 (0302:10de:1199) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-390xx-bumblebee            2023.03.23               false            PCI
    video-nvidia-390xx            2023.03.23               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:00:02.0 (0300:8086:0416) Display controller Intel Corporation:
     video-modesetting            2020.01.13                true            PCI
            video-vesa            2017.03.12                true            PCI
Hier erstmal die beiden Ergebnisse.
Ob bei der aktuellen Installation auch wieder "Wayland" mit installiert wurde, überprüfe ich gleich.
Gruß Heiko
Die_Kralle
LaGGGer hat geschrieben: ↑Samstag 7. Oktober 2023, 14:26 Wieso ist bei dir immer noch Wayland installiert? Passiert das automatisch? Ich habe das nicht zur Auswahl.
Bei dieser Installation habe ich auch nur "Xfce-Sitzung" und "Kodi" zur Auswahl.
LaGGGer hat geschrieben: ↑Samstag 7. Oktober 2023, 14:26 Und sollte man nicht den NVidia Optimus Treiber bei Hybrid GraKa nutzen? Bumblebee ist doch veraltet, wenn ich mich recht erinnere.
Ich habe einfach die geführte Installation von Manjaro durchlaufen lassen und da wurden diese Treiber automatisch installiert.
Und ich habe geantwortet, das nach dem Versuch den Treiber zu deinstallieren, Manjaro nicht mehr nutzbar war.
LaGGGer hat geschrieben: ↑Samstag 7. Oktober 2023, 14:26 Mit diesem Befehl wird automatisch der richtige Treiber für dein System installiert:
Ergebnis:
Skipping already installed config 'video-hybrid-intel-nvidia-390xx-bumblebee' for device: 0000:00:02.0 (0300:8086:0416) Display controller Intel Corporation 4th Gen Core Processor Integrated Graphics Controller
Danach ist der beste Treiber schon installiert.
Ich habe fast den Eindruck, das der Desktop beim Umschalten immer weiter nach rechts verschoben wird.
Ausgangssituation:
Links externer HDMI-Monitor und rechts Notebook-Display.
Maus ist auf dem Notebook-Display. Ich drücke STRG+ALT+P.
Und wähle "Nur Notebook". Der externe Monitor wird schwarz und das Fenster für die Monitorumschaltung wird ganz an den rechten Rand des Notebook-Display verschoben, so das man es nur noch über das entsprechende Leistensymbol schließen kann. Mit der Maus kann ich nicht über den rechten Bildschirmrand hinaus fahren.
Alles sehr merkwürdig. Leider braucht XFCE noch bis 2024 bis es Wayland kann.
Bei den vielen möglichen Konfigurationen von PC, Grafikkarte und externer Monitor die weltweit möglich sind, habe ich wohl eine Kombi die das System nicht mag.
Gruß Heiko
Hab alles überflogen.
Versuch mal nach dem der Monitor schwarz bleibt mit der Tastenkombination
CTRL+Alt+F2 dann gleich nochmal CTRL+ALT+F7 kommt dein Desktop zurück?
Die_Kralle
country hat geschrieben: ↑Samstag 7. Oktober 2023, 16:59 Hab alles überflogen.
Bist Du ein Hexer / eine Hexe? Seit diesem Tipp bestimmt 30 Kalt- und Warmstarts, aber der Fehler tritt nicht auf.
Ich werde das aber im Kopf behalten.
Gruß Heiko
Die_Kralle
nach vielen Warm- und Kaltstarts und nach vielen Umschaltungen der Monitore,
kam es jetzt "endlich" wieder zu diesem Fehler.
Wie vorgeschlagen habe ich dann
STRG+ALT+F2
und
STRG+ALT+F7
ausprobiert.
Ergebnis: Der Schreibtisch blieb leer und nur ein Neustart konnte helfen.
Noch irgendjemand eine Idee?
Gruß Heiko
