Plasma 5.7.3, Manjaro Tools 0.13, Gambas, OpenRC (Unstable Update)
Video
KDE fans might consider to switch to unstable branch for testing the latest Plasma 5.7.3 release. We also updated the programming language gambas, openrc and worked on our manjaro-tools. Plus you find the regular upstream updates as usual.
Archlinux upstream fixes are now from: Mon Aug 02 19:24 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues.
Kind regards,
Troubleshoots
GTK3
You can install it with:
QT apps style with GTK
With QT 5.7 you need to install qt5-styleplugins and qt5ct and configure your system to have an unified look again (If you use applications with root-rights, do the same for your root user) .
ufw
steam
Reference: Archlinux wiki
Current supported kernels
Linux310 3.10.102
Linux312 3.12.62
Linux314 3.14.74
Linux316 3.16.36
Linux318 3.18.37
Linux319 3.19.8.23 [EOL]
Linux41 4.1.28
Linux42 4.2.8.13 [EOL]
Linux44 4.4.16
Linux45 4.5.7 [EOL]
Linux46 4.6.5
Linux47 4.7.0
Linux-RT-LTS 4.4.15-rt23
Linux-RT 4.6.5-rt9
Quelle
Zuletzt geändert von Blueriver am Dienstag 2. August 2016, 22:55, insgesamt 1-mal geändert.
