[gelöst] WINE und "Mit anderer Anwendung öffnen ..." Thema ist als GELÖST markiert
Die_Kralle
CPU: Intel Core i7-4700HQ
Kernel: 6.6.5-1-MANJARO
Desktop-Variante: XFCE 4.18
Hat sich bedankt: 34 Mal
Beitrag von Die_Kralle »
inxi -Fz
  Kernel: 6.3.4-2-MANJARO arch: x86_64 bits: 64 Desktop: Xfce v: 4.18.1
    Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: G750JS v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: G750JS v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: G750JS.208 date: 07/17/2014
Battery:
  ID-1: BAT0 charge: 50.8 Wh (96.0%) condition: 52.9/77.0 Wh (68.7%)
    volts: 14.8 min: 14.8
CPU:
  Info: quad core model: Intel Core i7-4700HQ bits: 64 type: MT MCP cache:
    L2: 1024 KiB
  Speed (MHz): avg: 900 min/max: 800/3400 cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 800 7: 1600 8: 800
    v: kernel
  Device-2: NVIDIA GK104M [GeForce GTX 870M] driver: N/A
  Device-3: Chicony USB2.0 HD UVC WebCam driver: uvcvideo type: USB
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1 driver: X:
    loaded: intel dri: i965 gpu: i915 resolution: 1: 1920x1080~60Hz
    2: 1920x1080~60Hz
  API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel HD Graphics 4600 (HSW
    GT2)
Audio:
    driver: snd_hda_intel
  API: ALSA v: k6.3.4-2-MANJARO status: kernel-api
Network:
  Device-1: Broadcom BCM4352 802.11ac Wireless Network Adapter driver: wl
  IF: wlp3s0 state: down mac: <filter>
  Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet driver: alx
  IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Bluetooth:
  Device-1: IMC Networks BCM20702A0 driver: btusb type: USB
Drives:
  Local Storage: total: 1.6 TiB used: 807.14 GiB (49.3%)
  ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541515A9E630
  ID-2: /dev/sdb vendor: SanDisk model: SD5SE2256G1002E size: 238.47 GiB
Partition:
  ID-1: / size: 233.38 GiB used: 79.83 GiB (34.2%) fs: ext4 dev: /dev/sdb2
  ID-2: /boot/efi size: 299.4 MiB used: 300 KiB (0.1%) fs: vfat
    dev: /dev/sdb1
Swap:
Sensors:
  System Temperatures: cpu: 49.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2200
Info:
  Processes: 266 Uptime: 12h 5m Memory: available: 30.8 GiB
  used: 3.85 GiB (12.5%) Shell: Bash inxi: 3.3.27
wenn ich das Kontextmenü einer Datei öffne, dann kann ich unter "Öffnen mit" den Punkt "Mit anderer Anwendung öffnen ..."
auswählen.
In der Liste der zur Verfügung stehenden Anwendungen, wird mir 63-mal "A Wine application" angeboten.
Aktuell habe ich nicht eine WINE-Application am Laufen.
Wie miste ich diese Liste aus?
Gruß Heiko
Zuletzt geändert von Die_Kralle am Donnerstag 1. Juni 2023, 20:58, insgesamt 1-mal geändert.
Re: WINE und "Mit anderer Anwendung öffnen ..."
Echt? zeig mal ein Screenshot oder so?
Die_Kralle
hier ein Ausschnitt:
Gruß Heiko
Hier habe ich was gefunden:
https://forum.archlinux.de/d/27270-stan ... ntfernen/2
Der Beitrag ist von Greg, 6. Dez 2014
Ich bin mir nicht mehr ganz sicher, aber ich glaube ich habe damals in /usr/share/applications/ den winekram rausgeschmissen. Seit dem werde ich mit notepad und dem Windoofmist nicht mehr belästigt. Korregiert mich bitte wenns nicht stimmt!!!
Ahh, ich korregiere mich selber. Hier habe ichs wieder gefunden:
http://cremy.de/blog/2010/09/30/wine-ap ... entfernen/
Etwas was mich schon länger genervt hat bei meiner Gnome-Installation unter Arch Linux ist, dass in dem Fenster zu dem man über "Mit anderer Anwendung öffnen" mehrmals "A Wine application" erscheint, obwohl ich Wine nicht einmal installiert habe.
Um dieses Problem zu beheben muss man einfach die wine-extension-*.desktop-Dateien unter ~/.local/share/applications/ löschen. Danach werden die Wine-Einträge nicht mehr angezeigt.
Die_Kralle
Super das hat funktioniert.
Gruß Heiko
