Kodi vs mysql-clients55
Die_Kralle
CPU: Intel Core i7-4700HQ
Kernel: 6.6.5-1-MANJARO
Desktop-Variante: XFCE 4.18
Hat sich bedankt: 34 Mal
Beitrag von Die_Kralle »
inxi -Fz
  Kernel: 6.3.3-1-MANJARO arch: x86_64 bits: 64 Desktop: Xfce v: 4.18.1
    Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: G750JS v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: G750JS v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: G750JS.208 date: 07/17/2014
Battery:
  ID-1: BAT0 charge: 52.9 Wh (100.0%) condition: 52.9/77.0 Wh (68.7%)
    volts: 14.8 min: 14.8
CPU:
  Info: quad core model: Intel Core i7-4700HQ bits: 64 type: MT MCP cache:
    L2: 1024 KiB
  Speed (MHz): avg: 822 min/max: 800/3400 cores: 1: 800 2: 800 3: 800 4: 800
    5: 805 6: 971 7: 800 8: 800
    v: kernel
  Device-2: NVIDIA GK104M [GeForce GTX 870M] driver: N/A
  Device-3: Chicony USB2.0 HD UVC WebCam driver: uvcvideo type: USB
  Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: intel dri: i965
    gpu: i915 resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
  API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel HD Graphics 4600 (HSW
    GT2)
Audio:
    driver: snd_hda_intel
  API: ALSA v: k6.3.3-1-MANJARO status: kernel-api
Network:
  Device-1: Broadcom BCM4352 802.11ac Wireless Network Adapter driver: wl
  IF: wlp3s0 state: down mac: <filter>
  Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet driver: alx
  IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Bluetooth:
  Device-1: IMC Networks BCM20702A0 driver: btusb type: USB
Drives:
  Local Storage: total: 1.6 TiB used: 829.36 GiB (50.7%)
  ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541515A9E630
  ID-2: /dev/sdb vendor: SanDisk model: SD5SE2256G1002E size: 238.47 GiB
Partition:
  ID-1: / size: 233.38 GiB used: 78.22 GiB (33.5%) fs: ext4 dev: /dev/sdb2
  ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
    dev: /dev/sdb1
Swap:
Sensors:
  System Temperatures: cpu: 54.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2300
Info:
  Processes: 267 Uptime: 1d 21h 54m Memory: available: 30.8 GiB
  used: 6.12 GiB (19.9%) Shell: Bash inxi: 3.3.27
Ich brauche für eine Anwendung den "mysql-clients55". Leider muss ich um den zu installieren Kodi deinstallieren.
Nach dem meine APP jetzt läuft wollte ich auch Kodi neu installieren, aber
- das Entfernen von libmysqlclient55 verletzt Abhängigkeit 'libmysqlclient55' benötigt von mysql-clients55
wie bekomme ich beides gleichzeitig zum Laufen?
Gruß Heiko
Benutzer 1534 gelöscht
Re: Kodi vs mysql-clients55
Hallo Heiko,
darf man fragen um welche zusätzliche App es geht? Vielleicht steht diese neue App prinzipiell im Konflikt mit Kodi.
Im Softwarecenter, wenn Du dort auf ""Installiert" drückst, erscheint links an der Leiste Verwaist. Klick das mal an und wenn dort etwas drin steht, entferne die Pakete, Aktualisiere die Datenbank und versuche erneut Kodi zu installieren.
Die_Kralle
die APP ist eine in Lazarus erstellte Anwendung um auf die Datenbank meines Joomla-Installation bei meinem Provider zuzugreifen.
Den Tipp mit "Verwaist" werde ich gleich mal probieren.
Gruß Heiko
Die_Kralle
bei mir erscheint kein "Verwaist" ...
Gruß Heiko
Verstehe ich nicht. Xfce zeigt bei mir in der VM die Auswahl an. Siehe Bild
Vielleicht solltest Du mal im Terminal eine komplette Systemaktualisierung durchführen mit folgendem Befehl:
sudo pacman -Syu
Die_Kralle
Susanne hat geschrieben: ↑Sonntag 21. Mai 2023, 11:43 Vielleicht solltest Du mal im Terminal eine komplette Systemaktualisierung durchführen mit folgendem Befehl:
sudo pacman -Syu
sudo pacman -Syu
 core ist aktuell
 extra ist aktuell
 community ist aktuell
 multilib ist aktuell
 Es gibt nichts zu tun
Gruß Heiko
Vielleicht hier mal nachlesen, wie man verwaiste Pakete deinstalliert.
https://wiki.manjaro.org/index.php/Pama ... d_Packages
Ich lösche wie gesagt nicht mehr benötige Pakete im Softwarecenter ( wie im beigefügten vorherigen Bild zu sehen) unter Verwaist. Im XFCE installierst du ja deine Programme nicht im Terminal oder sondern Software hinzufügen/enfernen App.
Die_Kralle
Susanne hat geschrieben: ↑Sonntag 21. Mai 2023, 15:16 Vielleicht hier mal nachlesen, wie man verwaiste Pakete deinstalliert.
Das scheint alt zu sein.
Die Befehle funktionieren nicht mehr wie angegeben.
Gruß Heiko
Die_Kralle hat geschrieben: ↑Sonntag 21. Mai 2023, 08:35 Kann Abhängigkeiten nicht erfüllen:
man kann mit pacman -Sdd paketname .. eine nicht abfrage für abhäningkeiten machen, aber kein plan ob das so richtig funkoniert. im schlimmsten fall mal kodi-git aus dem aur bauen dauert aber..
country hat geschrieben: ↑Sonntag 21. Mai 2023, 19:55 im schlimmsten fall mal kodi-git aus dem aur bauen dauert aber..
Gibt noch ein Flatpak Paket, das sollte auf jeden Fall laufen.
Die_Kralle hat geschrieben: ↑Sonntag 21. Mai 2023, 16:55 Die Befehle funktionieren nicht mehr wie angegeben.
Die funktionieren schon, aber wenn du keine verwaisten Pakete hast wird da auch nix angezeigt.
Susanne hat geschrieben: ↑Sonntag 21. Mai 2023, 15:16 Ich lösche wie gesagt nicht mehr benötige Pakete im Softwarecenter ( wie im beigefügten vorherigen Bild zu sehen) unter Verwaist.
Ich denke hier gilt dasselbe. Bei mir steht auch nicht Verwaist im linken Abschnitt. Und Fremd kennt mein pamac-manager auch nicht. Was auch immer mit "Fremd" gemeint ist.
Siliziumfuchs
CPU: Intel® Core™ i9-11900K
GPU: NVIDIA GeForce RTX 3070
GPU Treiber: NVidia 550.54.14
Danksagung erhalten: 34 Mal
Beitrag von Siliziumfuchs »
LaGGGer hat geschrieben: ↑Sonntag 21. Mai 2023, 20:24 Und Fremd kennt mein pamac-manager auch nicht. Was auch immer mit "Fremd" gemeint ist.
Bei mir werden dort Pakete aus AUR gelistet....
ManTuxer
CPU: Intel Core i7-9750H
Hat sich bedankt: 46 Mal
Danksagung erhalten: 75 Mal
Beitrag von ManTuxer »
Die_Kralle hat geschrieben: ↑Sonntag 21. Mai 2023, 10:37 bei mir erscheint kein "Verwaist" ...
Dann hast du vielleicht in Pamac den Software-Modus eingeschaltet. Hamburger Menü → Haken raus bei Software-Modus. Nun wird unter Installiert normalerweise auch Verwaist angezeigt.
Anzeigen lassen kannst du dir verwaiste Pakete auch im Terminal:
pamac list -o
Löschen kannst du verwaiste Pakete dann auch gleich in Pamac-GUI oder im Terminal mit dem Befehl:
pamac remove -o
oder mit:
sudo pacman -Rsn `pacman -Qqtd`
LaGGGer hat geschrieben: ↑Sonntag 21. Mai 2023, 20:24 Ich denke hier gilt dasselbe. Bei mir steht auch nicht Verwaist im linken Abschnitt. Und Fremd kennt mein pamac-manager auch nicht. Was auch immer mit "Fremd" gemeint ist.
Gleiches sollte auch bei dir gelten.
ManTuxer hat geschrieben: ↑Montag 22. Mai 2023, 06:39 Dann hast du vielleicht in Pamac den Software-Modus eingeschaltet. Hamburger Menü → Haken raus bei Software-Modus. Nun wird unter Installiert normalerweise auch Verwaist angezeigt.
pamac list -o
Danke für deine Hinweise. Allerdings funktioniert das nicht so wie von dir beschrieben.
Software Modus ist ausgeschaltet habe (war schon immer so, ist wohl standard). Drei Punkte sind zu sehen:
Wenn ich bei den einzelnen Kategorien auf den auf den Pfeil rechts klicke, erscheinen Untermenüs, sehr umfangreich. Aber auch hier ist kein Verwaist und Fremd zu finden.
Und so, wenn ich den Softwaremodus einschalte, neun Punkte, keine Untermenüs. Ist das gleiche als wenn ich wie im ersten Beispiel auf Kategorien klicke:
Im Terminal findet dein Befehl anscheinend ein verwaistes Paket bei mir:
pamac list -o
ttf-noto-nerd 2.3.3-2  community  546,6 MB
Geht natürlich auch mit yay, was ich bevorzuge:
yay -Qtdq
ttf-noto-nerd
Welche Version hat bei Dir Pamac(Softwarecenter)?
ManTuxer
LaGGGer hat geschrieben: ↑Montag 22. Mai 2023, 11:15 Software Modus ist ausgeschaltet habe (war schon immer so, ist wohl standard). Drei Punkte sind zu sehen:
Du befindest dich im falschen Reiter. "Installiert" ist der Punkt.
Verwaist Fremd unter Installiert.png (97.49 KiB) 2361 mal betrachtet
