Fensterposition nach dem Wechsel von zwei auf einen Monitor
Die_Kralle
CPU: Intel Core i7-4700HQ
Kernel: 6.6.5-1-MANJARO
Desktop-Variante: XFCE 4.18
Hat sich bedankt: 34 Mal
Beitrag von Die_Kralle »
inxi -Fz
  Kernel: 6.2.8-1-MANJARO arch: x86_64 bits: 64 Desktop: Xfce v: 4.18.1
    Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: G750JS v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: G750JS v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: G750JS.208 date: 07/17/2014
Battery:
  ID-1: BAT0 charge: 52.9 Wh (100.0%) condition: 52.9/77.0 Wh (68.7%)
    volts: 14.8 min: 14.8
CPU:
  Info: quad core model: Intel Core i7-4700HQ bits: 64 type: MT MCP cache:
    L2: 1024 KiB
  Speed (MHz): avg: 837 min/max: 800/3400 cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 1100 7: 800 8: 800
    v: kernel
  Device-2: NVIDIA GK104M [GeForce GTX 870M] driver: N/A
  Device-3: Chicony USB2.0 HD UVC WebCam type: USB driver: uvcvideo
  Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: intel dri: i965
    gpu: i915 resolution: 1920x1080~60Hz
  API: OpenGL v: 4.6 Mesa 23.0.1 renderer: Mesa Intel HD Graphics 4600 (HSW
    GT2)
Audio:
    driver: snd_hda_intel
  API: ALSA v: k6.2.8-1-MANJARO status: kernel-api
Network:
  Device-1: Broadcom BCM4352 802.11ac Wireless Network Adapter driver: wl
  IF: wlp3s0 state: down mac: <filter>
  Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet driver: alx
  IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Bluetooth:
  Device-1: IMC Networks BCM20702A0 type: USB driver: btusb
Drives:
  Local Storage: total: 1.6 TiB used: 802.31 GiB (49.0%)
  ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541515A9E630
  ID-2: /dev/sdb vendor: SanDisk model: SD5SE2256G1002E size: 238.47 GiB
Partition:
  ID-1: / size: 233.38 GiB used: 68.85 GiB (29.5%) fs: ext4 dev: /dev/sdb2
  ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
    dev: /dev/sdb1
Swap:
Sensors:
  System Temperatures: cpu: 46.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2200
Info:
  Processes: 278 Uptime: 21h 22m Memory: 30.81 GiB used: 4.06 GiB (13.2%)
  Shell: Bash inxi: 3.3.26
Wenn ich vom zwei Monitorbetrieb auf "Nur Notebook" mittels "Anzeige" umschalte, dann wird z.B. das Fenster der "Anzeige"-App nach rechts aus den Bildschirm geschoben, so das nur noch der Rand zu sehen ist.
Es soll in den Einstellungen eine Option geben, das beim Anzeigewechsel die Fenster mittig auf dem aktiven Display zentriert werden. Leider finde ich die Option nicht wieder.
Weiß jemand von Euch wo das noch eingestellt wird?
Gruß Heiko
Die_Kralle
Re: Fensterposition nach dem Wechsel von zwei auf einen Monitor
Diese Frage war auch wenn am 1. April gestellt, kein Aprilscherz.
Gruß Heiko
Benutzer 1534 gelöscht
Hallo Heiko,
ich habe das wenn auch unter KDE mal bei meinem Laptop welcher auch im Dock mit einem Monitor betrieben wird ausprobiert.
Ich wechsle vom Monitor zum Laptop und umgedreht oder sogar mit Anzeige beides mit dem Drücken der Windows Taste ( sog. Super Taste) und Taste P dort kann ich alles auswählen, wie ich die Bildschirmanzeige möchte. Probier das mal.
Die_Kralle
Hallo Susanne,
[Super]+[P] funktioniert bei mir nicht.
Ich muss [STRG]+[ALT]+[P] nutzen um die "Anzeige-Einstellungen" aufzurufen und dann unter "Erweitert" das entsprechende Profil auswählen.
Wenn ich zwei Monitore aktiv habe (wie auf monitor01.png) und dann auf nur einen Monitor wechsel, dann kann man schön am Anzeige-Dialog sehen was passiert (siehe monitor02.png:
Der Dialog wird nach rechts fast komplett aus dem Fenster geschoben.
Leider finde ich den Beitrag nicht wieder, in dem erklärt wurde, was man wo einstellen muss, damit in so einem Fall der Dialog auf dem verbliebenen Arbeitsplatz zentriert wird.
Gruß Heiko
Hallo Heiko,
ich habe gesehen, dass Du ja eine NVIDIA Grafikkarte hast, da hatte ich auch mal solche Probleme. Ich konnte Sie mit dem richtigen Grafiktreiber lösen. Schau mal unter Einstellungen/Hardwarekonfiguration welche Treiber installiert sind. In dieser Übersicht solltest Du NVIDIA Treiber angezeigt bekommen i.d.R. ist es der oberste den Du installieren solltest. Neustarten und schauen ob es jetzt in Ordnung ist mit der Anzeige.
Die_Kralle
Hallo Susanne.
Gruß Heiko
Hallo Heiko,
Du solltest Dich einlesen mit dem Thema Optimus-Manager .Du hast eine Hybrid Grafikkarte sprich 2 Karten. Mit dem Optimus-Manager kann man auswählen. Das wurde vor kurzem hier im Forum schon geklärt
siehe hier:
https://www.manjaro-forum.de/viewtopic.php?t=4290
zum Thema Optimus, hier nähere Infos:
https://wiki.manjaro.org/index.php/Conf ... ia_Optimus
