sources.list Thema ist als GELÖST markiert
sources.list
ich suche verzweifelt nach der sources.list analog einer Liste wie unter Ubuntu, Beispiel unten.
# deb cdrom:[Xubuntu 20.04.2.0 LTS _Focal Fossa_ - Release amd64 (20210209.1)]/ focal main multiverse restricted universe
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://archive.ubuntu.com/ubuntu/ focal main restricted
# deb-src http://archive.ubuntu.com/ubuntu/ focal main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://archive.ubuntu.com/ubuntu/ focal-updates main restricted
# deb-src http://archive.ubuntu.com/ubuntu/ focal-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://archive.ubuntu.com/ubuntu/ focal universe
# deb-src http://archive.ubuntu.com/ubuntu/ focal universe
deb http://archive.ubuntu.com/ubuntu/ focal-updates universe
# deb-src http://archive.ubuntu.com/ubuntu/ focal-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://archive.ubuntu.com/ubuntu/ focal multiverse
# deb-src http://archive.ubuntu.com/ubuntu/ focal multiverse
deb http://archive.ubuntu.com/ubuntu/ focal-updates multiverse
# deb-src http://archive.ubuntu.com/ubuntu/ focal-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse
# deb-src http://archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
deb http://archive.canonical.com/ubuntu focal partner
# deb-src http://archive.canonical.com/ubuntu focal partner
deb http://security.ubuntu.com/ubuntu focal-security main restricted
# deb-src http://security.ubuntu.com/ubuntu focal-security main restricted
deb http://security.ubuntu.com/ubuntu focal-security universe
# deb-src http://security.ubuntu.com/ubuntu focal-security universe
deb http://security.ubuntu.com/ubuntu focal-security multiverse
# deb-src http://security.ubuntu.com/ubuntu focal-security multiverse
# This system was installed using small removable media
# (e.g. netinst, live or single CD). The matching "deb cdrom"
# entries were disabled at the end of the installation process.
# For information about how to configure apt package sources,
# see the sources.list(5) manual.
Gibt es so etwas im System von Manjaro, wenn ja wo? Das Wiki hilft mir leider nicht weiter.
Re: sources.list
Hallo Tuemmler,
Ich nehme an, Du meinst eine Liste der aktuellen Spiegelserver. Die kannst Du in /etc/pacman.d/mirorlist einsehen
cat /etc/pacman.d/mirorlist
zum Verändern dient z.B. das Kommando
sudo pacman-mirrors --country Germany,Austria && sudo pacman -Syyu
oder
sudo pacman-mirrors --fasttrack && sudo pacman -Syyu
https://wiki.manjaro.org/index.php/Spec ... an-mirrors
Re: sources.list
Moin Moin, zunächst einmal Danke für die Hinweise.
Die Seite https://wiki.manjaro.org/index.php/Spec ... an-mirrors kannte ich schon und habe mich dort auch durchgeackert. Ich werde mich wohl einmal mit der "Updatepolitik" von Manjaro eingehender befassen müssen.
Re: sources.list
Sowas wie sources.list gibts in Manjaro nicht. Vielleicht meint du auch ein PPA? Das gibts auch nicht.
Am ehesten kann man ein PPA mit dem AUR vergleichen. Das Arch User Repository. Aber das gibts nur einmal, im Gegensatz zu den verschiedenen PPA's. Dennoch gibts hier eine Menge Programme.
Das AUR muss man aber erst aktivieren. Kennst du dich damit aus ?
Re: sources.list
LaGGGer hat geschrieben: ↑Donnerstag 13. Januar 2022, 15:41 Sowas wie sources.list gibts in Manjaro nicht. Vielleicht meint du auch ein PPA? Das gibts auch nicht.
Am ehesten kann man ein PPA mit dem AUR vergleichen. Das Arch User Repository. ...
Zunächst eimal danke für die Erläuterungen, habe ich mir fast gedacht.
Grundsätzlich ja, AUR sind, wenn ich mich richtig eingelesen habe das, was unter Ubuntu "Fremdquellen" sind.
Damit hat sich meine Frage
ich suche verzweifelt nach der sources.list analog einer Liste wie unter Ubuntu....
erledigt.
Dank an alle Unterstützer
