Manjaro Update - 2016-05-22 (stable)
Themen Author - Moderator
- Kernel: 6.1
- Hat sich bedankt: 28 Mal
- Danksagung erhalten: 153 Mal
We are happy to announce our first update for Manjaro 16.06-rc1 (Daniella)!
With our first release candidate of Pamac v4.1 we are almost ready to present you the latest graphical packagemanager of Manjaro. We updated our UI to your needs and fixed found bugs you have reported to us. Followed new features you get by installing pamac-dev:
reenabled double click to view details
integrated progressbar and terminal view
Also all our kernels got updated to their latest point-releases. 3.13 kernel series is now depreciated. Please update to a more current one as we won't maintain any extramodules for this series. ZFS is now at 0.6.57 and thunderbird got updated to 45.1. Last but not least Deepin got refreshed and has now new features. Archlinux upstream fixes are now from: Fri May 20 20:37:55 CEST 2016.
It is always good to check for updated packages, even we don't notify you about them. As usual people using our testing branch will help us to get snaps over to our stable branch almost smoothly. For notifications on daily bases please take a look at our mailing list. A detailed list of package changes can been found here2.
Kind regards,
Philip M
Kind regards,
Philip M
Zuletzt geändert von Blueriver am Sonntag 22. Mai 2016, 17:45, insgesamt 1-mal geändert.
Kernel: 4.20
Kernel: 4.20
- Kernel: 6.1
Re: Manjaro Update - 2016-05-22 (stable)
Das Update lief sauber durch und alles funktioniert einwandfrei.
System:  Host: Dirk Kernel: 4.6.0-1-MANJARO x86_64 (64 bit gcc: 6.1.1)
     Desktop: Xfce 4.12.3 (Gtk 2.24.30) info: xfce4-panel dm: lightdm
     Distro: Manjaro Linux
Zuletzt geändert von Blueriver am Montag 23. Mai 2016, 09:43, insgesamt 1-mal geändert.
Kernel: 4.20
Kernel: 4.20
- Erfahrenes Foren Mitglied
- Kernel: 5.XX
- GPU Treiber: NVIDIA 495.XXX
- Hat sich bedankt: 1 Mal
- Danksagung erhalten: 12 Mal
Bis jetzt alles Top bei KDE, XFCE4 und Cinnamon.ÂÂ
Zuletzt geändert von OlliFri am Dienstag 24. Mai 2016, 21:57, insgesamt 1-mal geändert.
Gruß Olli
- Neues Foren Mitglied
Wie immer, einwandfrei durchgelaufen.
Danke an das Manjaro-Team.
Gru
Leider geht mein HP Device Manager nicht mehr.
HP Linux Imaging and Printing System (ver. 3.16.5)
HP Device Manager ver. 15.0
Copyright (c) 2001-15 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
(28/65) Aktualisiere hplip            [######################] 100%
Warnung: /etc/hp/hplip.conf installiert als /etc/hp/hplip.conf.pacne
 File "/usr/bin/hp-toolbox", line 270, in <module>
  ui = import_module(ui_package + ".devmgr5")
 File "/usr/lib/python3.5/importlib/__init__.py", line 126, in import_module
  return _bootstrap._gcd_import(name[level:], package, level)
 File "<frozen importlib._bootstrap>", line 986, in _gcd_import
 File "<frozen importlib._bootstrap>", line 969, in _find_and_load
 File "<frozen importlib._bootstrap>", line 944, in _find_and_load_unlocked
 File "<frozen importlib._bootstrap>", line 222, in _call_with_frames_removed
 File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked
 File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
 File "<frozen importlib._bootstrap_external>", line 658, in exec_module
 File "<frozen importlib._bootstrap_external>", line 868, in get_code
 File "<frozen importlib._bootstrap_external>", line 815, in get_data
PermissionError: [Errno 13] Permission denied: '/usr/share/hplip/ui4/__init__.py
Zuletzt geändert von hanny am Montag 23. Mai 2016, 15:51, insgesamt 1-mal geändert.
[marika@manjaro ~]$ hp-check -t
Saving output in log file: /home/marika/hp-check.log
Dependency/Version Check Utility ver. 15.1
Note: hp-check can be run in three modes:
1. Compile-time check mode (-c or --compile): Use this mode before compiling the HPLIPÂ Â Â Â
supplied tarball (.tar.gz or .run) to determine if the proper dependencies are installed toÂ
successfully compile HPLIP.                                Â
2. Run-time check mode (-r or --run): Use this mode to determine if a distro supplied package
(.deb, .rpm, etc) or an already built HPLIP supplied tarball has the proper dependencies  Â
installed to successfully run.                               Â
3. Both compile- and run-time check mode (-b or --both) (Default): This mode will check bothÂ
of the above cases (both compile- and run-time dependencies).               Â
Check types:Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â
a. EXTERNALDEP - External Dependencies                           Â
b. GENERALDEP - General Dependencies (required both at compile and run time)Â Â Â Â Â Â Â Â Â
c. COMPILEDEP - Compile time Dependencies                         Â
d. [All are run-time checks]Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â
PYEXT SCANCONF QUEUES PERMISSIONÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â
Status Types:
  OK
  MISSING   - Missing Dependency or Permission or Plug-in
  INCOMPAT   - Incompatible dependency-version or Plugin-version
warning: manjarolinux distro is not found in AUTH_TYPES
warning: 0- version is not supported. Using 0-0 versions dependencies to verify and install...
| SYSTEM INFO |
Kernel: 4.4.11-1-MANJARO #1 SMP PREEMPT Thu May 19 18:14:14 UTC 2016 GNU/Linux
Host: manjaro
Proc: 4.4.11-1-MANJARO #1 SMP PREEMPT Thu May 19 18:14:14 UTC 2016 GNU/Linux
Distribution: 0
Bitness: 64 bit
| HPLIP CONFIGURATION |
HPLIP-Version: HPLIP 3.16.5
HPLIP-Home: /usr/share/hplip
warning: HPLIP-Installation: Auto installation is not supported for 0 distro version
Current contents of '/etc/hp/hplip.conf' file:
# hplip.conf. Generated from hplip.conf.in by configure.
[hplip]
version=3.16.5
[dirs]
home=/usr/share/hplip
run=/var/run
ppd=/usr/share/ppd/HP
ppdbase=/usr/share/ppd
doc=/usr/share/doc/hplip-3.16.5
html=/usr/share/doc/hplip-3.16.5
icon=/usr/share/applications
cupsbackend=/usr/lib/cups/backend
cupsfilter=/usr/lib/cups/filter
drv=/usr/share/cups/drv/hp
bin=/usr/bin
apparmor=/etc/apparmor.d
# Following values are determined at configure time and cannot be changed.
[configure]
network-build=yes
libusb01-build=no
pp-build=yes
gui-build=yes
scanner-build=yes
fax-build=yes
dbus-build=yes
cups11-build=no
doc-build=yes
shadow-build=no
hpijs-install=yes
foomatic-drv-install=yes
foomatic-ppd-install=yes
foomatic-rip-hplip-install=no
hpcups-install=yes
cups-drv-install=yes
cups-ppd-install=yes
internal-tag=3.16.5
restricted-build=no
ui-toolkit=qt5
qt3=no
qt4=no
qt5=yes
policy-kit=no
lite-build=no
udev_sysfs_rules=no
hpcups-only-build=no
hpijs-only-build=no
apparmor_build=no
Current contents of '/var/lib/hp/hplip.state' file:
[plugin]
installed = 1
eula = 1
version = 3.16.5
Current contents of '~/.hplip/hplip.conf' file:
[last_used]
device_uri = "hp:/net/HP_LaserJet_Professional_P_1102w?ip=192.168.178.24"
printer_name = HP_LaserJet_Professional_P_1102w
working_dir = .
[settings]
systray_visible = 0
systray_messages = 0
[commands]
scan = /usr/bin/xsane -V %SANE_URI%
[refresh]
rate = 30
enable = false
type = 1
[polling]
enable = false
interval = 5
device_list =
[fax]
voice_phone =
email_address =
[upgrade]
notify_upgrade = true
last_upgraded_time = 1424091636
pending_upgrade_time = 0
[installation]
date_time = 05/23/16 15:31:53
version = 3.16.5
<Package-name>Â Â Â Â <Package-Desc>Â Â Â <Required/Optional> <Min-Version> <Installed-Version> <Status>Â <Comment>
| General Dependencies |
python3-dbus    Python DBus - Python bindings for DBus           REQUIRED    0.80.0     1.2.4     OK    -
python3-xml     Python XML libraries                    REQUIRED    -       2.1.1     OK    -
python3-pil     PIL - Python Imaging Library (required for commandline scanning with hp-scan) OPTIONAL    -       1.1.7     OK    -
cups-image     CUPS image - CUPS image development files          REQUIRED    -       2.1.3     OK    -
cups-ddk      CUPS DDK - CUPS driver development kit           OPTIONAL    -       -       OK    -
sane        SANE - Scanning library                   REQUIRED    -       1.0.25     OK    -
error: python3-notify2 Python libnotify - Python bindings for the libnotify Desktop notifications OPTIONALÂ Â Â Â -Â Â Â Â Â Â Â -Â Â Â Â Â Â Â MISSINGÂ Â 'python3-notify2 needs to be installed'
cups-devel     CUPS devel- Common Unix Printing System development files  REQUIRED    -       2.1.3     OK    -
python3X      Python 2.2 or greater - Python programming language     REQUIRED    2.2      3.5.1     OK    -
python3-pyqt4-dbus PyQt 4 DBus - DBus Support for PyQt4            OPTIONAL    4.0      4.11.4     OK    -
libcrypto      libcrypto - OpenSSL cryptographic library          REQUIRED    -       1.0.2     OK    -
python3-devel    Python devel - Python development files           REQUIRED    2.2      3.5.1     OK    -
libjpeg       libjpeg - JPEG library                   REQUIRED    -       -       OK    -
python3-reportlab  Reportlab - PDF library for Python             OPTIONAL    2.0      3.3.0     OK    -
python3-pyqt4Â Â Â Â PyQt 4- Qt interface for Python (for Qt version 4.x)Â Â Â Â REQUIREDÂ Â Â Â 4.0Â Â Â Â Â Â 4.11.4Â Â Â Â Â OKÂ Â Â Â -
sane-devel     SANE - Scanning library development files          REQUIRED    -       1.0.25     OK    -
libpthread     libpthread - POSIX threads library             REQUIRED    -       b'2.23'    OK    -
libusb       libusb - USB library                    REQUIRED    -       1.0      OK    -
libnetsnmp-devel  libnetsnmp-devel - SNMP networking library development files REQUIRED    5.0.9     5.7.3     OK    -
| Python Extentions |
cupsext       CUPS-Extension                       REQUIRED    -       3.16.5     OK    -
hpmudext      IO-Extension                        REQUIRED    -       3.16.5     OK    -
| COMPILEDEP |
make        make - GNU make utility to maintain groups of programs   REQUIRED    3.0      4.1      OK    -
libtool       libtool - Library building support services         REQUIRED    -       2.4.6     OK    -
gcc         gcc - GNU Project C and C++ Compiler            REQUIRED    -       6.1.1     OK    -
| Scan Configuration |
scanext       Scan-SANE-Extension                     REQUIRED    -       3.16.5     OK    -
hpaio        HPLIP-SANE-Backend                     REQUIRED    -       3.16.5     OK    'hpaio found in /etc/sane.d/dll.conf'
| External Dependencies |
xsane        xsane - Graphical scanner frontend for SANE         OPTIONAL    0.9      0.999     OK    -
scanimage      scanimage - Shell scanning program             OPTIONAL    1.0      1.0.25     OK    -
dbus        DBus - Message bus system                  REQUIRED    -       1.10.8     OK    -
gs         GhostScript - PostScript and PDF language interpreter and previewer REQUIRED    7.05      9.19      OK    -
network       network -wget                        OPTIONAL    -       1.17.1     OK    -
policykit      PolicyKit - Administrative policy framework         OPTIONAL    -       0.113     OK    -
avahi-utils     avahi-utils                         OPTIONAL    -       0.6.32     OK    -
cups        CUPS - Common Unix Printing System             REQUIRED    1.1      2.1.3     OK    'CUPS Scheduler is running'
| DISCOVERED SCANNER DEVICES |
device `hpaio:/net/Officejet_Pro_8600?ip=192.168.178.28' is a Hewlett-Packard Officejet_Pro_8600 all-in-one
| DISCOVERED USB DEVICES |
No devices found.
| INSTALLED CUPS PRINTER QUEUES |
HP-Officejet-Pro-8600
Type: Printer
Device URI: hp:/net/Officejet_Pro_8600?ip=192.168.178.28
PPD: /etc/cups/ppd/HP-Officejet-Pro-8600.ppd
PPD Description: HP Officejet Pro 8600, hpcups 3.14.4
Printer status: printer HP-Officejet-Pro-8600 is idle. enabled since Do 19 Feb 2015 16:20:18 CET
Communication status: Good
Type: Printer
Device URI: hp:/net/HP_LaserJet_Professional_P_1102w?ip=192.168.178.24
PPD: /etc/cups/ppd/HP_LaserJet_Professional_P_1102w.ppd
PPD Description: HP LaserJet Professional P 1102w, hpcups 3.14.4, requires proprietary plugin
Printer status: printer HP_LaserJet_Professional_P_1102w is idle. enabled since Sa 09 Apr 2016 17:12:57 CEST
Required plug-in status: Installed
Roger-Router-Fax
Type: Unknown
Device URI: roger-cups:/
PPD: /etc/cups/ppd/Roger-Router-Fax.ppd
PPD Description: roger fax printer, 1.0
Printer status: printer Roger-Router-Fax is idle. enabled since Do 17 Jul 2014 15:34:36 CEST
warning: Printer is not HPLIP installed. Printers must use the hp: or hpfax: CUPS backend for HP-Devices.
| PERMISSION |
| SUMMARY |
Missing Required Dependencies
None
Missing Optional Dependencies
None
Total Errors: 1
Total Warnings: 1
Done.
[marika@manjaro ~]$
Status Types:
  OK
| SYSTEM INFO |
Host: manjaro
Distribution: 0
Bitness: 64 bit
[hplip]
version=3.16.5
[dirs]
run=/var/run
bin=/usr/bin
[configure]
network-build=yes
libusb01-build=no
pp-build=yes
gui-build=yes
scanner-build=yes
fax-build=yes
dbus-build=yes
cups11-build=no
doc-build=yes
shadow-build=no
hpijs-install=yes
hpcups-install=yes
internal-tag=3.16.5
restricted-build=no
ui-toolkit=qt5
qt3=no
qt4=no
qt5=yes
policy-kit=no
lite-build=no
udev_sysfs_rules=no
hpijs-only-build=no
apparmor_build=no
[plugin]
installed = 1
eula = 1
version = 3.16.5
[last_used]
working_dir = .
[settings]
systray_visible = 0
[commands]
[refresh]
rate = 30
enable = false
type = 1
[polling]
enable = false
interval = 5
device_list =
[fax]
voice_phone =
email_address =
[upgrade]
[installation]
version = 3.16.5
| Python Extentions |
| COMPILEDEP |
No devices found.
Type: Printer
Type: Printer
Roger-Router-Fax
Type: Unknown
| PERMISSION |
| SUMMARY |
None
None
Total Errors: 1
Total Warnings: 1
Done.
[marika@manjaro ~]$
[2016-05-23 15:58] Installed python-pyqt5 (5.5.1-2)
[2016-05-23 15:57] Installed python2-pyqt5 (5.5.1-2)
[2016-05-23 15:56] Installed pyqt5-common (5.5.1-2)
Diese Pakete l
Diese Pakete l
- Kernel: 510
- Hat sich bedankt: 43 Mal
- Danksagung erhalten: 11 Mal
