2017-05-27 - Kernels, Cinnamon, Firefox, Mesa, OpenSSL, Kodi (Stable Update)
Themen Author - Moderator
- Kernel: 6.1
- Hat sich bedankt: 28 Mal
Hi community,
some of our updated kernels got marked as EOL. Please move on to the next kernel series soon. We also consider to remove some EOL kernels1 from our repositories.
With this update-pack we have the latest Mesa v17.1 series, Firefox v53.0.3, Cinnamon v3.4.x and updated KODI-Addons. Additionally we have the latest ALSA and updated Python and Haskell packages. With an API-fix of openssl-1.0 the issue we had with Steam games should be fixed now. For all fans of XFCE, we added the latest GTK3 packages. Currently the panel1 got completely ported. Additionally you get the regular upstream updates of packages.
If you use Samba as a connection to your Windows machines, please update to the latest Samba release as soon as possible due a security issue we had fixed.
Please give us feedback as usual and report any issues you may see with this update.
Current supported Kernels
linux310 3.10.105
linux312 3.12.74 [EOL]
linux316 3.16.42
linux318 3.18.55 [EOL]
linux41 4.1.39
linux44 4.4.70
linux48 4.8.17 [EOL]
linux49 4.9.30
linux410 4.10.17 [EOL]
linux411 4.11.3
linux-RT-LTS 4.4.66_rt79 (x86_64)
linux-RT 4.9.27_rt18 (x86_64)
Package Updates (Sat May 27 07:26:39 CEST 2017)
stable community i686: 636 new and 628 removed package(s)
stable community x86_64: 644 new and 635 removed package(s)
stable core i686: 19 new and 19 removed package(s)
stable core x86_64: 19 new and 19 removed package(s)
stable extra i686: 281 new and 278 removed package(s)
stable extra x86_64: 281 new and 278 removed package(s)
stable multilib x86_64: 28 new and 29 removed package(s)
A detailed list of package changes can be found here.
Quelle
linux310 3.10.105
linux316 3.16.42
linux41 4.1.39
linux44 4.4.70
linux49 4.9.30
linux411 4.11.3
Quelle
Kernel: 4.20
Kernel: 4.20
- Kernel: 6.1
Re: 2017-05-27 - Kernels, Cinnamon, Firefox, Mesa, OpenSSL, Kodi (Stable Update)
Ohne Probleme!
System:  Host: dirk-pc Kernel: 4.11.3-1-MANJARO x86_64 (64 bit)
     Desktop: Gnome 3.24.2 Distro: Manjaro Linux
Kernel: 4.20
Kernel: 4.20
- Erfahrenes Foren Mitglied
- Kernel: 5.XX
- GPU Treiber: NVIDIA 495.XXX
- Hat sich bedankt: 1 Mal
- Danksagung erhalten: 12 Mal
Hi
Alles glatt gegangen.
Danke an das Manjaro Team für ein immer besser laufendes Plasma 5 System!
Gruß Olli
- Kernel: 510
- Hat sich bedankt: 43 Mal
- Danksagung erhalten: 11 Mal
Nachdem Update auf meinem Desktop-Rechner (LXQt und Mate) stellte ich fest, dass sich Seafile (verschlüsselte Datensynchronisation) nicht mehr starten lässt. Wenn ich es über ein Terminal mit /usr/bin/seafile-applet versuche, erhalte ich fplgende Fehlermeldung:
Seafile-Nutzer muss man also vor diesem Update warnen. Eine Neuinstallation hilft nichts.
/usr/bin/seafile-applet: /usr/lib/libcrypto.so.1.0.0: version `OPENSSL_1.0.2d' not found (required by /usr/bin/seafile-applet)
Seit diesem Update funktioniert das Netzwerk nach einem Suspend to Ram nicht mehr.
@m-bostaurus
Vielleicht hilft dir das:
After upgrading openssl-1.0 and qt5-base, it was a matter of just running:
pacaur -S seafile-client --rebuild
https://aur.archlinux.org/packages/seafile-client/
@m-bostaurus
Zuletzt geändert von Benutzer 118 gelöscht am Samstag 27. Mai 2017, 18:47, insgesamt 1-mal geändert.
- Kernel: 510
@Josef_K Das Seafile-Problem ist gelöst. Fand heute Morgen auf https://aur.archlinux.org/packages/seafile/ folgenden Hinweis vor: "You need to re-install seafile-client (not seafile). Then the package will re-compile against the new version of openssl." Habe das gemacht und alles funktioniert wieder. Hatte gestern nur seafile reinstalliert ... Danke für die Unterstützung!
- Kernel: 510
Nach dem das Problem mit Seafile gelöst war, habe ich alle meine Rechner aktualisiert und alles hat gut geklappt. Ein Hoch auf das Manjaro-Team!
- Kernel: 5.15 / 6.0
- GPU Treiber: Intel i915
- Hat sich bedankt: 15 Mal
- Danksagung erhalten: 36 Mal
Keine Probleme während der Aktualisierung und auch nicht danach.ÂÂ
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft!
