2017-04-15 - Kernels, Thunderbird, Firefox, Libreoffice (Stable Update)
Themen Author - Moderator
- Kernel: 6.1
- Hat sich bedankt: 28 Mal
Hi community,
Manjaro is a wonderful project to be part of. To celebrate my birthday, our development team worked hard to stabilize a lot of packages for todays update.
We worked hard to get the latest Firefox and Thunderbird packages ready. Marcus adjusted his OpenRC packages to be more compatible to his change made to use elogind from now on. Bernhard reviewed a lot of Deepin packages and we created several release candidates of his edition to be tested by you, our community.
For our coding community we have the latest haskell packages as usual. For all using Manjaro productive we have the latest LibreOffice ready for your current projects. We also fixed some graphical drivers and updated to the latest Mesa-Stack. Last but not least we updated some of our multimedia codecs and most of our kernels to the latest releases.
Please give us feedback as usual and report any issues you may see with this update.
kind regards,
Philip Müller and the Development Team
Current supported Kernels
linux310 3.10.105
linux312 3.12.73
linux316 3.16.42
linux318 3.18.48 [EOL]
linux41 4.1.39
linux44 4.4.61
linux48 4.8.17 [EOL]
linux49 4.9.22
linux410 4.10.10
linux-RT-LTS 4.4.60_rt73
linux-RT 4.9.20_rt16
Package Updates (Sat Apr 15 11:21:12 CEST 2017)
stable community i686: 708 new and 777 removed package(s)
stable community x86_64: 745 new and 813 removed package(s)
stable core i686: 31 new and 31 removed package(s)
stable core x86_64: 31 new and 31 removed package(s)
stable extra i686: 348 new and 344 removed package(s)
stable extra x86_64: 348 new and 344 removed package(s)
stable multilib x86_64: 9 new and 9 removed package(s)
Package changes can be reviewed here.
Quelle
kind regards,
linux310 3.10.105
linux312 3.12.73
linux316 3.16.42
linux41 4.1.39
linux44 4.4.61
linux49 4.9.22
linux410 4.10.10
Quelle
Kernel: 4.20
Kernel: 4.20
- Kernel: 6.1
Re: 2017-04-15 - Kernels, Thunderbird, Firefox, Libreoffice (Stable Update)
Ohne Probleme!
System:Â Â Host: dirk-pc Kernel: 4.10.10-1-MANJARO x86_64 (64 bit)
Kernel: 4.20
Kernel: 4.20
- Erfahrenes Foren Mitglied
- Kernel: 5.XX
- GPU Treiber: NVIDIA 495.XXX
- Hat sich bedankt: 1 Mal
- Danksagung erhalten: 12 Mal
Hi, und frohe Ostern.Â
Null Problemo!
Null Problemo!
Gruß Olli
Checkliste für dieses Update für User die mit OpenRC arbeiten.
OPTIONAL!!!
lightdm eintragen falls nicht vorhanden.
PFLICHTKÃœR
unter XFCE4 in “Sitzung und Startverhalten“ Reiter “Automatisch gestartete Anwendungen“
den “Legitimationsdienst von PolicyKit (Legitimationsdienst von PolicyKit)“ aktivieren (falls nicht vorhanden).
Grüße der Prinz
OPTIONAL!!!
rc-update add xdm default
sudo pacman -S lightdm
sudo pacman -S lightdm-gtk-greeter
nano /etc/conf.d/xdm
PFLICHTKÃœR
sudo pacman -Syu
Grüße der Prinz
[size=1em]Nach[/size]
[size=1em]und[/size]
[size=1em]ist das Update durchgelaufen.[/size]
[size=1em]Danach musste ich noch elogind aktivieren:[/size]
[size=1em]forum.manjaro.org/t/stable-update-2017-04-15-kernels-thunderbird-firefox-libreoffice/21784/95[/size]
Anschließend musste ich noch den Drucker neu installieren. Funktionierte aber nur mit localhost:631.
Josef
sudo pacman -S networkmanager
sudo pacman -Rdd light-locker-consolekit
sudo rc-update add elogind default
sudo rc-service elogind start
Josef
Zuletzt geändert von Benutzer 118 gelöscht am Dienstag 18. April 2017, 16:17, insgesamt 1-mal geändert.
@Josef genau das von Dir beschriebenen Vorgehen (vom Manjaro-Forum Eng.) – "kann" das von mir beschriebene Handeln danach nötig machen!Â
- Kernel: 510
- Hat sich bedankt: 43 Mal
- Danksagung erhalten: 11 Mal
Bei mir lief es auf allen Rechnern gut. Allerdings ist der Kalender Lightning innert Thunderbird auf Englisch ...
- Kernel: 6.1
[quote="m-bostaurus"]
Sieh mal hier
http://www.manjaro-forum.de/index.php/t ... ml#msg5460
Sieh mal hier
Kernel: 4.20
Kernel: 4.20
- Kernel: 510
Danke, das ist die Lösung. Als ich den Lösungsweg las, fiel mir ein, dass es das Problem auch schon einmal gegeben hatte.
