Unterstützt Manjaro Luks2?
Wo ist da der Unterschied zu Luks?
Luks2
- CPU: AMD Ryzen 5 2400 G
- GPU: HD
- Kernel: 5.x
- Desktop-Variante: Mate
- GPU Treiber: radeon
- Hat sich bedankt: 5 Mal
- Danksagung erhalten: 2 Mal
- GPU: HD
- Kernel: 5.x
- CPU: Ryzen 7 3700X
- GPU: RTX 3060Ti
- Kernel: up-to-date
- Desktop-Variante: Cinnamon
- GPU Treiber: RTX 3060Ti
- Hat sich bedankt: 122 Mal
Re: Luks2
https://gitlab.com/cryptsetup/cryptsetup/
https://gitlab.com/cryptsetup/cryptsetu ... type=heads
Luks2 ist abwärtskompatibel mit Luks...
edit/
Warning:
In any scenario, never use file system repair software such as fsck directly on an encrypted volume, or it will destroy any means to recover the key used to decrypt your files. Such tools must be used on the decrypted (opened) device instead.
For the LUKS2 format:
GRUB's support for LUKS2 is limited; see GRUB#Encrypted /boot for details. Use LUKS1 (cryptsetup luksFormat --type luks1) for partitions that GRUB will need to unlock.
The LUKS2 format has a high RAM usage per design, defaulting to 1GB per encrypted mapper. Machines with low RAM and/or multiple LUKS2 partitions unlocked in parallel may error on boot. See the --pbkdf-memory option to control memory usage.[1]
https://wiki.archlinux.org/title/Dm-cry ... ire_system
