Cronyk
Beiträge: 17 Registriert: Sonntag 23. Juni 2019, 22:50
CPU: AMD Ryzen 5 2600 Six-Core Processor
GPU: AMD Radeon RX 6700 XT
Kernel: 6.4.0_rt6-2
Desktop-Variante: xfce
GPU Treiber: The X.Org Foundation 21.1.8
Beitrag
von Cronyk » Montag 7. August 2023, 19:42
ich habe Manjaro frisch installiert. Ton läuft über USB Headset und VR-Headset; aber nicht über den Monitor (HDMI). Wo kann ich da ansetzen?
Systeminformationen:
inxi --full
Host: Nexus Kernel: 6.4.0-2-rt6-MANJARO arch: x86_64 bits: 64 Desktop: Xfce
v: 4.18.1 Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: B450M GAMING PLUS (MS-7B87) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.40
date: 01/25/2019
CPU:
Info: 6-core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP cache: L2: 3 MiB
Speed (MHz): avg: 2450 min/max: 1550/3400 cores: 1: 1550 2: 1550 3: 1550
4: 2800 5: 3400 6: 3400 7: 2923 8: 2800 9: 1550 10: 2629 11: 2455 12: 2800
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
driver: amdgpu v: kernel
Device-2: WaveRider USB Live camera driver: snd-usb-audio,uvcvideo
type: USB
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2 driver: X:
loaded: amdgpu unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu
resolution: 1: 1920x1080~60Hz 2: 2560x1440~144Hz 3: 1920x1080~60Hz
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon RX 6700 XT (navi22
LLVM 15.0.7 DRM 3.52 6.4.0-2-rt6-MANJARO)
Audio:
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel
Device-2: AMD Family 17h HD Audio driver: snd_hda_intel
Device-3: WaveRider USB Live camera driver: snd-usb-audio,uvcvideo
type: USB
Device-4: Logitech G430 Surround Sound Gaming Headset
driver: hid-generic,snd-usb-audio,usbhid type: USB
Device-5: Oculus VR Rift S
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB
API: ALSA v: k6.4.0-2-rt6-MANJARO status: kernel-api
Network:
driver: r8169
IF: enp27s0 state: up speed: 1000 Mbps duplex: full mac: 00:d8:61:2f:fa:63
Drives:
Local Storage: total: 4.54 TiB used: 77.42 GiB (1.7%)
ID-1: /dev/sda vendor: Samsung model: SSD 870 QVO 2TB size: 1.82 TiB
ID-2: /dev/sdb vendor: Western Digital model: WD2003FYPS-27W9B0
ID-3: /dev/sdc vendor: Crucial model: CT250MX500SSD1 size: 232.89 GiB
ID-4: /dev/sdd vendor: Mushkin model: MKNSSDSR500GB size: 465.76 GiB
ID-5: /dev/sde vendor: Seagate model: WDC WDS240G1G0B-00RC30
Partition:
ID-1: / size: 211.02 GiB used: 77.42 GiB (36.7%) fs: ext4 dev: /dev/sdc2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/sdc1
Swap:
ID-1: swap-1 type: file size: 30 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:
System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 46.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Info:
Processes: 379 Uptime: 9m Memory: total: 16 GiB available: 15.57 GiB
used: 2.11 GiB (13.5%) Shell: Bash inxi: 3.3.28
Semper ludens!
Beiträge: 905 Registriert: Samstag 21. Mai 2016, 12:12
Hat sich bedankt: 63 Mal
Danksagung erhalten: 118 Mal
Beitrag
von djeli » Dienstag 8. August 2023, 11:23
Moin
Die Ausgabe lässt sich in "pavucontrol" (Lautstärkeregelung) unter Wiedergabe einstellen.Rechts das kleine Auswahlfenster.
Cronyk
Kernel: 6.4.0_rt6-2
Beitrag
von Cronyk » Dienstag 8. August 2023, 16:29
Danke für deine Antwort, ja das ist korrekt, der Schirm wird auch erkannt und angesteuert. Es gibt sogar passend zum abgespielten Stück einen Ausschlag. Allerdings ohne Ton:
Semper ludens!
Beitrag
von djeli » Dienstag 8. August 2023, 20:29
Wenn ein Pegel angezeigt wird sollte auch Ton rauskommen!
Was ist es denn für ein HDMI Gerät?
Monitor mit Lautsprecher?
Cronyk
Kernel: 6.4.0_rt6-2
Beitrag
von Cronyk » Montag 14. August 2023, 13:19
Fernseher mit Lautsprecher: SONY KDL-50W685A
Semper ludens!
Beiträge: 1560 Registriert: Freitag 26. Juni 2020, 18:53
Kernel: 6.8
Hat sich bedankt: 145 Mal
Danksagung erhalten: 252 Mal
Beitrag
von LaGGGer » Dienstag 15. August 2023, 11:20
djeli hat geschrieben: ↑ Dienstag 8. August 2023, 11:23
Moin
Hast du wohl nicht verstanden.
In der obersten Zeile ist rechts ein Pfeil. Den Pfeil anklicken bis zum Reiter
Konfiguration . Du kannst das Fenster auch einfach größer ziehen.
Konfiguration anklicken. Unter Profil solltest du das einstellen können.
Cronyk
Kernel: 6.4.0_rt6-2
Beitrag
von Cronyk » Montag 21. August 2023, 11:26
Ok... das war einfach.
Vielen Dank ich habe es wirklich einfach nicht gewusst.
Beste Grüße,
Cronyk
Semper ludens!
