Steam startet nicht mehr nach Update Thema ist als GELÖST markiert
Kernel: 6.8
Hat sich bedankt: 145 Mal
Danksagung erhalten: 252 Mal
Nachdem ich das große update heute Morgen ausgeführt habe, startet mein Steam nicht mehr. Wie ihr warscheinlich wißt, ist Steam für viele Linux & Windows Spiele zuständig.
Hier der Start aus dem Terminal:
steam-runtime
steam.sh[3242]: Running Steam on manjarolinux 23.0.0 64-bit
steam.sh[3242]: STEAM_RUNTIME is enabled automatically
setup.sh[3316]: Steam runtime environment up-to-date!
steam.sh[3242]: Steam client's requirements are satisfied
[2023-07-10 16:25:38] Startup - updater built Jun 21 2023 21:17:38
[2023-07-10 16:25:38] Startup - Steam Client launched with: '/home/ws/.local/share/Steam/ubuntu12_32/steam'
07/10 16:25:38 Init: Installing breakpad exception handler for appid(steam)/version(1687386907)/tid(3373)
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2023-07-10 16:25:38] Loading cached metrics from disk (/home/ws/.local/share/Steam/package/steam_client_metrics.bin)
[2023-07-10 16:25:38] Using the following download hosts for Public, Realm steamglobal
[2023-07-10 16:25:38] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
[2023-07-10 16:25:38] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2023-07-10 16:25:38] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2023-07-10 16:25:38] Checking for update on startup
[2023-07-10 16:25:38] Suche nach verfügbaren Updates …
[2023-07-10 16:25:38] Downloading manifest: https://client-update.akamai.steamstatic.com/steam_client_ubuntu12
[2023-07-10 16:25:38] Manifest download: send request
[2023-07-10 16:25:38] Manifest download: waiting for download to finish
[2023-07-10 16:25:38] Manifest download: finished
[2023-07-10 16:25:38] Download skipped: /steam_client_ubuntu12 version 1687386907, installed version 1687386907, existing pending version 0
[2023-07-10 16:25:38] Nothing to do
[2023-07-10 16:25:38] Installation wird überprüft …
[2023-07-10 16:25:38] Performing checksum verification of executable files
[2023-07-10 16:25:39] Verification complete
(process:3373): GLib-GObject-CRITICAL **: 16:25:39.468: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
(process:3373): GLib-GObject-CRITICAL **: 16:25:39.468: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf63a9db0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf63a8500
GetWin32Stats: display was not open yet, good
Loaded SDL version 3.0.0-1782-g214d5daa3
ComputeStartupMode: found registry default startup mode: 0
Switching to desktopui, since -vgui was not specified
steamwebhelper.sh[3480]: Runtime for steamwebhelper: defaulting to /home/ws/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[3480]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 90 milliseconds to initialize
Failed to init SteamVR because it isn't installed
Assertion 'device' failed at src/libsystemd/sd-device/device-private.c:103, function device_get_tags_generation(). Aborting.
crash_20230710162540_27.dmp[3654]: Uploading dump (out-of-process)
/tmp/dumps/crash_20230710162540_27.dmp
crash_20230710162540_27.dmp[3654]: Finished uploading minidump (out-of-process): success = yes
crash_20230710162540_27.dmp[3654]: response: CrashID=bp-00431396-dde7-49d3-914a-1b4222230710
crash_20230710162540_27.dmp[3654]: file ''/tmp/dumps/crash_20230710162540_27.dmp'', upload yes: ''CrashID=bp-00431396-dde7-49d3-914a-1b4222230710''
/home/xxx/.local/share/Steam/steam.sh: Zeile 798:  3373 Abgebrochen             (Speicherabzug geschrieben) "$STEAMROOT/$STEAMEXEPATH" "$@"
Habe grade die Lösung gefunden als ich das hier geschrieben habe, möglicherweise hat da auch jemand Probleme mit. Ich lasse dass mal so stehen.
Ausschlaggebend war diese Zeile:
Github hat mir dann die Lösung verraten, ein Downgrade musste gemacht werden:
https://github.com/ValveSoftware/steam- ... 1625627064
Im Terminal eingeben:
sudo pacman -U https://archive.archlinux.org/packages/l/libgudev/libgudev-237-2-x86_64.pkg.tar.zst
sudo pacman -U https://archive.archlinux.org/packages/l/lib32-libgudev/lib32-libgudev-237-2-x86_64.pkg.tar.zst
steam --reset
Steam rödelt dann ne Zeitlang, man muss sich neu einloggen, aber dann isses wieder in Ordnung, Alle installierten Spiele starten wieder, ohne Neuinstallation. Gab noch kleinere Updates aber das wars dann aber.
Tja, das war es leider nicht, nicht alle Spiele funktionieren.
Zu voreilig gewesen, doch nicht gelöst. Kann das leider nicht rückgängig machen.
Zuletzt geändert von LaGGGer am Montag 10. Juli 2023, 18:34, insgesamt 2-mal geändert.
Benutzer 1458 gelöscht
Re: [Gelöst] Steam startet nicht mehr nach Update
Immer wieder spannend. Hab gerade das Update gefahren und Steam funktionierte bei mir auf Anhieb. Habs extra getestet, wegen Deinem Beitrag hier.
country
CPU: Ryzen 7 3700X
GPU: RTX 3060Ti
Kernel: up-to-date
GPU Treiber: RTX 3060Ti
Hat sich bedankt: 122 Mal
Danksagung erhalten: 227 Mal
Re: Steam startet nicht mehr nach Update
Beitrag von country »
Hallo LaGGGer,
startet steam nun ohne probleme? lösch mal die /home/xxx/.local/share/Steam/steam.sh und starte steam, er macht quasi eine Neuinstallation.
Was passiertwenn du auf Spielen klickst? bleibt das spiel ausgeführt und oder bricht steam gleich wieder ab?
Sind das native games? evtl mal die proton version wechseln. Evtl noch unter Einstellungen -> download -> cache leeren + shader-pre caching löschen Deaktivieren..
Kernel: 6.8
country hat geschrieben: ↑Montag 10. Juli 2023, 18:47 startet steam nun ohne probleme? lösch mal die /home/xxx/.local/share/Steam/steam.sh und starte steam, er macht quasi eine Neuinstallation.
Neuinstallation hat Steam schon gemacht, kein Auswirkung.
country hat geschrieben: ↑Montag 10. Juli 2023, 18:47 Was passiertwenn du auf Spielen klickst? bleibt das spiel ausgeführt und oder bricht steam gleich wieder ab?
Steam bricht nach dem Startversuch gleich wieder ab.
country hat geschrieben: ↑Montag 10. Juli 2023, 18:47 Sind das native games? evtl mal die proton version wechseln. Evtl noch unter Einstellungen -> download -> cache leeren + shader-pre caching löschen Deaktivieren..
Sind alles Windows Games die nicht starten. Verschiedene Protons habe ich getestet, bringt nix.
Cache habe ich noch nicht geleert, mache ich noch.
LaGGGer hat geschrieben: ↑Montag 10. Juli 2023, 20:32 Sind alles Windows Games die nicht starten. Verschiedene Protons habe ich getestet, bringt nix.
Ich hab es gerade mal mit Flotsam ausprobiert (reines Windows Game). Das ließ sich bei mir installieren und starten (wenn auch mit der falschen Grafikkarte). Ich hatte vorher allerdings noch nie ein Windows Game installiert.
Vielleicht hilft diese Info um den Fehler zu finden? Cache z.B. oder Fehler in einem Paket. Vulkan Shader Problem. Sowas?
Kernel: 6.8
Ok, ich habe aufgegeben.
Habe Manjaro Cinnamon mit Steam neu auf ner zweiten SSD Installiert. Von Steam habe ich auf den schon vorhandenen Spiele Ordner auf der ersten SSD (wo die Spiele nicht mehr starten) verwiesen.
Das hat funktioniert, die Spiele laufen alle wieder.
Dasselbe muss ich noch mit Epic machen, hierfür nutze ich dann Heroic.
Die erste Platte wird später von der Manjaro installation befreit, die Spiele Ordner bleiben.
So wird ein Schuh draus. ;D
Ja man kommt auch von Münster aus über München nach Hamburg. ;D Aber in der Tat funktioniert das auch unter Windows sehr gut, wenn man die Steam Spiele auf einer anderen Platte hat, kann man problemlos wieder einlesen und sie funktionieren auch.
Kernel: 6.8
Abschließende Info:
Die "alte" XFCE Installation ist wieder voll funktionsfähig, kamen ja einige Updates.
Alle installierten Spiele starten.
Dennoch werde ich das demnächst so einrichten und den Spiele Ordner auf eine Extra SSD setzen. Aber nicht mit Cinnamon, dieser Desktop hat in meinen Augen schwer nachgelassen.
Aber das ist ein anderes Thema.
