wie zwing ich LightDM dazu das er mir das Login Fenstern im Primary Display anzeigt?
ich hab schon folgendes versucht.
in /etc/lightdm/lightdm-gtk-greeter.conf
[greeter]
active-monitor=0
in /etc/lightdm/lightdm.conf
display-setup-script=xrandr --output DP-4 --primary
xrandr -q took  19s at  19:36:59
Screen 0: minimum 8 x 8, current 5760 x 2160, maximum 32767 x 32767
HDMI-0 connected 3840x2160+0+0 (normal left inverted right x axis y axis) 1600mm x 900mm
3840x2160 60.00 + 119.88* 100.00 59.94 50.00 29.97 25.00 23.98
4096x2160 119.88 100.00 59.94 50.00 29.97 25.00 24.00 23.98
2560x1440 120.00
1920x1080 119.88 100.00 60.00 59.94 50.00 29.97 25.00 23.98
1280x1024 60.02
1280x720 59.94 50.00
1152x864 60.00
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 59.94
640x480 59.95 59.94
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 connected primary 1920x1080+3840+350 (normal left inverted right x axis y axis) 531mm x 298mm
1920x1080 60.00 + 144.00* 119.98 99.93 59.94 50.00 23.98
1680x1050 59.95
1600x900 60.00
1280x1024 143.85 119.96 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1024x768 143.86 119.99 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
DP-5 disconnected (normal left inverted right x axis y axis)
EDIT:Ich stelle gerade fest das alle neun Programme die ich starte im secondary Display starten. Obwohl unter -> Anzeigeeinstellen -> der DP-4 auf "Set as Primary" aktiv ist.
sieht jemand ein Fehler? Danke
