lensfun ist in der Version 1:0.3.3-1 installiert. Laut der Liste auf Github sollte das Nikkor AF-S 70-200mm f/2.8G VR IF-ED eigentlich dabei sein. In Darktable wird das Objektiv nicht gefunden.
Habe sudo lesfun-apdate-data versucht, aber der Host wird nicht gefunden.
Reading http://lensfun.sourceforge.net/db/versions.json …
Reading http://wilson.bronger.org/lensfun-db/versions.json …
File "/usr/lib/python3.10/urllib/request.py", line 1348, in do_open
h.request(req.get_method(), req.selector, req.data, headers,
File "/usr/lib/python3.10/http/client.py", line 1282, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/lib/python3.10/http/client.py", line 1328, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/lib/python3.10/http/client.py", line 1277, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/lib/python3.10/http/client.py", line 1037, in _send_output
self.send(msg)
File "/usr/lib/python3.10/http/client.py", line 975, in send
self.connect()
File "/usr/lib/python3.10/http/client.py", line 941, in connect
self.sock = self._create_connection(
File "/usr/lib/python3.10/socket.py", line 845, in create_connection
raise err
File "/usr/lib/python3.10/socket.py", line 833, in create_connection
sock.connect(sa)
OSError: [Errno 113] No route to host
During handling of the above exception, another exception occurred:
File "/usr/bin/lensfun-update-data", line 136, in <module>
read_location("http://wilson.bronger.org/lensfun-db/")
File "/usr/bin/lensfun-update-data", line 118, in read_location
response = urllib.request.urlopen(base_url + "versions.json")
File "/usr/lib/python3.10/urllib/request.py", line 216, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python3.10/urllib/request.py", line 519, in open
response = self._open(req, data)
File "/usr/lib/python3.10/urllib/request.py", line 536, in _open
result = self._call_chain(self.handle_open, protocol, protocol +
File "/usr/lib/python3.10/urllib/request.py", line 496, in _call_chain
result = func(*args)
File "/usr/lib/python3.10/urllib/request.py", line 1377, in http_open
return self.do_open(http.client.HTTPConnection, req)
File "/usr/lib/python3.10/urllib/request.py", line 1351, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [Errno 113] No route to host>
