Nostradamus
Beiträge: 12 Registriert: Samstag 28. Mai 2016, 20:58
Beitrag
von Nostradamus » Sonntag 26. Juni 2022, 12:12
inxi
[erwin@erwin-linncplusp1 ~]$ inxi -F
Host: erwin-linncplusp1 Kernel: 5.18.6-1-MANJARO arch: x86_64 bits: 64 Console: pty pts/1
Distro: Manjaro Linux
Type: Laptop System: LINCPLUS product: LINNCPLUS P1 v: N/A serial: <superuser required>
Mobo: weibu model: LINCPLUS serial: <superuser required> UEFI: American Megatrends
v: HW-13.3-BI-X133GRX231-043-D date: 04/25/2021
Battery:
ID-1: BAT0 charge: 34.2 Wh (100.0%) condition: 34.2/34.2 Wh (100.0%)
CPU:
Info: dual core model: Intel Celeron N4020 bits: 64 type: MCP cache: L2: 4 MiB
Speed (MHz): avg: 2694 min/max: 800/2800 cores: 1: 2686 2: 2703
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
Device-2: Realtek USB2.0 camera type: USB driver: uvcvideo
Display: server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2 driver: X: loaded: modesetting
gpu: i915 tty: 236x54 resolution: 1920x1080
Message: GL data unavailable in console. Try -G --display
Audio:
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: sof-audio-pci-intel-apl
Sound Server-1: ALSA v: k5.18.6-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: yes
Sound Server-3: PipeWire v: 0.3.52 running: yes
Network:
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter driver: rtw_8821ce
IF: wlp1s0 state: up mac: 24:18:c6:22:86:32
Bluetooth:
Device-1: Realtek Bluetooth Radio type: USB driver: btusb
Drives:
Local Storage: total: 176.9 GiB used: 12.51 GiB (7.1%)
ID-1: /dev/mmcblk0 vendor: BIWIN model: N/A size: 57.66 GiB
ID-2: /dev/sda vendor: Samsung model: MZNLN128HCGR-000H1 size: 119.24 GiB
Partition:
ID-1: / size: 56.16 GiB used: 12.51 GiB (22.3%) fs: ext4 dev: /dev/mmcblk0p2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat dev: /dev/mmcblk0p1
Swap:
Sensors:
System Temperatures: cpu: 77.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info:
Processes: 171 Uptime: 10m Memory: 3.65 GiB used: 2.09 GiB (57.1%) Init: systemd Shell: Bash
inxi: 3.3.19
Pactl
[erwin@erwin-linncplusp1 ~]$ pactl list sinks
Ziel #0
Status: SUSPENDED
Beschreibung: Celeron/Pentium Silver Processor High Definition Audio Stereo
Treiber: module-alsa-card.c
Abtastwert-Angabe: s16le 2ch 48000Hz
Kanalzuordnung: front-left,front-right
Besitzer-Modul: 6
Stumm: nein
Lautstärke: front-left: 63570 / 97% / -0,79 dB, front-right: 63570 / 97% / -0,79 dB
Verteilung 0,00
Basis-Lautstärke: 65536 / 100% / 0,00 dB
Quellen-Monitor: alsa_output.pci-0000_00_0e.0-platform-sof-essx8336.stereo-fallback.monitor
Latenz: 0 usec, eingestellt 0 usec
Flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY
Eigenschaften:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = ""
alsa.id = "ES8336 (*)"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
alsa.card_name = "sof-essx8336"
alsa.long_card_name = "weibu-LINNCPLUSP1-TobefilledbyO.E.M.-LINCPLUS"
alsa.driver_name = "snd_soc_sof_es8336"
device.bus_path = "pci-0000:00:0e.0-platform-sof-essx8336"
sysfs.path = "/devices/pci0000:00/0000:00:0e.0/sof-essx8336/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.vendor.name = "Intel Corporation"
device.product.id = "3198"
device.product.name = "Celeron/Pentium Silver Processor High Definition Audio"
device.string = "hw:0"
device.buffering.buffer_size = "65536"
device.buffering.fragment_size = "16384"
device.access_mode = "mmap+timer"
device.profile.name = "stereo-fallback"
device.profile.description = "Stereo"
device.description = "Celeron/Pentium Silver Processor High Definition Audio Stereo"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Ports:
analog-output-speaker: Speakers (Typ: Lautsprecher, Priorität: 10000, Verfügbarkeit unbekannt)
analog-output-headphones: Headphones (Typ: Kopfhörer, Priorität: 9900, Verfügbarkeitsgruppe: Legacy 1, nicht verfügbar)
Aktiver Port: analog-output-speaker
Formate:
pcm
Danke im Voraus
Nostradamus
Beitrag
von Nostradamus » Sonntag 26. Juni 2022, 14:04
Beiträge: 1557 Registriert: Freitag 26. Juni 2020, 18:53
Kernel: 6.8
Hat sich bedankt: 145 Mal
Danksagung erhalten: 252 Mal
Beitrag
von LaGGGer » Sonntag 26. Juni 2022, 15:48
Schreibfaul ?!
Beitrag
von Benutzer 1541 gelöscht » Sonntag 26. Juni 2022, 16:00
LaGGGer hat geschrieben: ↑ Sonntag 26. Juni 2022, 15:48 Schreibfaul ?!
Anscheinend, denn es gibt keine Angabe auf welchem Ausgang ( PC, Analog, HDMI, USB ...) er keinen Ton hört.
Er hat auch nicht geschrieben welche Einstellungsversuche in den "Systemeinstellungen -> Audio" er schon versucht hat.
Meine Glaskugel verweigert bei dieser Hitze auch ihren Dienst. Also können wir nur raten.
Beiträge: 975 Registriert: Freitag 22. Dezember 2017, 14:17
Hat sich bedankt: 21 Mal
Beitrag
von Daemon » Sonntag 26. Juni 2022, 16:41
Eigentlich hätte er das doch kommen sehen müssen das es nicht klappt nach der Installation.
Ne Spaß, schreib mal was dazu. Wo kommt kein Sound? Lautsprecher? Kopfhörer? Wie josefine_h schon geschrieben hat, über welchen Ausgang? Wird pulseaudio oder pipewire benutzt? So viele Fragen, und so wenig Antworten.
Was hast du bisher unternommen?
Nostradamus
Beitrag
von Nostradamus » Montag 27. Juni 2022, 17:36
Gar Kein Ausgang...
Ist Wohl laut google ein Kernel Problem mit Bay Trail
Bluetooth Funktioniert...
Hab jetzt Pop Os Draufgemacht...
Danke...
Bitte Closed...
Kernel: 6.8
Beitrag
von LaGGGer » Montag 27. Juni 2022, 18:54
Kann mich mal einer Aufklären was das hier jetzt war ?!
Sowas sinnfreies habe ich noch nie erlebt. Gibt anscheinend immer wieder neue Arten von Trollen.
country
Beiträge: 1118 Registriert: Samstag 16. Oktober 2021, 02:12
CPU: Ryzen 7 3700X
GPU: RTX 3060Ti
Kernel: up-to-date
GPU Treiber: RTX 3060Ti
Hat sich bedankt: 122 Mal
Danksagung erhalten: 227 Mal
Beitrag
von country » Montag 27. Juni 2022, 20:08
Nostradamus hat geschrieben: ↑ Sonntag 26. Juni 2022, 12:12
würde mal eins davon löschen zb. pacman -R PipeWire oder pacman -R PulseAudio
PS.
hab auch nur
Sound Server-1: ALSA v: k5.18.6-arch1-1 running: yes
Sound Server-2: PipeWire v: 0.3.52 running: yes
am laufen...
Edit: hier wird darüber diskutiert
https://github.com/thesofproject/linux/issues/3248
country
CPU: Ryzen 7 3700X
GPU: RTX 3060Ti
Kernel: up-to-date
Beitrag
von country » Mittwoch 29. Juni 2022, 22:05
Nostradamus hat geschrieben: ↑ Montag 27. Juni 2022, 17:36
Bitte Closed...
sorry da hat sich was getan, bin mir aber nicht sicher ob das zu deinem Problem passt - einfach mal probieren wenn du die Möglichkeit hast.
https://github.com/thesofproject/linux/ ... 1169564966
kannst ja mal berichten - andernfalls einfach ignorieren
Beitrag
von Benutzer 1541 gelöscht » Donnerstag 30. Juni 2022, 07:54
country hat geschrieben: ↑ Montag 27. Juni 2022, 20:08
PS.
hab auch nur
am laufen...
Bei mir laufen auch alle drei und es gibt keinerlei Probleme:
inxi -A  ✔
Audio:
Device-1: AMD SBx00 Azalia driver: snd_hda_intel
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
Device-3: C-Media Audio Device type: USB driver: snd-usb-audio
Kernel: 6.8
Beitrag
von LaGGGer » Donnerstag 30. Juni 2022, 09:30
Ähm Leute..
Ihr wisst schon das der TE jetz auf Pop OS umgestiegen ist und hier wahrscheinlich überhaupt nicht mehr mit ließt?
Außerdem hat er selbst den Beitrag geschlossen.... ich mein ja nur ...
Beitrag
von Benutzer 1541 gelöscht » Donnerstag 30. Juni 2022, 09:31
LaGGGer hat geschrieben: ↑ Donnerstag 30. Juni 2022, 09:30
Ähm Leute..
Beiträge: 2345 Registriert: Donnerstag 19. Mai 2016, 15:49
Kernel: 6.1
Hat sich bedankt: 28 Mal
Danksagung erhalten: 151 Mal
Beitrag
von Blueriver » Donnerstag 30. Juni 2022, 11:31
Ich schließe das Thema mal.
