ja springt an
Akku jetzt definitiv fällig?
- CPU: Ryzen 3 3200U
- GPU: Vega 3
- Kernel: 5.15.25-1
- Desktop-Variante: xfce/gnome
- GPU Treiber: open source driver for vega 3
- Hat sich bedankt: 63 Mal
- Danksagung erhalten: 3 Mal
Re: Akku jetzt definitiv fällig?
- GPU: Vega 3
- Kernel: 5.15.25-1
ich hab MODULES="amdgpu"
in die Zeile eingetragen und den weiteren Befehl von Dir eingeben:
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.105-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [filesystems]
==> Generating module dependencies
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qla1280
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> Starting build: 5.15.28-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux517.preset: 'default'
-> -k /boot/vmlinuz-5.17-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.17-x86_64.img
==> Starting build: 5.17.0-1-MANJARO
==> WARNING: Possibly missing firmware for module: xhci_pci
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.17-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux517.preset: 'fallback'
-> -k /boot/vmlinuz-5.17-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.17-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.17-x86_64-fallback.img
- CPU: Ryzen 7 3700X
- GPU: RTX 3060Ti
- Kernel: up-to-date
- Desktop-Variante: Cinnamon
- GPU Treiber: RTX 3060Ti
- Hat sich bedankt: 122 Mal
Nein,
MODULES=(amdgpu) kommt an die letzte Zeile der /etc/mkinitcpio.conf und dann abspeichern.
das andere wieder rückgängig machen..
dann
sudo mkinitcpio -P
dann Neustarten.
dann
sudo mkinitcpio -P
dann Neustarten.
- GPU: Vega 3
- Kernel: 5.15.25-1
also ich hab dich beim Wort genommen, das alte rückgängig gemacht, steht also wieder am Ende des 1. Absatzes MODULES="crc32c"
und in der letzten Zeile der gesamten Datei MODULES=(amdgpu)
Daraufhin die Ausgabe:
Neu gestartet.. und gings 2x ordnungsgemäß wie es sollte und ab dem dritten Mal gings dann wieder nicht.... hab ich die Einträge richtig gemacht?
- GPU: RTX 3060Ti
ja, sollte alles passenNutzer4354 hat geschrieben: ↑Mittwoch 6. April 2022, 21:02 ... hab ich die Einträge richtig gemacht?
seltsam ich hab momentan keine andere Idee was das sein kann. evtl wieder auf die anderen (5.17…) Kernel switchen. Vielleicht hat jemand anderes noch ne glühenden Idee.Nutzer4354 hat geschrieben: ↑Mittwoch 6. April 2022, 21:02 Neu gestartet.. und gings 2x ordnungsgemäß wie es sollte und ab dem dritten Mal gings dann wieder nicht.
- GPU: Vega 3
- Kernel: 5.15.25-1
trotzdem erst mal danke für Deinen Einsatz!
dann muss halt doch wahrscheinlich ein neuer Akku her und bis dahin heisst es immer runterfahren anstatt Bereitschaft.. Ruhezustand geht übrigens auch nicht... diese Option bekomme ich beim Menü für Herunterfahren usw. ja auch noch..
- GPU: Vega 3
- Kernel: 5.15.25-1
ich habe jetzt eine für mich akzeptable Lösung gefunden, bis ich einen neuen Akku habe.
ich habe herausgefunden, dass offenbar der Rechner aus der Bereitschaft ordnungsgemäss herauszuholen ist, WENN beim Versetzen in den Bereitschaftsmodus das Stromkabel drinsteckte!
Ich hatte zuerst versucht, beim Versetzen in die Bereitschaft das Stromkabel anzuschließen, dann während der Bereitschaftsphase das Kabel herauszustecken und wenn ich ihn aus der Bereitschaft heraushole, wieder das Kabel reinzustecken. Das hat dann geklappt.
Dann bin ich einen Schritt weiter gegangen und das Kabel nur beim Versetzen in die Bereitschaft reinzustecken, aber dann rauszustecken und auch beim Zurückholen aus der Bereitschaft das Kabel draussen zu lassen. Auch das geht... dann kommt auch der Rechner aus der Bereitschaft, obwohl das Kabel nicht drinsteckt.
Dh das Kabel muss nur drin stecken, wenn der Laptop in die Bereitschaft versetzt wird.
Gibt das irgendeinen Sinn? Ich habs 5x hintereinander probiert, es klappte immer.
Allerdings waren das nur 5-10 Sekunden. Wie es sich verhält, wenn ich ihn mal einige Minuten oder Stunden in Bereitschaft versetze, muss sich erweisen. Aber mit dieser Lösung kann ich jetz leben!
____________________
Bleibt nur noch die Frage nach dem Akku. Kann man den hier nehmen?
https://www.hplaptopakku.de/hp-17-ca121 ... z-akku.htm
- CPU: Intel Core i9-9900KF
- Kernel: 6.6 LTS
- Desktop-Variante: Gnome
- GPU Treiber: nVidia
- Hat sich bedankt: 19 Mal
hmmm... da glaube ich dann schon fast wieder nicht an ein zu schwachen/kaputten Akku...Nutzer4354 hat geschrieben: ↑Mittwoch 6. April 2022, 22:18 ...Dh das Kabel muss nur drin stecken, wenn der Laptop in die Bereitschaft versetzt wird.
Wenn du ohne Kabel per Konsole den Standby herbeiführst wacht er dann auch nicht auf?
systemctl suspend
- GPU: Vega 3
- Kernel: 5.15.25-1
hallo zompel,
hab es gerade ausprobiert. Ohne Kabel in den Bereitschaftsmodus mit dem Konsolenbefehl den du gepostet hast bewirkt, dass er nicht mehr herauskommt. Dh auch per Konsolenbefehl muss zwingend das Strom drin stecken, wenn man in in den Bereitschaftsmodus versetzt.
Merkwürdig ist eben, dass man es dann sofort rausstecken kann während er schläft und beim Aufwecken muss das Kabel auch nicht drinstecken.... umgekehrt würde es mehr Sinn machen, dass er beim Aufwecken mehr Leistung benötigt, um alles wieder ansprechen und aktivieren zu können.
Vielleichtl liegts ja doch nicht am Akku, und ihr findet noch die Lösung.
Aber die Tatsache, dass meine interne 1 TB HDD Festplatte ständig geklickt hat und Geräusche machte im Akkumodus und wenn das Stromkabel angeschlossen war, hörte man wirklich nur das Lesen und Schreiben der Platte, deutet doch eher wieder auf den Akku..
Das passt irgendwie alles nicht zusammen... Ich installiere die nächsten Tage mal nochmal Ubuntu und schaue, wie es sich da verhält.
Wenn nur noch nicht mehr kommt... hoffentlich ist da nicht noch mehr kaputt, weil durch das Aufmachen des Laptops jetzt auch die Garantie weg ist..
- GPU: Vega 3
- Kernel: 5.15.25-1
was mir auch gerade noch gekommen ist.. eine Idee
das Passwort, das man zur Anmeldung eingibt nach Einschalten des PCs dient doch nur dazu, den PC vor ort in der Wohnung vor fremdem physischem Zugriff zu schützen und hat doch in Bezug auf die Internet- bzw. Systemsicherheit keinerlei Relevanz, oder ?
Ich könnte einfach Manjaro so einstellen, dass er beim Drücken des Ein-/Ausschaltknopfes herunterfährt und ich ihn um ihn weiter zu nutzen einfach wieder anmache und er ohne Passwortabfrage dann automatisch wieder in den Desktop mündet und die Programme die ich sowieso viel gebrauche, automatisch geladen werden...
Hat das Passwort Relevanz in Bezug auf die Internet/Systemsicherheit nach außen hin? Meines Wissen doch nicht... ?
- Kernel: 6.6 LTS
Das ist richtig. Ich selbst benutze auch Autologin, weil ich die Passworteingabe bei jedem Systemstart etwas lästig finde und der einzige bin, der physischen Zugriff auf den Rechner hat.Nutzer4354 hat geschrieben: ↑Donnerstag 7. April 2022, 01:06 das Passwort, das man zur Anmeldung eingibt nach Einschalten des PCs dient doch nur dazu, den PC vor ort in der Wohnung vor fremdem physischem Zugriff zu schützen und hat doch in Bezug auf die Internet- bzw. Systemsicherheit keinerlei Relevanz, oder ?
Das merkwürdige ist, dass er beim Standby alles im RAM behält und nichts auf die Festplatte schreiben muss.hab es gerade ausprobiert. Ohne Kabel in den Bereitschaftsmodus mit dem Konsolenbefehl den du gepostet hast bewirkt, dass er nicht mehr herauskommt. Dh auch per Konsolenbefehl muss zwingend das Strom drin stecken, wenn man in in den Bereitschaftsmodus versetzt.
Mehrere Kernel hast du auch schon probiert, dann bliebe vielleicht noch das BIOS, aber dann bin ich auch schon am Ende mit den Ideen.
Hat halt den Nachteil das du beim Starten nicht zwischen X11 und Wayland wählen kannst ...
- Kernel: 6.6 LTS
@ josefine_h
Das stimmt natürlich.
Wobei beim proprietären nVidia Treiber unter Gnome, welchen ich nutze, Wayland offiziell sowieso noch nicht unterstützt wird.
@ Nutzer4354
Die aktuellste BIOS Version deines Notebooks (HP Notebook – 17-ca1216ng) kannst du hier herunterladen:
F.61 Rev.A (30. Jun. 2021)
oh... ich sehe gerade, dass es nur unter Windows ausgeführt werden kann... das ist ja ein schlechter Witz
@ Nutzer4354
- GPU: Vega 3
- Kernel: 5.15.25-1
Und eben auch bringt es den Nachteil mit sich, dass er automatisch immer den Desktop lädt, mit dem man sich zuletzt angemeldet hatte.josefine_h hat geschrieben: ↑Donnerstag 7. April 2022, 08:28 Hat halt den Nachteil das du beim Starten nicht zwischen X11 und Wayland wählen kannst ...
Ich arbeite ja mit zwei verschiedenen Desktopumgebungen und möchte das auch weiterhin tun, aber ich mache systembedingt wichtige Dinge nur auf dem Orginal-Desktop der Distro. Kleine Sachen wie Miniprogramme installieren, brennen usw. da seh ich drüber weg, aber bei den wichtigen Aufgaben vertraue ich einer zusätzlich installierten DE einfach nicht so recht. Wobei mir bei Manjaro jetzt so noch keine gravierenden Fehler aufgefallen sind mit meinem zusätzlich installierten Gnome, auf anderen Distros waren zusätzlich installierte DE hier und da schon mit Fehlern verbunden.
Ich kann halt ohne Gnome nicht leben aber ich bin ein Mensch der einfach die Abwechslung liebt und ab und an immer wieder mal einen Tapetenwechsel benötigt. Deshalb zwei Desktops :-)
Zuletzt geändert von Nutzer4354 am Donnerstag 7. April 2022, 16:34, insgesamt 1-mal geändert.
- GPU: Vega 3
- Kernel: 5.15.25-1
:-) Naja das an sich wäre nicht so das Problem, ich hab noch ein Windows 8 herumliegen, das ich kurz draufklatschen könnte.. ich hab ja genügend Festplattenabbilder von meinem Manjaro mittlerweile
ich arbeite seit vielen Jahren mit Festplattenabbildern und finde das eine tolle Sache. Ich probiere halt immer wieder neue Dinge aus, weil ich Linux mehr und mehr lernen will und da zerschist man hier und da scho so manches oder müllt das System zu und da ist es gut ein Abbild zu haben und dann alles wieder wie am Tag der Instalaltion zu haben. Ist eben doch besser als so Funktionen wie Timeshift.
Der einzige Nachteil ist eben, daß dabei die SSD unnötig belastet wird.
Jetzt aber zu dem Thema BIOS Update. Ich würde das schon grundsätzlich machen, aber ich hab in der Vergangenheit, dh in den letzten 10 Jahren schon 4 Updates diesbezüglich gemacht, außer 1x hat es nie irgendetwas gebracht. Und ein BIOS Update bringt ja immer auch die Gefahr mit sich, dass etwas schief läuft.
Deshalb nochmal zwei Fragen: Gibt es dazu irgendwelche Statistiken, wieviel % von den BIOS Updates die von Usern durchgeführt werden, effektiv am Ende schief liefen ?
Und zweite Frage: Wie hoch von der Wahrscheinlichkeit schätzt Du denn die Sache ein, dass ein BIOS Update hier in meinem Fall zum Erfolg führen wird ? eher wahrscheinlich oder eher unwahrscheinlich ? Ich glaube, dass das eher weniger wahrscheinlich sein wird.... aber ich hab von der Materie auch nicht so viel Ahnung wie Du / ihr.
Auf jeden Fall möchte ich allen ohne Ausnahme im Forum danken für die Beiträge und Hilfe, die ich bisher für alles bekommen habe!
