Quellephilm, post:1, topic:102594 hat geschrieben: Hello community,
Another **stable** branch update with some usual updates for you.
*Checkout our latest spin of [Cutefish](https://github.com/manjaro-cutefish/dow ... 2202070936)!*
* Most of our **Kernels** got updated
* **Cutefish** got updated to [0.7](https://forum.cutefishos.com/d/293-cute ... a-released)
* Some more **Deepin** packages got updated
* **Firefox** is now at [97.0](https://www.mozilla.org/en-US/firefox/9 ... easenotes/)
* **Maui** got renewed to [2.1.1](https://mauikit.org/blog/maui-2-1-1-release/)
* **systemd** drops cloudflare from fallback DNS servers
* The usual upstream updates including **Haskell** and **Python**
You may need to [rebuild any AUR packages] that install files to site-packages
You may need to rebuild any Python packages you’ve installed from the AUR. To get a list of them, you can run:
And to rebuild them all at once with an AUR helper such as `yay`, you can do:Code: Alles auswählen
pacman -Qoq /usr/lib/python3.9
But if any of the packages don’t work with Python 3.10 yet, this might fail halfway through and you’ll have to do rebuild the remaining ones one or a few at a time.Code: Alles auswählen
>yay -S $(pacman -Qoq /usr/lib/python3.9) --answerclean All
Get our latest daily developer images now from Github: [Plasma](https://github.com/manjaro-plasma/download/releases), [Gnome](https://github.com/manjaro-gnome/download/releases), [XFCE](https://github.com/manjaro-xfce/download/releases). You get the latest [stable releases](https://manjaro.org/download) of Manjaro from [CDN77](https://cdn77.com).
**Our current supported kernels**
* linux44 4.4.302 [EOL]
* linux49 4.9.299
* linux414 4.14.264
* linux419 4.19.227
* linux54 5.4.178
* linux510 5.10.98
* linux515 5.15.21
* linux516 5.16.7
* linux517 5.17-rc3
* linux515-rt 5.15.18_rt28
* linux516-rt 5.16.2_rt18
**Package Updates** (Wed Feb 9 08:02:28 CET 2022)
* stable community x86_64: 746 new and 760 removed package(s)
* stable core x86_64: 37 new and 37 removed package(s)
* stable extra x86_64: 145 new and 243 removed package(s)
* stable kde-unstable x86_64: 314 new and 314 removed package(s)
* stable multilib x86_64: 13 new and 13 removed package(s)
A detailed list of all package changes may be found here.
[Stable Update] 2022-02-14 - Kernels, Haskell, Cutefish 0.7, Deepin, Firefox, Maui 2.1.1, Systemd
Themen Author - Moderator
- Kernel: 6.1
- Hat sich bedankt: 28 Mal
- Erfahrenes Foren Mitglied
- CPU: 4 × Intel® Pentium® Silver N6000 @ 1.10GHz
- Kernel: ...always the newest
- Desktop-Variante: KDE-Plasma
- GPU Treiber: ...out of the box
- Hat sich bedankt: 4 Mal
- Danksagung erhalten: 14 Mal
Re: [Stable Update] 2022-02-14 - Kernels, Haskell, Cutefish 0.7, Deepin, Firefox, Maui 2.1.1, Systemd
Hatte keine Probleme, lief durch und ist wieder komplikationsfrei am letzten Stand...
regards jacl
regards jacl
Manjaro KDE, Liebe auf den ersten Klick ...
- Administrator
- CPU: Intel® Core™ i7-2630QM
- GPU: Intel UHD Graphics
- Kernel: 5.6
- Hat sich bedankt: 189 Mal
Alles supi durchgelaufen unter KDE.
Das Einzige was mir bislang unter XFCE negativ auffällt ist, das die Zeile
bei mir wieder mehrfach in Grub vorhanden ist. Das hatte ich in der Vergangenheit bereits schon einmal...
# Uncomment this option to enable os-prober execution in the grub-mkconfig command
GRUB_DISABLE_OS_PROBER=false
- CPU: Ryzen 7 3700X
- GPU: RTX 3060Ti
- Kernel: up-to-date
- Desktop-Variante: Cinnamon
- GPU Treiber: RTX 3060Ti
- Hat sich bedankt: 122 Mal
meinst du in /etc/default/grub ?Manfrago hat geschrieben: ↑Dienstag 15. Februar 2022, 16:51bei mir wieder mehrfach in Grub vorhanden ist.Code: Alles auswählen
# Uncomment this option to enable os-prober execution in the grub-mkconfig command GRUB_DISABLE_OS_PROBER=false
Wie sind die Dateirechte bei dir? bei mir siehst so aus:
ls /etc/default/grub
-rw-r--r-- 1 root root 2180 26. Jan 17:20 /etc/default/grub
Ja, in /etc/default/grub war der o.g. os-prober Eintrag nach dem Update 3-fach vorhanden. Das bemerke ich eigentlich nur, wenn ich ab und zu in die /etc/default/grub reinschaue. Obwohl ich nicht glaube, dass das etwas mit den Dateirechten zu tun haben könnte und weil deinem genannten ls-Befehl das -l fehlt, um auch die Rechte anzuzeigen, bringe ich hier mal eine etwas komfortablere Ansicht meiner Dateirechte.
getfacl -p /etc/default/grub
# file: /etc/default/grub
# owner: root
# group: root
user::rw-
group::r--
other::r--
- Neues Foren Mitglied
- CPU: Ryzen 7 4750G
- GPU: Radeon Vega Graphics
- Kernel: 5.16
- Desktop-Variante: DE
- GPU Treiber: Standard
ich habe das erste Mal Probleme mit einem Manjaro Update. Nach dem Start des Updates erhalte ich folgende Fehlermeldung:
- removing linux510-rt breaks dependency 'linux510-rt' required by linux-rt-lts-manjaro
- removing linux510-rt-r8168 breaks dependency 'linux510-rt-r8168' required by linux-rt-lts-manjaro-r8168
Ich selbst habe den Kernel 5.16.2-1-rt19-MANJARO installiert und aktiv und den Desktop XFCE im Einsatz.
Wie kann ich dieses Problem beseitigen? Bisher hatte ich keine Probleme mit den Updates, er lief alles geschmeidig.
Danke für Hilfe.
Danke für Hilfe.
- Kernel: 6.8
- Hat sich bedankt: 145 Mal
Versuchs mal den empfohlenen Kernel 5.15. Dieser ist Empfohlen. Muss jetzt nicht heißen das der 5.16 fehlerhaft ist, dennoch würde ich es erstmal mit dem 5.15er Kernel probieren und dann nochmal das Update anstoßen.
Zuletzt geändert von LaGGGer am Mittwoch 16. Februar 2022, 16:29, insgesamt 1-mal geändert.
Hm, eigentlich ist das Problem bereits etwas älter.
https://forum.manjaro.org/t/update-pack ... aro/101594
sudo pacman -Rdd linux-rt-lts-manjaro linux-rt-lts-manjaro-r8168
Das Problem des TE ist doch der inaktive 510er Kernel und nicht sein aktiver Kernel 5.16. Was soll der Kernel 5.15 nun bewirken?
- Kernel: 6.8
Das werden wir sehen wenn er es getestet hat oder ? Ich glaube nicht das er mit meinem Vorschlag sein System zerschießt
Oder hast du dazu auch noch was zu bemängeln?
Ich vermag in deinem Vorhaben einfach keinen logisch nachvollziehbaren Ansatz für die Problemlösung des TE zu erkennen.
- Kernel: 6.8
Tja, ich verstehe auch nicht immer alles, und ich muss auch nicht alles kommentieren.
Ok, lass gut sein, ich bin jetzt hier raus.
- Kernel: 5.16
danke für die schnelle Hilfe.
@Manfrago Dein geposteter Befehl war für mich und mein System die Lösung. Danach konnte ich den Update ohne Probleme durchführen lassen.
Danke auch an die anderen, die sich meinem Problem angenommen hatten.
