QuelleHello community,
Another **stable** branch update with some usual updates for you.
*Find out what is new in [LibreOffice 7.1 ](https://9to5linux.com/libreoffice-7-1-o ... -whats-new)! #stayhome, #staysafe, #stayhealthy*
* Most of the **Kernels** go updated
* A lot of effort went into **Gnome 40**
* Some **Deepin** packages got updated
* **Firefox** and **Thunderbird** got renewed: FF 85.0.1, TB 78.7.0
* **Systemd** is now at [247.3 ](https://github.com/systemd/systemd-stab ... 2...v247.3)
* **Nvidia** driver got updated to [460.39 ](https://forums.developer.nvidia.com/t/l ... ase/166842)
* **ZFS** is now updated to [2.0.2 ](https://github.com/openzfs/zfs/releases/tag/zfs-2.0.2)
* A new point-release of [KDE-Apps 20.12 ](https://kde.org/announcements/releases/ ... ps-update/) landed in our repos
* **AMDVLK** is now at [2021.Q1.2](https://github.com/GPUOpen-Drivers/AMDV ... -2021.Q1.2)
* **LibreOffice** got renewed to [7.0.4 ](https://blog.documentfoundation.org/blo ... ffice-704/) and [7.1.0 ](https://blog.documentfoundation.org/blo ... community/)
* **Mesa** is now at [20.3.4 ](https://docs.mesa3d.org/relnotes/20.3.4.html)
* Most of [LibRetro ](https://www.libretro.com/) got renewed
* Another [bug-fix release ](https://gstreamer.freedesktop.org/releases/1.18/#1.18.3) of **Gstreamer**
* **Virtualbox** is now at [6.1.18](https://www.virtualbox.org/wiki/Changelog-6.1#v18)
* Other regular upstream updates including **python** and **haskell**
Get our latest daily developer images now from Github: [Plasma ](https://github.com/manjaro-plasma/download/releases), [Gnome ](https://github.com/manjaro-gnome/download/releases), [XFCE ](https://github.com/manjaro-xfce/download/releases)
**Our current supported kernels**
* linux44 4.4.255
* linux49 4.9.255
* linux414 4.14.219
* linux419 4.19.173
* linux54 5.4.95
* linux59 5.9.16 [EOL]
* linux510 5.10.13
* linux511 5.11-rc6
* linux54-rt 5.4.93_rt51
* linux59-rt 5.9.1_rt19
**Packages Changes** (Sat Feb 6 10:58:24 CET 2021)
* stable community x86_64: 2056 new and 1933 removed package(s)
* stable core x86_64: 77 new and 78 removed package(s)
* stable extra x86_64: 1098 new and 1169 removed package(s)
* stable multilib x86_64: 52 new and 52 removed package(s)
A detailed list of all package changes can be found [here ](https://gitlab.manjaro.org/-/snippets/587/raw).
[Stable Update] 2021-02-09 - Kernels, Gnome 40-Alpha, KDE Apps 20.12.2, Systemd, Mesa, LibreOffice
Themen Author - Moderator
- Kernel: 6.12
- Hat sich bedankt: 32 Mal
- Kernel: 5.10
- GPU Treiber: Freier Treiber
- Hat sich bedankt: 46 Mal
- Danksagung erhalten: 51 Mal
Re: [Stable Update] 2021-02-09 - Kernels, Gnome 40-Alpha, KDE Apps 20.12.2, Systemd, Mesa, LibreOffice
bei mir gab es in der Tat Problemchen.
1. Das Update hat lange gedauert - denke das ich vielleicht nen anderen Server verwenden hätte sollen.
2. Telegram Desktop war verstellt , Nachtmodus ausgeschaltet , wiederholte Abfrage der Spracheinstellung, Thema verstellt
und das Taskleisten-Symbol hat sich verändert.
Alles kein Beinbruch - umgestellt fertig!
3. Firefox war seit dem letzten Update recht CPU intensiv. Das sieht nach Verbesserung aus, teste ich noch weiter.
Ansonsten alles bestens.
LG Sachse
LG Sachse
- Kernel: 6.12
Alles funktioniert wie es soll.
Hm, das XFCE Einstellungsmenü leidet nach wie vor unter Klaustophobie....
- Bildschirmfoto.png (20.78 KiB) 3954 mal betrachtet
System bootet erst nach Bedienung der Resettaste.
Soll bekunden, das Manjaro nicht mehr sauber runter fährt?
Um welche Desktop Variante geht es denn?
Manjaro 20.2.1, XFCE
Beim Betätigen des grünen Ausschaltbuttons erscheint keine mögliche Auswahl "Abmelden, Neustart, Herunterfahren usw., das System fährt sofort runter, hängt aber vermutlich mit schwarzen Bildschirm fest. Nur die Resettaste bringt den Neustart. Habe versuchsweise neu installiert, dierekt nach der Neuinstallation die Updates eingespielt. Gleicher Effekt.
Schaue mal bitte in der Einstellungsverwaltung nach, ob bei -> [Sitzung und Startverhalten]->[Vor dem Abmelden nachfragen] der Haken noch gesetzt ist.
Ja, der Haken war gesetzt. Mir ist noch aufgefallen, dass ich nach dem Update beim Öffnen der .xsessions.errors eine Meldung siehe Anhang bekomme, war bisher auch noch nicht.
Also: Mir stellt sich das so dar, als hättest du das Update vom 30.12.20 ausgelassen und das heutige Update da drübergebügelt. Für deine darauf folgende Neuinstallation hast du dann höchstwahrscheinlich auch ein Installationsmedium von vor dem 30.12.20 genutzt. Könnte das so gewesen sein?
Die Installations-Iso war die vom 03.01.21. Alle Updates waren installiert.
Und es tritt der gleiche Fehler wieder auf? Liegt dein Userverzeichnis auf einer separaten Partition?
- Kernel: 6.12
Ich habe das Problem nicht, bei ist es wie es sein sollte.
Hast du es mal mit deinstallieren des xfce4-settings
sudo pacman -R xfce4-settings
sudo pacman -S xfce4-settings
Danach musst du warscheinlich deine Favoritenliste neu erstellen.
Das brauchte ich nicht, aber gebracht hat es auch nichts. Ich werde mir das nachher mal auf anderen Laptops mit unterschiedlichen Bildschirmauflösungen anschauen, eventuell liegt es ja daran.
- GPU: Intel HD Graphics 620
- Kernel: 6.6
- Desktop-Variante: Xfce; Labwc
- Hat sich bedankt: 8 Mal
Ich bekam nach dem Update keine Verbindung mehr zu meinen Localhost. Offenbar ein Problem mit dem PHP-Modul:
Mit dem Wechsel auf die PHP-Version 8 ist, wie sich zeigte, die Moduldatei libphp7.so in libphp.so umbenannt worden. Mit einer entsprechenden Anpassung der einschlägigen Zeilen in der /etc/httpd/conf/httpd.conf konnte ich das Problem beheben:
(Anschließend httpd neu starten: systemctl restart httpd)
~ $ apachectl configtest
httpd: Syntax error on line 34 of /etc/httpd/conf/httpd.conf: Cannot load modules/libphp7.so into server: /etc/httpd/modules/libphp7.so: cannot open shared object file: No such file or directory
LoadModule php_module modules/libphp.so
AddHandler php-script .php
Include conf/extra/php_module.conf
