2019-11-08 - Kernels, Pamac, Plasma, Mesa, KDE Apps (Testing Update)
Hatte keine Probleme.
3
100%
0
Keine Stimmen
0
Keine Stimmen
Insgesamt abgegebene Stimmen: 3
Kernel: 6.1
Hat sich bedankt: 28 Mal
Danksagung erhalten: 149 Mal
Hello community,
I am happy to announce another Testing Update.
With this we have rebuilt most of our kernels with extramodules and ship the latest packages of KDE-Plasma 5.17.3. Pamac got some needed fixes.
Some feature-updates:
Plasma is now at 5.17.3
Apps are at 19.08.3
Thunderbird got some needed fixes in 68.2.2
The bi-weekly Mesa update 19.2.3 brings some fixes and stabilizations
The usual upstream fixes and updates
If you like following latest Plasma development you may also like to check out our current version of mnjaro-kde-vanilla , which we build on a regular basis against kde-git master packages.
As always we appreciate your input and feedback for the updates.
Our current supported kernels:
linux316 3.16.75
linux44 4.4.199
linux49 4.9.199
linux414 4.14.152
linux419 4.19.82
linux52 5.2.21 [EOL] (no catalyst module!)
linux53 5.3.9 (no catalyst module!)
linux54 5.4.0-rc5 (not all modules build yet!)
linux419-rt 4.19.72_rt26
linux52-rt 5.2.21_rt13
Quelle
linuxkumpel
Kernel: 5.15 / 6.0
GPU Treiber: Intel i915
Hat sich bedankt: 15 Mal
Danksagung erhalten: 36 Mal
Re: 2019-11-08 - Kernels, Pamac, Plasma, Mesa, KDE Apps (Testing Update)
Beitrag von linuxkumpel »
Bei mir alles bestens gelaufen.
Kernel: 6.1
Ohne Probleme! :)
Hat sich bedankt: 189 Mal
Danksagung erhalten: 142 Mal
Unter MATE alles gut. ;)
Zurück zu „|Testing Releases|“
