so (mit sudo vorangestellt) klappt's besser mit "nvme list" :
Node Generic SN Model Namespace Usage Format FW Rev
/dev/nvme0n1 /dev/ng0n1 S675NX1T372539 SAMSUNG MZVL2512HCJQ-00B00 0x1 511.49 GB / 512.11 GB 512 B + 0 B GXA7601Q
NVME Identify Controller:
vid : 0x144d
ssvid : 0x144d
sn : S675NX1T372539
mn : SAMSUNG MZVL2512HCJQ-00B00
fr : GXA7601Q
rab : 2
ieee : 002538
cmic : 0
[3:3] : 0 ANA not supported
[2:2] : 0 PCI
[1:1] : 0 Single Controller
[0:0] : 0 Single Port
mdts : 7
cntlid : 0x6
ver : 0x10300
rtd3r : 0x30d40
rtd3e : 0x989680
oaes : 0x200
[31:31] : 0 Discovery Log Change Notice Not Supported
[27:27] : 0 Zone Descriptor Changed Notices Not Supported
[15:15] : 0 Normal NSS Shutdown Event Not Supported
[14:14] : 0 Endurance Group Event Aggregate Log Page Change Notice Not Supported
[13:13] : 0 LBA Status Information Notices Not Supported
[12:12] : 0 Predictable Latency Event Aggregate Log Change Notices Not Supported
[11:11] : 0 Asymmetric Namespace Access Change Notices Not Supported
[9:9] : 0x1 Firmware Activation Notices Supported
[8:8] : 0 Namespace Attribute Changed Event Not Supported
ctratt : 0x10
[19:19] : 0 Flexible Data Placement Not Supported
[17:17] : 0 HMB Restrict Non-Operational Power State Access Not Supported
[16:16] : 0 MDTS and Size Limits Exclude Metadata Not Supported
[15:15] : 0 Extended LBA Formats Not Supported
[14:14] : 0 Delete NVM Set Not Supported
[13:13] : 0 Delete Endurance Group Not Supported
[12:12] : 0 Variable Capacity Management Not Supported
[11:11] : 0 Fixed Capacity Management Not Supported
[10:10] : 0 Multi Domain Subsystem Not Supported
[9:9] : 0 UUID List Not Supported
[8:8] : 0 SQ Associations Not Supported
[7:7] : 0 Namespace Granularity Not Supported
[6:6] : 0 Traffic Based Keep Alive Not Supported
[5:5] : 0 Predictable Latency Mode Not Supported
[4:4] : 0x1 Endurance Groups Supported
[3:3] : 0 Read Recovery Levels Not Supported
[2:2] : 0 NVM Sets Not Supported
[1:1] : 0 Non-Operational Power State Permissive Not Supported
[0:0] : 0 128-bit Host Identifier Not Supported
rrls : 0
cntrltype : 0
[7:2] : 0 Reserved
[1:0] : 0 Controller type not reported
fguid : 00000000-0000-0000-0000-000000000000
crdt1 : 0
crdt2 : 0
crdt3 : 0
nvmsr : 0
[1:1] : 0 NVM subsystem Not part of an Enclosure
[0:0] : 0 NVM subsystem Not part of a Storage Device
vwci : 0
[7:7] : 0 VPD Write Cycles Remaining field is Not valid.
[6:0] : 0 VPD Write Cycles Remaining
mec : 0
[1:1] : 0 NVM subsystem Not contains a Management Endpoint on a PCIe port
[0:0] : 0 NVM subsystem Not contains a Management Endpoint on an SMBus/I2C port
oacs : 0x17
[10:10] : 0 Lockdown Command and Feature Not Supported
[9:9] : 0 Get LBA Status Capability Not Supported
[8:8] : 0 Doorbell Buffer Config Not Supported
[7:7] : 0 Virtualization Management Not Supported
[6:6] : 0 NVMe-MI Send and Receive Not Supported
[5:5] : 0 Directives Not Supported
[4:4] : 0x1 Device Self-test Supported
[3:3] : 0 NS Management and Attachment Not Supported
[2:2] : 0x1 FW Commit and Download Supported
[1:1] : 0x1 Format NVM Supported
[0:0] : 0x1 Security Send and Receive Supported
acl : 7
aerl : 3
frmw : 0x16
[5:5] : 0 Multiple FW or Boot Update Detection Not Supported
[4:4] : 0x1 Firmware Activate Without Reset Supported
[3:1] : 0x3 Number of Firmware Slots
[0:0] : 0 Firmware Slot 1 Read/Write
lpa : 0xe
[6:6] : 0 Telemetry Log Data Area 4 Not Supported
[5:5] : 0 LID 0x0, Scope of each command in LID 0x5, 0x12, 0x13 Not Supported
[4:4] : 0 Persistent Event log Not Supported
[3:3] : 0x1 Telemetry host/controller initiated log page Supported
[2:2] : 0x1 Extended data for Get Log Page Supported
[1:1] : 0x1 Command Effects Log Page Supported
[0:0] : 0 SMART/Health Log Page per NS Not Supported
elpe : 63
[7:0] : 63 (0's based) Error Log Page Entries (ELPE)
npss : 4
[7:0] : 4 (0's based) Number of Power States Support (NPSS)
avscc : 0x1
[0:0] : 0x1 Admin Vendor Specific Commands uses NVMe Format
apsta : 0x1
[0:0] : 0x1 Autonomous Power State Transitions Supported
wctemp : 354
[15:0] : 81 °C (354 K) Warning Composite Temperature Threshold (WCTEMP)
cctemp : 358
[15:0] : 85 °C (358 K) Critical Composite Temperature Threshold (CCTEMP)
mtfa : 0
hmpre : 0
hmmin : 0
tnvmcap : 512.110.190.592
[127:0] : 512.110.190.592
Total NVM Capacity (TNVMCAP)
unvmcap : 0
[127:0] : 0
Unallocated NVM Capacity (UNVMCAP)
rpmbs : 0
[31:24]: 0 Access Size
[23:16]: 0 Total Size
[5:3] : 0 Authentication Method
[2:0] : 0 Number of RPMB Units
edstt : 35
dsto : 0
fwug : 0
kas : 0
hctma : 0x1
[0:0] : 0x1 Host Controlled Thermal Management Supported
mntmt : 318
[15:0] : 45 °C (318 K) Minimum Thermal Management Temperature (MNTMT)
mxtmt : 356
[15:0] : 83 °C (356 K) Maximum Thermal Management Temperature (MXTMT)
sanicap : 0x2
[31:30] : 0 Additional media modification after sanitize operation completes successfully is not defined
[29:29] : 0 No-Deallocate After Sanitize bit in Sanitize command Supported
[2:2] : 0 Overwrite Sanitize Operation Not Supported
[1:1] : 0x1 Block Erase Sanitize Operation Supported
[0:0] : 0 Crypto Erase Sanitize Operation Not Supported
hmminds : 0
hmmaxd : 0
nsetidmax : 0
endgidmax : 1
anatt : 0
anacap : 0
[7:7] : 0 Non-zero group ID Not Supported
[6:6] : 0 Group ID does change
[4:4] : 0 ANA Change state Not Supported
[3:3] : 0 ANA Persistent Loss state Not Supported
[2:2] : 0 ANA Inaccessible state Not Supported
[1:1] : 0 ANA Non-optimized state Not Supported
[0:0] : 0 ANA Optimized state Not Supported
anagrpmax : 0
nanagrpid : 0
pels : 0
domainid : 0
megcap : 0
sqes : 0x66
[7:4] : 0x6 Max SQ Entry Size (64)
[3:0] : 0x6 Min SQ Entry Size (64)
cqes : 0x44
[7:4] : 0x4 Max CQ Entry Size (16)
[3:0] : 0x4 Min CQ Entry Size (16)
maxcmd : 256
nn : 1
oncs : 0x57
[10:10] : 0 All Fast Copy Not Supported
[9:9] : 0 Copy Single Atomicity Not Supported
[8:8] : 0 Copy Not Supported
[7:7] : 0 Verify Not Supported
[6:6] : 0x1 Timestamp Supported
[5:5] : 0 Reservations Not Supported
[4:4] : 0x1 Save and Select Supported
[3:3] : 0 Write Zeroes Not Supported
[2:2] : 0x1 Data Set Management Supported
[1:1] : 0x1 Write Uncorrectable Supported
[0:0] : 0x1 Compare Supported
fuses : 0
[0:0] : 0 Fused Compare and Write Not Supported
fna : 0
[3:3] : 0 Format NVM Broadcast NSID (FFFFFFFFh) Supported
[2:2] : 0 Crypto Erase Not Supported as part of Secure Erase
[1:1] : 0 Crypto Erase Applies to Single Namespace(s)
[0:0] : 0 Format Applies to Single Namespace(s)
vwc : 0x7
[2:1] : 0x3 The Flush command supports NSID set to FFFFFFFFh
[0:0] : 0x1 Volatile Write Cache Present
awun : 1023
awupf : 0
icsvscc : 1
[0:0] : 0x1 NVM Vendor Specific Commands uses NVMe Format
nwpc : 0
[2:2] : 0 Permanent Write Protect Not Supported
[1:1] : 0 Write Protect Until Power Supply Not Supported
[0:0] : 0 No Write Protect and Write Protect Namespace Not Supported
acwu : 0
ocfs : 0
[3:3] : 0 Controller Copy Format 3h Not Supported
[2:2] : 0 Controller Copy Format 2h Not Supported
[1:1] : 0 Controller Copy Format 1h Not Supported
[0:0] : 0 Controller Copy Format 0h Not Supported
sgls : 0
[15:8] : 0 SGL Descriptor Threshold
[1:0] : 0 Scatter-Gather Lists Not Supported
mnan : 0
maxdna : 0
maxcna : 0
oaqd : 0
subnqn : nqn.1994-11.com.samsung:nvme:PM9A1:M.2:S675NX1T372539
ioccsz : 0
iorcsz : 0
icdoff : 0
fcatt : 0
[0:0] : 0 Dynamic Controller Model
msdbd : 0
ofcs : 0
[0:0] : 0 Disconnect command Not Supported
ps 0 : mp:8.37W operational enlat:0 exlat:0 rrt:0 rrl:0
rwt:0 rwl:0 idle_power:- active_power:-
active_power_workload:-
ps 1 : mp:8.37W operational enlat:0 exlat:200 rrt:1 rrl:1
rwt:1 rwl:1 idle_power:- active_power:-
ps 2 : mp:8.37W operational enlat:0 exlat:200 rrt:2 rrl:2
rwt:2 rwl:2 idle_power:- active_power:-
ps 3 : mp:0.0500W non-operational enlat:2000 exlat:1200 rrt:3 rrl:3
rwt:3 rwl:3 idle_power:- active_power:-
ps 4 : mp:0.0050W non-operational enlat:500 exlat:9500 rrt:4 rrl:4
rwt:4 rwl:4 idle_power:- active_power:-
Sudo wirkt / hält normalerweise doch länger, imho ~15 Minuten ?
