WLAN Verbindung bricht ab
Roberto
CPU: Intel Core i5 M 540
Kernel: 5.6.1-artix1-1 x86_64
Beitrag von Roberto »
Hallo liebe Gemeinde,
ich hoffe, dass mein Thema/Problem hier richtig aufgehoben ist.
Seit einigen Tagen habe ich das Problem, dass meine WLAN Verbindung ständig abbricht.
Hier zunächst meine Konfiguration:
System:    Host: Asus Kernel: 4.7.1-1-MANJARO x86_64 (64 bit) Desktop: KDE Plasma 5.7.3 Distro: Manjaro Linux
Machine:   System: ASUSTeK (portable) product: X550CC v: 1.0
           Mobo: ASUSTeK model: X550CC v: 1.0 Bios: American Megatrends v: X550CC.214 date: 07/19/2013
Battery    BAT0: charge: 13.8 Wh 38.4% condition: 35.9/44.6 Wh (81%)
CPU:       Dual core Intel Core i3-3217U (-HT-MCP-) cache: 3072 KB
           clock speeds: max: 1800 MHz 1: 824 MHz 2: 1187 MHz 3: 967 MHz 4: 918 MHz
Graphics:  Card-1: Intel 3rd Gen Core processor Graphics Controller
           Card-2: NVIDIA GK208M [GeForce GT 720M]
           Display Server: X.Org 1.17.4 driver: intel Resolution: 1366x768@60.05hz
           GLX Renderer: Mesa DRI Intel Ivybridge Mobile GLX Version: 3.0 Mesa 12.0.1
Audio:     Card Intel 7 Series/C210 Series Family High Definition Audio Controller driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.7.1-1-MANJARO
Network:   Card-1: Qualcomm Atheros AR9485 Wireless Network Adapter driver: ath9k
           IF: wlp3s0 state: up mac: 48:d2:24:45:17:54
           Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8168
           IF: enp4s0f2 state: down mac: ac:22:0b:b8:d1:72
Drives:    HDD Total Size: 242.1GB (8.1% used) ID-1: /dev/sda model: SanDisk_SDSSDHII size: 240.1GB
           ID-2: USB /dev/sdb model: USB_2.0_FD size: 2.1GB
Partition: ID-1: / size: 29G used: 12G (43%) fs: ext4 dev: /dev/sda2
           ID-2: /boot size: 247M used: 107M (46%) fs: ext2 dev: /dev/sda1
           ID-3: /home size: 186G used: 1.4G (1%) fs: ext4 dev: /dev/sda3
           ID-4: swap-1 size: 6.14GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 52.0C mobo: N/A
           Fan Speeds (in rpm): cpu: 2500
Info:      Processes: 189 Uptime: 1:06 Memory: 1465.0/5858.3MB Client: Shell (bash) inxi: 2.3.0
Zunächst hatte ich die Vermutung, dass ein simples Problem mit meinem lokalen Internetprovider besteht. Daraufhin habe ich mehrere Speedtests durchgeführt. Die waren alle im grünen Bereich.
Das Problem äußerst sich vielfältig.
Zum Einen bekomme ich bei updates neuerdings oft die Meldung "Operation too slow" und der Server wird dann oft gewechselt. Diese Situation kenne ich nicht. Ich habe in der pacman-mirrors.conf "OnlyCountry = Germany" eingestellt. Das machte bisher überhaupt keine Probleme.
Dann wird immer wieder die drahtlose Schnittstelle (wlp3s0) beendet und neu gestartet. Downloads dauern ewig lange. bzw. brechen ganz ab.
Seltsamerweise habe ich die Problem mit meinem anderen Notebook, einem alten Lenovo T61 nicht. Auf beiden Geräten läuft KDE 16.06. Auf dem Asus branch testing und auf dem Lenovo stable.
Außerdem habe ich über die fstab einen Router mit NAS Funktion (Asus RT-N65U) eingebunden. Auch hier habe ich seitdem den Eindruck, dass der Datenaustausch deutlich langsamer geworden ist. Wenn ich z. B. per SUSE Studio Imagewriter 1.10 eine ISO auf einen USB Stick schreiben will, dauert das neuerdings fast 30 Minuten.
Natürlich habe ich keine Veränderung an meiner Konfiguration vorgenommen  O:-)
Hat jemand irgendeine Idee, was hier schief gelaufen sein könnte?
Vielen Dank im Voraus
Roberto
Prinz
Re: WLAN Verbindung bricht ab
Beitrag von Prinz »
Wie alt ist Dein Notebook?
Roberto
Ich habe das Notebook 2013 neu gekauft. Das Lenovo ist deutlich älter  O:-)
Kernel: 6.1
Hat sich bedankt: 28 Mal
Danksagung erhalten: 151 Mal
Hallo Roberto,
das Problem hatte ich auch mal.
Bei mir hatte sich die WLAN Karte etwas gelöst.
Du kannst im Terminal  die Logaktivitäten mitlaufen lassen.
journalctl -f
Sobald deine Verbindung abbricht kannst du es entsprechend hier im Codeblock posten.
Desweiteren kannst du ja mal den Kernel 4.4 probieren, vielleicht geht es damit wieder besser.
Kernel: 4.20
Roberto
So, ich habe die Logaktivitäten mal mitlaufen lassen und habe folgenden Auszug:
Hier kommt dann der Ausfall:
Aug 23 13:45:20 Asus ntpd[2357]: bind(24) AF_INET6 fe80::89ba:6d3e:4f17:ab56%3#123 flags 0x11 failed: Cannot assign requested address
Aug 23 13:45:20 Asus ntpd[2357]: unable to create socket on wlp3s0 (6) for fe80::89ba:6d3e:4f17:ab56%3#123
Aug 23 13:45:20 Asus ntpd[2357]: failed to init interface for address fe80::89ba:6d3e:4f17:ab56%3
Aug 23 13:45:21 Asus avahi-daemon[423]: Joining mDNS multicast group on interface wlp3s0.IPv6 with address fe80::89ba:6d3e:4f17:ab56.
Aug 23 13:45:21 Asus avahi-daemon[423]: New relevant interface wlp3s0.IPv6 for mDNS.
Aug 23 13:45:21 Asus avahi-daemon[423]: Registering new address record for fe80::89ba:6d3e:4f17:ab56 on wlp3s0.*.
Aug 23 13:48:58 Asus plasmashell[813]:  New Notification:  "Mäusenetz" "Die Verbindung Mäusenetz wurde deaktiviert." -1 & Part of: 0
Aug 23 13:48:58 Asus plasmashell[813]: file:///usr/lib/qt/qml/QtQuick/Controls/Button.qml:100: TypeError: Cannot read property of null
Aug 23 13:48:58 Asus akonadi_imap_resource[1289]: log_kimap: Connection to server lost  3
Aug 23 13:48:58 Asus kwin_x11[777]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 37399, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Aug 23 13:48:59 Asus kwin_x11[777]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 37827, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Aug 23 13:48:59 Asus kwin_x11[777]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 37828, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Aug 23 13:49:05 Asus wpa_supplicant[537]: wlp3s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Aug 23 13:49:22 Asus NetworkManager[486]: <warn>  [1471952962.7569] device (wlp3s0): Activation: (wifi) association took too long, failing activation
Aug 23 13:49:22 Asus NetworkManager[486]: <info>  [1471952962.7569] device (wlp3s0): state change: config -> failed (reason 'ssid-not-found') [50 120 53]
Aug 23 13:49:22 Asus NetworkManager[486]: <info>  [1471952962.7572] manager: NetworkManager state is now DISCONNECTED
Aug 23 13:49:22 Asus kernel: IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
Aug 23 13:49:22 Asus NetworkManager[486]: <warn>  [1471952962.7583] device (wlp3s0): Activation: failed for connection 'Mäusenetz'
Aug 23 13:49:22 Asus NetworkManager[486]: <info>  [1471952962.7586] device (wlp3s0): supplicant interface state: scanning -> disconnected
Aug 23 13:49:22 Asus NetworkManager[486]: <info>  [1471952962.7590] device (wlp3s0): state change: failed -> disconnected (reason 'none') [120 30 0]
Aug 23 13:49:22 Asus akonadi_ical_resource[1288]: "Keine derartige Schnittstelle »org.freedesktop.DBus.Properties« des Objekts im Pfad /org/freedesktop/NetworkManager/ActiveConnection/3"
Aug 23 13:49:22 Asus akonadi_imap_resource[1289]: "Keine derartige Schnittstelle »org.freedesktop.DBus.Properties« des Objekts im Pfad /org/freedesktop/NetworkManager/ActiveConnection/3"
Aug 23 13:49:22 Asus kdeinit5[730]: "Keine derartige Schnittstelle »org.freedesktop.DBus.Properties« des Objekts im Pfad /org/freedesktop/NetworkManager/ActiveConnection/3"
Aug 23 13:49:22 Asus kdeconnectd[783]: "Keine derartige Schnittstelle »org.freedesktop.DBus.Properties« des Objekts im Pfad /org/freedesktop/NetworkManager/ActiveConnection/3"
Aug 23 13:49:22 Asus kmail[1693]: "Keine derartige Schnittstelle »org.freedesktop.DBus.Properties« des Objekts im Pfad /org/freedesktop/NetworkManager/ActiveConnection/3"
Aug 23 13:49:22 Asus kdeconnectd[783]: kdeconnect.core: Broadcasting identity packet
Aug 23 13:49:22 Asus akonadi_sendlater_agent[1301]: "Keine derartige Schnittstelle »org.freedesktop.DBus.Properties« des Objekts im Pfad /org/freedesktop/NetworkManager/ActiveConnection/3"
Aug 23 13:49:22 Asus akonadi_maildispatcher_agent[1293]: "Keine derartige Schnittstelle »org.freedesktop.DBus.Properties« des Objekts im Pfad /org/freedesktop/NetworkManager/ActiveConnection/3"
Aug 23 13:49:22 Asus akonadi_followupreminder_agent[1287]: "Keine derartige Schnittstelle »org.freedesktop.DBus.Properties« des Objekts im Pfad /org/freedesktop/NetworkManager/ActiveConnection/3"
Aug 23 13:49:22 Asus plasmashell[813]: file:///usr/lib/qt/qml/QtQuick/Controls/Button.qml:100: TypeError: Cannot read property of null
Aug 23 13:49:22 Asus plasmashell[813]: Currrent active notifications: QHash()
Aug 23 13:49:22 Asus plasmashell[813]: Guessing partOf as: 0
Aug 23 13:49:22 Asus plasmashell[813]:  New Notification:  "Drahtlose Schnittstelle (wlp3s0)" "Das WiFi-Netzwerk wurde nicht gefunden" -1 & Part of: 0
Aug 23 13:49:23 Asus plasmashell[813]: Currrent active notifications: QHash(("notification 9", "NetzwerkverwaltungDrahtlose Schnittstelle (wlp3s0)"))
Aug 23 13:49:23 Asus plasmashell[813]: Guessing partOf as: 0
Aug 23 13:49:23 Asus plasmashell[813]:  New Notification:  "Mäusenetz" "Die Verbindung Mäusenetz wurde deaktiviert." -1 & Part of: 0
Aug 23 13:49:23 Asus kwin_x11[777]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53018, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Aug 23 13:49:23 Asus kwin_x11[777]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53433, resource id: 0, major code: 14 (GetGeometry), minor code: 0
LuMI
Beitrag von LuMI »
[quote="Roberto"]
Roberto
Hin und wieder hilft die Geräte anders zu positionieren.
Kannst du externe Störung (Nachbarn die am gleichen Kanal "funken") ausschließen?
https://blog.saddey.net/2007/07/08/wlan ... -die-pest/
Roberto
Hallo Lumi,
eine externe Störung kann ich ausschließen, da ich meinen Router manuell auf Kanal 1 konfiguriert habe.
Die Position kann ich auch mal testen, aber wie gesagt, mit dem T61 habe ich im gleichen Funknetz keine Probleme.
Prinz
Beitrag von Prinz »
Ich fragte nach dem Alter,
weil die WLAN-Karten im Dauerbetrieb schon nach 2 Jahren ausgelutscht sein "können" (aber nicht müssen)!
Möglichkeiten
1.) Router auf den stärksten WLAN-Kanal stellen
2.) Lose WLAN-Karte (thermisch nichts besonderes gerade im Sommer )
3.) WLAN-Karte am Lebensende
4.) Keine, "ich wiederhole keine" Aluhütte im WLAN-Haushalt tragen!!!
Sollte es Punkt 3 sein schreib mir welches WLAN-Modul Du verbaut hast, habe vielleicht das passende hier.
GypsyWolve
Beitrag von GypsyWolve »
[quote="Prinz"]
Wie warum das?
GW
Roberto
Ich habe jetzt mal mit LinSSID meine Funknachbarschaft untersucht und dann auf Kanal 3 eingestellt. Auch wenn das ein evtl. überlappender Kanal ist, ist dort niemand unterwegs.
Lt. wavemon habe ich eine Verbindungsqualität von ca. 80%.
Ansonsten ist bei mir eine Atheros AR9485 verbaut. Bis jetzt habe ich mein Notebook noch nicht zerlegt, um den Sitz zu kontrollieren.
Das muss ich dann mal in Ruhe machen, bevor ich mein Gerät zerstöre :(
Zuletzt geändert von Roberto am Mittwoch 24. August 2016, 11:05, insgesamt 1-mal geändert.
Prinz
Beitrag von Prinz »
Na das hört sich doch mal gut an!
Das beste WLAN ist das WLAN ohne W  >:D >:D >:D
GypsyWolve
Passt zwar nicht so ganz, aber noch besser finde ich die BT Ohrstoepsel....................oder BT im Alllgemeinen
Nur wenn es ein modul ist, was soll denn dann da wackeln? Nehme mal an es ist mit Schraube fixiert.
@Roberto
Warum kein Kabel?
GW
Roberto
Lt. einem youtube Video ist es ein Steckmodul (siehe Foto).  Ob es allerdings mit 2 Schrauben fixiert ist, kann ich nicht sagen.
Mein PC in meinem Arbeitszimmer ist verkabelt, aber die anderen mobilen Geräte per WLAN verbunden.
Ich habe nicht gerne Kabel durch meine Bude liegen ;)
[Die Dateierweiterung wurde deaktiviert und kann nicht länger angezeigt werden.]
