Akonadi Dienst arbeitet nicht richtig
- CPU: Rysen 7
- GPU: GeForce GT 710
- Kernel: 6.3.5
- GPU Treiber: k.A.
- Hat sich bedankt: 8 Mal
Hallo Forum,
nach dem letzten update vor ein paar Tage geht der Korganizer nicht mehr siehe Fotos.
Habe schon mal gegoogelt aber bringt mich nicht weiter.
Akonadi Selftest gemacht aber kann damit nichts anfangen ihr seht da bestimmt mehr wie ich.
Hier der test:
Akonadi Server Self-Test Report===============================
Test 1: SUCCESS
Database driver found.
Details: The QtSQL driver 'QMYSQL' is required by your current Akonadi server configuration and was found on your system.
File content of '/home/ulf/.config/akonadi/akonadiserverrc':
[%General]
Driver=QMYSQL
[QMYSQL]
Host=
Name=akonadi
Options="UNIX_SOCKET=/run/user/1000/akonadi/mysql.socket"
ServerPath=/usr/bin/mysqld
StartServer=true
Test 2: SUCCESS
Akonadi is not running as root
Details: Akonadi is not running as a root/administrator user, which is the recommended setup for a secure system.
Test 3: SUCCESS
MySQL server found.
Details: You have currently configured Akonadi to use the MySQL server '/usr/bin/mysqld'.
Make sure you have the MySQL server installed, set the correct path and ensure you have the necessary read and execution rights on the server executable. The server executable is typically called 'mysqld'; its location varies depending on the distribution.
Test 4: SUCCESS
MySQL server is executable.
Details: MySQL server found: /usr/bin/mysqld Ver 10.5.5-MariaDB for Linux on x86_64 (Arch Linux)
Test 5: SUCCESS
No current MySQL error log found.
Details: The MySQL server did not report any errors during this startup. The log can be found in '/home/ulf/.local/share/akonadi/db_data/mysql.err'.
Test 6: SUCCESS
MySQL server default configuration found.
Details: The default configuration for the MySQL server was found and is readable at <a href="/etc/xdg//akonadi/mysql-global.conf">/etc/xdg//akonadi/mysql-global.conf</a>.
File content of '/etc/xdg//akonadi/mysql-global.conf':
# Global Akonadi MySQL server settings,
# These settings can be adjusted using $HOME/.config/akonadi/mysql-local.conf
# Based on advice by Kris Köhntopp <kris@mysql.com>
[mysqld]
# strict query parsing/interpretation
# TODO: make Akonadi work with those settings enabled
# sql_mode=strict_trans_tables,strict_all_tables,strict_error_for_division_by_zero,no_auto_create_user,no_auto_value_on_zero,no_engine_substitution,no_zero_date,no_zero_in_date,only_full_group_by,pipes_as_concat
# DEBUGGING:
# log all queries, useful for debugging but generates an enormous amount of data
# log=mysql.full
# log queries slower than n seconds, log file name relative to datadir (for debugging only)
# log_slow_queries=mysql.slow
# long_query_time=1
# log queries not using indices, debug only, disable for production use
# log_queries_not_using_indexes=1
# mesure database size and adjust innodb_buffer_pool_size
# SELECT sum(data_length) as bla, sum(index_length) as blub FROM information_schema.tables WHERE table_schema not in ("mysql", "information_schema");
# NOTES:
# Keep Innob_log_waits and keep Innodb_buffer_pool_wait_free small (see show global status like "inno%", show global variables)
#expire_logs_days=3
#sync_bin_log=0
# Use UTF-8 encoding for tables
character_set_server=utf8
collation_server=utf8_general_ci
# use InnoDB for transactions and better crash recovery
default_storage_engine=innodb
# memory pool InnoDB uses to store data dictionary information and other internal data structures (default:8M)
# Deprecated in MySQL >= 5.6.3, removed in 5.7 (works in MariaDB)
# innodb_additional_mem_pool_size=8M
# memory buffer InnoDB uses to cache data and indexes of its tables (default:128M)
# Larger values means less I/O
innodb_buffer_pool_size=128M
# Create a .ibd file for each table (default:0)
innodb_file_per_table=1
# Write out the log buffer to the log file at each commit (default:1)
innodb_flush_log_at_trx_commit=2
# Buffer size used to write to the log files on disk (default:1M for builtin, 8M for plugin)
# larger values means less I/O
innodb_log_buffer_size=1M
# Size of each log file in a log group (default:5M) larger means less I/O but more time for recovery.
innodb_log_file_size=64M
# # error log file name, relative to datadir (default:hostname.err)
log_error=mysql.err
# print warnings and connection errors (default:1)
log_warnings=2
# Convert table named to lowercase
lower_case_table_names=1
# Maximum size of one packet or any generated/intermediate string. (default:1M)
max_allowed_packet=32M
# Maximum simultaneous connections allowed (default:100)
max_connections=256
# The two options below make no sense with prepared statements and/or transactions
# (make sense when having the same query multiple times)
# Memory allocated for caching query results (default:0 (disabled))
query_cache_size=0
# Do not cache results (default:1)
query_cache_type=0
# Do not use the privileges mechanisms
skip_grant_tables
# Do not listen for TCP/IP connections at all
skip_networking
# The number of open tables for all threads. (default:64)
table_open_cache=200
# How many threads the server should cache for reuse (default:0)
thread_cache_size=3
# wait 365d before dropping the DB connection (default:8h)
wait_timeout=31536000
# We use InnoDB, so don't let MyISAM eat up memory
key_buffer_size=16K
[client]
default-character-set=utf8
Test 7: SKIP
MySQL server custom configuration not available.
Details: The custom configuration for the MySQL server was not found but is optional.
Test 8: SUCCESS
MySQL server configuration is usable.
Details: The MySQL server configuration was found at <a href="/home/ulf/.local/share/akonadi/mysql.conf">/home/ulf/.local/share/akonadi/mysql.conf</a> and is readable.
File content of '/home/ulf/.local/share/akonadi/mysql.conf':
[mysqld]
# DEBUGGING:
# log=mysql.full
# long_query_time=1
# NOTES:
#expire_logs_days=3
#sync_bin_log=0
log_error=mysql.err
log_warnings=2
max_connections=256
query_cache_size=0
query_cache_type=0
skip_grant_tables
skip_networking
thread_cache_size=3
key_buffer_size=16K
[client]
Test 9: SUCCESS
akonadictl found and usable
Details: The program '/usr/bin/akonadictl' to control the Akonadi server was found and could be executed successfully.
Result:
akonadictl 5.15.0 (20.08.0)
Test 10: ERROR
Akonadi control process not registered at D-Bus.
Details: The Akonadi control process is not registered at D-Bus which typically means it was not started or encountered a fatal error during startup.
Test 11: ERROR
Akonadi server process not registered at D-Bus.
Details: The Akonadi server process is not registered at D-Bus which typically means it was not started or encountered a fatal error during startup.
Test 12: SKIP
Protocol version check not possible.
Details: Without a connection to the server it is not possible to check if the protocol version meets the requirements.
Test 13: ERROR
No resource agents found.
Details: No resource agents have been found, Akonadi is not usable without at least one. This usually means that no resource agents are installed or that there is a setup problem. The following paths have been searched: '/usr/share/akonadi/agents'. The XDG_DATA_DIRS environment variable is set to '/home/ulf/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share:/var/lib/snapd/desktop'; make sure this includes all paths where Akonadi agents are installed.
Directory listing of '/usr/share/akonadi/agents':
akonadiindexingagent.desktop
akonotesresource.desktop
birthdaysresource.desktop
contactsresource.desktop
davgroupwareresource.desktop
ewsmtaresource.desktop
ewsresource.desktop
googleresource.desktop
icaldirresource.desktop
icalresource.desktop
imapresource.desktop
kalarmdirresource.desktop
kalarmresource.desktop
knutresource.desktop
kolabresource.desktop
maildirresource.desktop
maildispatcheragent.desktop
mboxresource.desktop
migrationagent.desktop
mixedmaildirresource.desktop
newmailnotifieragent.desktop
openxchangeresource.desktop
pop3resource.desktop
tomboynotesresource.desktop
vcarddirresource.desktop
vcardresource.desktop
Environment variable XDG_DATA_DIRS is set to '/home/ulf/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share:/var/lib/snapd/desktop'
Test 14: SUCCESS
No current Akonadi server error log found.
Details: The Akonadi server did not report any errors during its current startup.
Test 15: SUCCESS
No previous Akonadi server error log found.
Details: The Akonadi server did not report any errors during its previous startup.
Test 16: SUCCESS
No current Akonadi control error log found.
Details: The Akonadi control process did not report any errors during its current startup.
Test 17: SUCCESS
No previous Akonadi control error log found.
Details: The Akonadi control process did not report any errors during its previous startup.
Bestimmt könnt ihr damit was anfangen
Danke für eure Hilfe ich brauche nählich den Kalender für meine Termine
Hier der test:
Test 1: SUCCESS
[%General]
Driver=QMYSQL
[QMYSQL]
Host=
Name=akonadi
StartServer=true
Test 2: SUCCESS
Test 3: SUCCESS
MySQL server found.
Test 4: SUCCESS
Test 5: SUCCESS
Test 6: SUCCESS
[mysqld]
# DEBUGGING:
# log=mysql.full
# long_query_time=1
# NOTES:
#expire_logs_days=3
#sync_bin_log=0
log_error=mysql.err
log_warnings=2
max_connections=256
query_cache_size=0
query_cache_type=0
skip_grant_tables
skip_networking
thread_cache_size=3
key_buffer_size=16K
[client]
Test 7: SKIP
Test 8: SUCCESS
[mysqld]
# DEBUGGING:
# log=mysql.full
# long_query_time=1
# NOTES:
#expire_logs_days=3
#sync_bin_log=0
log_error=mysql.err
log_warnings=2
max_connections=256
query_cache_size=0
query_cache_type=0
skip_grant_tables
skip_networking
thread_cache_size=3
key_buffer_size=16K
[client]
Test 9: SUCCESS
Result:
Test 10: ERROR
Test 11: ERROR
Test 12: SKIP
Test 13: ERROR
ewsresource.desktop
Test 14: SUCCESS
Test 15: SUCCESS
Test 16: SUCCESS
Test 17: SUCCESS
- ksnip_20200830-214032.png (16.78 KiB) 5098 mal betrachtet
- ksnip_20200830-213945.png (21.16 KiB) 5098 mal betrachtet
- Moderator
- Kernel: 6.1
- Hat sich bedankt: 28 Mal
Re: Akonadi Dienst arbeitet nicht richtig
Probier es mal mit
Starte Akonadi und wenn es läuft danach noch ein
sudo aa-complain /usr/bin/akonadiserver
sudo aa-enforce /usr/bin/akonadiserver
- CPU: 4x Intel Core i5-6200 CPU @ 2.30GHz
- GPU: NVIDIA GeForce 930M
- Kernel: 5.10.18-1-MANJARO
- Desktop-Variante: KDE Plasma 5.21.1
- GPU Treiber: Mesa Intel® HD Graphics 520
- Hat sich bedankt: 42 Mal
- Danksagung erhalten: 13 Mal
Hallo Blueriver,
ich habe dasselbe Problem, und habe die Befehle ausgeführt.
Das ergebnis ist leider unverändert.
Da das Problem das erste mal bei KMail auftrat, hatte ich inzwischen Kmail deinstalliert (muß ich nicht unbedingt haben - wäre aber schön.
Mein Hauptsystem ist z.Zt. noch Linux Mint Cinnamon. Soll/könnte aber von Manjaro abgelöst werden.
Zwischen dem ersten und zweiten Befehl habe ich KOrganizer gestartet (weil ich nicht weoß, was du mit "starte Aconadi" meintest).[borrtux@borrtux-p7641md60398 ~]$ sudo aa-complain /usr/bin/akonadiserver
[sudo] Passwort für borrtux:
/usr/bin/akonadiserver wird in den Complain-Modus versetzt.
[borrtux@borrtux-p7641md60398 ~]$ sudo aa-enforce /usr/bin/akonadiserver
/usr/bin/akonadiserver wird in den Erzwingen-Modus versetzt.
Es grüßt euch borrtux
- CPU: Rysen 7
- Kernel: 6.3.5
- GPU Treiber: k.A.
Hallo Blueriver,
habe es ausprobiert und sah erst gut aus. Korganizer gestartet ohne Fehler und Kalender Datei hinzugefügt aber keine Termine im Kalender zu sehen.
Dann Notbook runtergefahren und neu gestartet und sofort wieder der Fehler.
- CPU: Rysen 7
- Kernel: 6.3.5
- GPU Treiber: k.A.
Hallo nochmal,
ich habe inzwischen im Internet weiter gesucht und da wird oft von mariadb.service berichtet.
Jetzt habe ich mal im AUR nachgeschaut und mariadb ist installiert.wenn ich den Dienst aber starte gibts auch Fehler,habe den status mal für euch hier kopiert vielleicht hilft euch das ja weiter.
[ulf@xotox ~]$ systemctl start mariadb
Job for mariadb.service failed because the control process exited with error code.
See "systemctl status mariadb.service" and "journalctl -xe" for details.
[ulf@xotox ~]$ systemctl status mariadb.service
● mariadb.service - MariaDB 10.5.5 database server
Loaded: loaded (/usr/lib/systemd/system/mariadb.service; disabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Tue 2020-09-01 18:22:58 CEST; 42s ago
Docs: man:mariadbd(8)
https://mariadb.com/kb/en/library/systemd/
Process: 3553 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0>
Process: 3554 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VAR=`cd /usr/bin/..; /usr>
Process: 3564 ExecStart=/usr/bin/mariadbd $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=exited>
Main PID: 3564 (code=exited, status=1/FAILURE)
Status: "MariaDB server is down"
Sep 01 18:22:56 xotox mariadbd[3564]: 2020-09-01 18:22:56 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/my>
Sep 01 18:22:56 xotox mariadbd[3564]: 2020-09-01 18:22:56 0 [ERROR] Could not open mysql.plugin table: "Table 'mys>
Sep 01 18:22:56 xotox mariadbd[3564]: 2020-09-01 18:22:56 0 [ERROR] Can't open and lock privilege tables: Table 'm>
Sep 01 18:22:56 xotox mariadbd[3564]: 2020-09-01 18:22:56 0 [Note] InnoDB: Buffer pool(s) load completed at 200901>
Sep 01 18:22:56 xotox mariadbd[3564]: 2020-09-01 18:22:56 0 [Note] Server socket created on IP: '::'.
Sep 01 18:22:56 xotox mariadbd[3564]: 2020-09-01 18:22:56 0 [ERROR] Fatal error: Can't open and lock privilege tab>
Sep 01 18:22:56 xotox mariadbd[3564]: 2020-09-01 18:22:56 0 [ERROR] Aborting
Sep 01 18:22:58 xotox systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Sep 01 18:22:58 xotox systemd[1]: mariadb.service: Failed with result 'exit-code'.
lines 1-20
lines 1-20
Hallo Prizibil,
Ob das aber Akonadi auf die Beine hilft weiss ich nicht.
ist die Datenbank aber auch initialisiert?
sudo mysql_install_db --user=mysql --basedir=/usr --datadir=/var/lib/mysql
sudo systemctl start mariadb
sudo systemctl enable mariadb
sudo mysql_secure_installation
- CPU: Rysen 7
- Kernel: 6.3.5
- GPU Treiber: k.A.
danke für die schnelle Antwort,mariadb ist jetzt ohne Fehler aber der akonadi geht immer noch nicht.
Soll ich lieber mal die Festplatte löschen und Manjaro neu installieren?
Gruß prizibil
Gruß prizibil
Hallo Prizibil,
Aber da ich von Akonadi nur weiss, daß es das gibt kann ich dir nur diesen Versuch anbieten
https://wiki.archlinux.de/title/KDE#Akonadi
Das klingt für mich zu sehr nach Windows
Ich möchte hier nichts durcheinander bringen, aber da ich dasselbe Problem habe, habe ich den Vorschlag von Gosia (danke dafür) mal versucht.
Mit folgendem Ergebnis:
Ergebnis ist Kmail hat immer noch denselben Fehler und läuft nicht.
[borrtux@borrtux-p7641md60398 ~]$ akonadictl stop
Akonadi is not running.
[borrtux@borrtux-p7641md60398 ~]$ akonadictl status
Akonadi Control: stopped
Akonadi Server: stopped
Akonadi Server Search Support: available (Remote Search, Akonadi Search Plugin)
Available Agent Types: akonadi_akonotes_resource, akonadi_archivemail_agent, akonadi_birthdays_resource, akonadi_contacts_resource, akonadi_davgroupware_resource, akonadi_ews_resource, akonadi_ewsmta_resource, akonadi_followupreminder_agent, akonadi_google_resource, akonadi_ical_resource, akonadi_icaldir_resource, akonadi_imap_resource, akonadi_indexing_agent, akonadi_kalarm_dir_resource, akonadi_kalarm_resource, akonadi_knut_resource, akonadi_kolab_resource, akonadi_maildir_resource, akonadi_maildispatcher_agent, akonadi_mailfilter_agent, akonadi_mbox_resource, akonadi_migration_agent, akonadi_mixedmaildir_resource, akonadi_newmailnotifier_agent, akonadi_notes_agent, akonadi_notes_resource, akonadi_openxchange_resource, akonadi_pop3_resource, akonadi_sendlater_agent, akonadi_tomboynotes_resource, akonadi_unifiedmailbox_agent, akonadi_vcard_resource, akonadi_vcarddir_resource
[borrtux@borrtux-p7641md60398 ~]$ rm -rf $HOME/.local/share/akonadi/db_data
[borrtux@borrtux-p7641md60398 ~]$ akonadictl restart
[borrtux@borrtux-p7641md60398 ~]$ mysql_install_db --datadir=$HOME/.local/share/akonadi/db_data --basedir=/usr
Installing MariaDB/MySQL system tables in '/home/borrtux/.local/share/akonadi/db_data' ...
OK
To start mysqld at boot time you have to copy
support-files/mysql.server to the right place for your system
Two all-privilege accounts were created.
One is root@localhost, it has no password, but you need to
be system 'root' user to connect. Use, for example, sudo mysql
The second is borrtux@localhost, it has no password either, but
you need to be the system 'borrtux' user to connect.
After connecting you can set the password, if you would need to be
able to connect as any of these users with a password and without sudo
See the MariaDB Knowledgebase at https://mariadb.com/kb or the
MySQL manual for more instructions.
You can start the MariaDB daemon with:
cd '/usr' ; /usr/bin/mysqld_safe --datadir='/home/borrtux/.local/share/akonadi/db_data'
You can test the MariaDB daemon with mysql-test-run.pl
cd '/usr/mysql-test' ; perl mysql-test-run.pl
Please report any problems at https://mariadb.org/jira
The latest information about MariaDB is available at https://mariadb.org/.
You can find additional information about the MySQL part at:
https://dev.mysql.com
Consider joining MariaDB's strong and vibrant community:
https://mariadb.org/get-involved/
Hallo Borrtux,
ausgelassen hast, der dafür sorgt, daß MariaDB mindestens mit Passwörten lauft. Und ob nun MariaDB beim Booten automatisch gestartet wird kann ich so nur hoffen und raten.
Aber da ich mich gerade im Reich der Spekulation bewege kann ich auch gleich noch vermuten, daß man Akonadi irgendwie mitteilen muss (Konfiguration?) daß jetzt MariaDB als Datenbank zuständig ist. Nur ein Verdacht, aber er liegt nahe, weil ich auch Beiträge gelesen habe, in denen nicht MariaDB sondern PostgreSQL für Akonadi eingerichtet wurde. Aber wie gesagt, da sollten die Plasma/KDE-User ran, von denen ja wohl niemand ohne Akonadi auskommt und die sich deshalb super mit Akonadi auskennen
Nur noch was MariaDB betrifft. gib mal probeweise nach einem Neustart des Rechners (wichtig) dieses Kommando ein:
wenn Du dann im MariaDB Monitor landest, sieht so aus:
bist Du schon mal sicher, daß MariaDB vernünftig läuft.
Wenn nicht, dann nicht
Leider geht es aber etwas durcheinander... Akonadi ist das eine und MariaDB das andere, auch wenn Akonadi wohl eine laufende DB benötigt.
Vorab, ich habe keine Ahnung von Akonadi, habe nur gelesen, daß es wohl eine gut eingerichtete und laufende Datenbank benötigt. Wenn ich es richtig sehe, hast Du die Reihenfolge wohl umgedreht, zuerst versucht Akonadi zu starten und dann die DB eingerichtet, aber igendwie auch nur halbherzig: zwei User (root und Du) mit vollen Privilegien für MariaDB aber ohne jegliches Passwort. Was schon mal für die DB kritisch ist und den Verdacht aufkommen lässt, daß Du diesen Schritt
mysql -uroot -p
Welcome to the MariaDB monitor. Commands end with ; or \g.
Your MariaDB connection id is 14
Hallö Gosia,
tut mir leid, wenn es durcheinander geht. Da bleibe ich hier mal lieber draußen.
Nein, ich habe genau und Schritt für Schritt die Anleitung durchgeführt. Du hast bestimmt gesehen, dass dort zuerst steht "Stoppen von Akonadi"
Von
Ich hänge die von Dir verlinkte Anleitung als Screenshot an.
Dein letzter Tip ergab:
Ok läuft nicht.
Von
war dort keine Rede, konnte ich deshalb auch nicht auslassen.sudo mysql_secure_installation
[borrtux@borrtux-p7641md60398 ~]$ mysql -uroot -p
Enter password:
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/run/mysqld/mysqld.sock' (2)
Hallo Borrtux,
https://forum.manjaro.org/t/howto-insta ... lamp/13000
nochmal den MariaDB-Teil durchgehen, ob Du alles so gemacht hast. Aber Achtung - nur den MariaDB-Abschnitt - schliesslich willst und brauchst Du kein LAMPP aufsetzen. Also ab
Und da sind wir schon wieder mitten in dem Schlamassel, daß wir eigentlich Akonadi starten wollen und trotzdem von was anderem - MariaDB - reden.
Naja, ist auch irgendwie schwierig zu trennen. Die eigentliche Frage ging ja um Akonadi und jetzt kommt das Problem "wie installiere ich eine Datenbank" ins Spiel, was ja eigentlich ein eigenen Thread ergeben würde. Auf der anderen Seite scheint das aber eine Vorraussetzung für Akonadi zu sein, gehört also doch irgendwie dazu.
Naja, wie man's nimmt:Borrtux hat geschrieben: ↑Mittwoch 2. September 2020, 17:53 Vonwar dort keine RedeCode: Alles auswählen
Alles zu lesen ist also nicht so verkehrt. Aber dieser letzte Schritt ist eigentlich eher aus sicherheitstechnischen Gründen wichtig. Jedenfalls läuft dein MariaDB nicht, da kann es so also auch nichts mit Akonadi werden. Kannst ja in dieser Anleitunggosia hat geschrieben: ↑Dienstag 1. September 2020, 18:52 ist die Datenbank aber auch initialisiert?Code: Alles auswählen
sudo mysql_install_db --user=mysql --basedir=/usr --datadir=/var/lib/mysql sudo systemctl start mariadb sudo systemctl enable mariadb sudo mysql_secure_installation
##3. Install MariaDB
- CPU: Rysen 7
- Kernel: 6.3.5
- GPU Treiber: k.A.
da bin ich wieder. Habe vom Stick die iso gestartet Festplatte gelöscht und Manjaro neu installiert.
Ergebnis: Akonadi-Dienst startet immer noch nicht. Praktisch der gleiche Fehler wie vorher.
Was ich allerdings bemerkt habe zur ersten fehlerfreien Installation ist, beim Start 2 reihen in rot
laufen so schnell durch eine ist aber Failed:to load zfs Filesystem
hoffe ich zumindest.
Und beim Installationsprogramm kommt am Anfang "Der Computer ist nicht mit dem Internet verbunden"
Da ich mir eine Neuinstallation mit alten Fehlern nicht vorstellen kann, müsst ihr mir da helfen was mach ich jetzt noch.
setze sehr auf eure Hilfe
mfg Prizibil
mfg Prizibil
- CPU: Rysen 7
- Kernel: 6.3.5
- GPU Treiber: k.A.
kommt noch besser wenn ich die ausweisapp2 installieren will kommt folgendes
AusweisApp2-1.20.1.tar.gz ... FEHLGESCHLAGEN (Unbekannter öffentlicher Schlüssel 2D7479A531451088)
==> FEHLER: Eine oder mehrere PGP-Signaturen konnten nicht überprüft werden!
Fehler beim Erstellen von ausweisapp2
Hallo Prizibil,
bitte mach künftig für neue Probleme einen neuen Thread auf, das zerfranst hier schon zu sehr.
oder importiere den Key
https://wiki.archlinux.org/index.php/Gn ... public_key
aber wie gesagt, wenn einige von diesen Themen sich so nicht klären lassen, bitte in neuen Threads weiterbehandeln.
benutzt Du denn das zfs Filesystem?
das kann schon sein, aber dann bist Du doch verbunden, oder nicht?
https://wiki.archlinux.org/index.php/Pa ... nown_trust
