this update is more or less a roundup patchset. We fixed some issues we found in Calamares 2.3b3, updated some lib32-libraries, sqlite and renewed some python and haskell packages. Also we will base our fourth preview of Manjaro 16.08 on those packages.
Archlinux upstream fixes are now from: Sat Aug 13 07:37 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Additional it would be good to test one of our preview install medias to check these changes on a fresh install.
Kind regards,
Troubleshoots
GTK3
You can install it with:
ufw
steam
Current supported kernels
Linux310 3.10.102
Linux312 3.12.62
Linux314 3.14.75
Linux316 3.16.36
Linux318 3.18.39
Linux319 3.19.8.23 [EOL]
Linux41 4.1.30
Linux42 4.2.8.13 [EOL]
Linux44 4.4.17
Linux45 4.5.7 [EOL]
Linux46 4.6.6
Linux47 4.7.0
Linux-RT-LTS 4.4.15-rt23
Linux-RT 4.6.5-rt10
Package changes
testing community i686: 72 new and 68 removed package(s)
testing community x86_64: 72 new and 68 removed package(s)
testing core i686: 6 new and 6 removed package(s)
testing core x86_64: 6 new and 6 removed package(s)
testing extra i686: 15 new and 15 removed package(s)
testing extra x86_64: 15 new and 15 removed package(s)
testing multilib x86_64: 13 new and 13 removed package(s)
Quelle
