this update is more or less to renew most of our kernels. Also we added changelogs of the same to MSM. Calamares is now at 2.3-beta3, which introduces a better locale handling during installation. We will feature this installer in our fourth preview of Manjaro 16.08. Besides Wine 1.9.16 we have the usual upstream repacks and updates.
Archlinux upstream fixes are now from: Fri Aug 12 08:09 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Additional it would be good to test one of our preview install medias to check these changes on a fresh install.
Kind regards,
Troubleshoots
GTK3
You can install it with:
ufw
steam
Current supported kernels
Linux310 3.10.102
Linux312 3.12.62
Linux314 3.14.75
Linux316 3.16.36
Linux318 3.18.39
Linux319 3.19.8.23 [EOL]
Linux41 4.1.30
Linux42 4.2.8.13 [EOL]
Linux44 4.4.17
Linux45 4.5.7 [EOL]
Linux46 4.6.6
Linux47 4.7.0
Linux-RT-LTS 4.4.15-rt23
Linux-RT 4.6.5-rt10
Package changes
testing community i686: 80 new and 79 removed package(s)
testing community x86_64: 78 new and 77 removed package(s)
testing core i686: 12 new and 12 removed package(s)
testing core x86_64: 12 new and 12 removed package(s)
testing extra i686: 97 new and 96 removed package(s)
testing extra x86_64: 97 new and 96 removed package(s)
testing multilib x86_64: 3 new and 3 removed package(s)
Quelle
