2016-08-10 - Mate (from Arch), Vulkan, Texlive, Lumina (Testing Update)
Kernel: 6.1
Hat sich bedankt: 28 Mal
Danksagung erhalten: 151 Mal
Hi community,
this update is more or less the move back to Archlinux Mate-Upstream packages. It took a while for Arch to pick them up. Since upstream is again maintaining Mate, it makes not so much sense to do double work from our end.
TeXLive packages have been updated to the 2016 version. The most notable change is that the biber utility is now provided as a separate package. You can install it normally using pacman. Pacman hooks are now used in the TeXLive packages so the update will be less verbose than in past years.
Also we moved our Netbook-Kernel up a notch and updated it to v4.4 kernel series and Lumina-Desktop sees its first stable release.
Archlinux upstream fixes are now from: Wed Aug 10 07:20 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Additional it would be good to test one of our preview install medias  to check these changes on a fresh install.
Kind regards,
Troubleshoots
GTK3
You can install it with:
ufw
steam
Reference: Archlinux wiki
Current supported kernels
Linux310 3.10.102
Linux312 3.12.62
Linux314 3.14.74
Linux316 3.16.36
Linux318 3.18.37
Linux319 3.19.8.23 [EOL]
Linux41 4.1.28
Linux42 4.2.8.13 [EOL]
Linux44 4.4.16
Linux45 4.5.7 [EOL]
Linux46 4.6.5
Linux47 4.7.0
Linux-RT-LTS 4.4.15-rt23
Linux-RT 4.6.5-rt9
Package changes
testing community i686: 165 new and 184 removed package(s)
testing community x86_64: 165 new and 184 removed package(s)
testing core i686: 13 new and 14 removed package(s)
testing core x86_64: 13 new and 14 removed package(s)
testing extra i686: 95 new and 93 removed package(s)
testing extra x86_64: 95 new and 93 removed package(s)
testing multilib x86_64: 13 new and 13 removed package(s)
Quelle
Kernel: 4.20
Kernel: 6.1
Re: 2016-08-10 - Mate (from Arch), Vulkan, Texlive, Lumina (Testing Update)
Ohne Probleme!
Kernel: 4.20
linuxkumpel
Kernel: 5.15 / 6.0
GPU Treiber: Intel i915
Hat sich bedankt: 15 Mal
Danksagung erhalten: 36 Mal
Beitrag von linuxkumpel »
Alles flott durchgelaufen und nach dem Neustart ebenfalls alles top.  ???
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft! :)
Zurück zu „|Testing Releases|“
