2016-08-06 - Plasma 5.7.3, LibreOffice, Firefox, Thunderbird (Testing Update)
Kernel: 6.1
Hat sich bedankt: 28 Mal
Danksagung erhalten: 151 Mal
Almost a week passed for this testing branch update-pack. It took us a little longer to sync our Firefox and Thunderbird packages with upstream. Rob worked on his Netbook optimized kernel, our kernel team on the real-time kernels and I on the Nvidia drivers. Let see if 367.36.02 is fixing some issues we have in 367 series of the proprietary driver.
We also have Libreoffice in both branches. Fresh is now at v5.2 series and Still adopted v5.1 series. We have an updated tool-chain featuring the latest glibc 2.24 which let to rebuilds of python, haskel and a new version of eric. KDE fans will be happy about the Plasma 5.7.3 update.
Archlinux upstream fixes are now from: Sat Aug 06 16:37 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Additional it would be good to test one of our preview install medias to check these changes on a fresh install. Package details can be found here.
Kind regards,
Troubleshoots
GTK3
You can install it with:
ufw
steam
Reference: Archlinux wiki
Current supported kernels
Linux310 3.10.102
Linux312 3.12.62
Linux314 3.14.74
Linux316 3.16.36
Linux318 3.18.37
Linux319 3.19.8.23 [EOL]
Linux41 4.1.28
Linux42 4.2.8.13 [EOL]
Linux44 4.4.16
Linux45 4.5.7 [EOL]
Linux46 4.6.5
Linux47 4.7.0
Linux-RT-LTS 4.4.15-rt23
Linux-RT 4.6.5-rt9
Upstream package changes:
testing community i686: 446 new and 441 removed package(s)
testing core x86_64: 22 new and 22 removed package(s)
testing core i686: 22 new and 22 removed package(s)
testing multilib x86_64: 25 new and 25 removed package(s)
testing extra i686: 502 new and 501 removed package(s)
testing extra x86_64: 502 new and 501 removed package(s)
testing community x86_64: 449 new and 444 removed package(s)
Overlay package changes:
testing community i686: 103 new and 98 removed package(s)
testing core x86_64: 3 new and 2 removed package(s)
testing core i686: 3 new and 2 removed package(s)
testing multilib x86_64: 2 new and 4 removed package(s)
testing extra i686: 20 new and 21 removed package(s)
testing extra x86_64: 20 new and 19 removed package(s)
testing community x86_64: 132 new and 98 removed package(s)
Quelle
Zuletzt geändert von Blueriver am Samstag 6. August 2016, 18:42, insgesamt 1-mal geändert.
Kernel: 4.20
saurier
Hat sich bedankt: 61 Mal
Danksagung erhalten: 24 Mal
Re: 2016-08-06 - Plasma 5.7.3, LibreOffice, Firefox, Thunderbird (Testing Update)
Beitrag von saurier »
Problem beim Update:
[img width=529 height=400][/img]
Läuft ŝomit nicht ganz durch..... :'( Was genau sagt er mir damit?  ^-^
Kernel: 6.1
Hallo saurier,
das schreibt philm dazu
.. Is using testing branch. You might be on an outdated mirror as the memtest86+ is already fixed.
gib mal im Terminal ein
sudo pacman-mirrors -g -c Germany
Danach das System noch mal aktualisieren.
Kernel: 4.20
Kernel: 6.1
Das Update lief sauber durch und alles funktioniert einwandfrei.
Kernel: 4.20
saurier
[quote="Blueriver"]
Hallo saurier,
Hm, gesagt getan, leider nichts geholfen:
Pakete (1) memtest86+-5.01-2
Gesamtgröße der installierten Pakete:   0,14 MiB
Größendifferenz der Aktualisierung:  -0,01 MiB
(1/1) Prüfe Schlüssel im Schlüsselring             [######################] 100%
(1/1) Überprüfe Paket-Integrität                   [######################] 100%
(1/1) Lade Paket-Dateien                           [######################] 100%
(1/1) Prüfe auf Dateikonflikte                     [######################] 100%
Fehler: Konnte den Vorgang nicht durchführen (In Konflikt stehende Dateien)
memtest86+: /etc/grub.d/60_memtest86+ existiert im Dateisystem
LuMI
Beitrag von LuMI »
sudo rm /etc/grub.d/60_memtest86+
saurier
Jepp, Danke LUMI, das wars. Nun ist die Meldung weg und das System komplett Aktualisert.
linuxkumpel
Kernel: 5.15 / 6.0
GPU Treiber: Intel i915
Hat sich bedankt: 15 Mal
Danksagung erhalten: 36 Mal
Beitrag von linuxkumpel »
Alles top.  ???
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft! :)
Amber
Beitrag von Amber »
[quote="saurier"]
weis nicht ob einfach löschen die Lösung ist (hätte es höchstens umbenannt). Bei mir ist auch 60_memtest86+ vorhanden und keine Fehlermeldung.
peace
LuMI
Beitrag von LuMI »
[quote="Amber"]
[quote="saurier"]
peace
Die /etc/grub.d/60_memtest86+ erstellt nur den Speichertest Eintrag im Grub Menü.
