We updated linux314, linux44 and linux46 to the latest point releases, fixed some issues in Mesa 12 series, adjusted MSM for qt 5.7 changes and renewed some of our Gnome packages. Octopi gained a new point-release which fixes some issues we had found. Other than that, we added some python and perl updates.
Archlinux upstream fixes are now from: Tue Jul 30 11:55 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Additional it would be good to test one of our preview install medias to check these changes on a fresh install.
Kind regards,
Troubleshoots
GTK3
You can install it with:
With QT 5.7 you need to install qt5-styleplugins and qt5ct and configure your system to have an unified look again (If you use applications with root-rights, do the same for your root user) .
ufw
steam
Current supported kernels
Linux310 3.10.102
Linux312 3.12.62
Linux314 3.14.74
Linux316 3.16.36
Linux318 3.18.37
Linux319 3.19.8.23 [EOL]
Linux41 4.1.28
Linux42 4.2.8.13 [EOL]
Linux44 4.4.16
Linux45 4.5.7 [EOL]
Linux46 4.6.5
Linux47 4.7.0
Package changes
testing community i686: 97 new and 100 removed package(s)
testing community x86_64: 98 new and 100 removed package(s)
testing core i686: 8 new and 8 removed package(s)
testing core x86_64: 8 new and 8 removed package(s)
testing extra i686: 158 new and 140 removed package(s)
testing extra x86_64: 158 new and 140 removed package(s)
testing multilib x86_64: 2 new and 3 removed package(s)
Quelle
