2016-07-23 - MSM, VirtualBox, Manjaro 16.08-pre1 (testing)
Kernel: 6.1
Hat sich bedankt: 28 Mal
Danksagung erhalten: 151 Mal
We are getting close to our next stable release of Manjaro Linux. So I decided to push this update-pack now to our testing branch.
We updated VirtualBox to 5.1.2. Still we see the mouse cursor error  , which seems to be upstream. Ramon worked on Manjaro Settings Manager to get translations going again, I've updated Manjaro Welcome to start our installers themed again, plus Bernhard is getting nuts on Kernel Configs to get a higher kernel version than 4.4 series working with VirtualBox again. This brings also a newer libdrm to support more hardware.
We are still evaluating a way on how to get a unified look for qt apps on GTK environments. More on that topic here  . If you have segfaults, please post the exact application you used and theme, so we can help. Also start the application from a terminal so we get the error messages.
Archlinux upstream fixes are now from: Sat Jul 23 18:23 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Additional it would be good to test one of our preview install medias to check these changes on a fresh install.
Kind regards,
Troubleshoots
GTK3
You can install it with:
QT apps style with GTK
ufw
steam
Reference: Archlinux wiki
Current supported kernels
Linux310 3.10.102
Linux312 3.12.61
Linux314 3.14.73
Linux316 3.16.36
Linux318 3.18.37
Linux319 3.19.8.23 [EOL]
Linux41 4.1.28
Linux42 4.2.8.13 [EOL]
Linux44 4.4.15
Linux45 4.5.7 [EOL]
Linux46 4.6.4
Linux47 4.7-rc7
Package changes
testing community i686: 49 new and 43 removed package(s)
testing community x86_64: 53 new and 47 removed package(s)
testing core i686: 4 new and 4 removed package(s)
testing core x86_64: 4 new and 4 removed package(s)
testing extra i686: 65 new and 65 removed package(s)
testing extra x86_64: 65 new and 65 removed package(s)
testing multilib x86_64: 1 new and 1 removed package(s)
Quelle
Zuletzt geändert von Blueriver am Sonntag 24. Juli 2016, 13:10, insgesamt 1-mal geändert.
Kernel: 4.20
Kernel: 6.1
Re: 2016-07-23 - MSM, VirtualBox, Manjaro 16.08-pre1 (testing)
Das Update verlief soweit ohne Probleme.
Virtualbox hat einen Bug worauf ja schon in der Updatebeschreibung hingewiesen wurde.
Da mich das sehr stört habe ich ein downgrade von Virtualbox durchgeführt.
Bei mir steht Manjaro 16.06.1, sollte jetzt nicht Manjaro 16.08-pre1 angezeigt werden?
Kernel: 4.20
Zurück zu „|Testing Releases|“
