We are still evaluating a way on how to get a unified look for qt apps on GTK environments. More on that topic here . If you have segfaults, please post the exact application you used and theme, so we can help. Also start the application from a terminal so we get the error messages.
Archlinux upstream fixes are now from: Tue Jul 19 07:39 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Additional it would be good to test one of our development install medias to check these changes on a fresh install.
Kind regards,
Troubleshoots
GTK3
You can install it with:
QT apps style with GTK
ufw
steam
Current supported kernels
Linux310 3.10.102
Linux312 3.12.61
Linux314 3.14.73
Linux316 3.16.36
Linux318 3.18.37
Linux319 3.19.8.23 [EOL]
Linux41 4.1.28
Linux42 4.2.8.13 [EOL]
Linux44 4.4.15
Linux45 4.5.7 [EOL]
Linux46 4.6.4
Linux47 4.7-rc7
Package changes
testing community i686: 47 new and 42 removed package(s)
testing community x86_64: 47 new and 42 removed package(s)
testing core i686: 6 new and 5 removed package(s)
testing core x86_64: 6 new and 5 removed package(s)
testing extra i686: 29 new and 29 removed package(s)
testing extra x86_64: 29 new and 29 removed package(s)
Quelle
