With this we have updated our whole KDE stack to the latest packages, which is: Plasma 5.7.1, Apps 16.04.3 and Framework 5.24. Canonical decided now to drop some kernels from their support. These are 3.19.x and 4.2.x. You should switch over to our LTS kernels when you feel ready. Work has also been done on our realtime kernel supported by our community. We are currently evaluating if a 32bit version of it makes sense to have. Thunderbird got updated, such as Mesa, which is now at 12.x series.
We are still evaluating a way on how to get a unified look for qt apps on GTK environments. More on that topic here. If you have segfaults, please post the exact application you used and theme, so we can help. Also start the application from a terminal so we get the error messages.
Archlinux upstream fixes are now from: Fri Jul 15 10:48 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Detailed changes can been found here.
Kind regards,
Troubleshoots
GTK3
You can install it with:
QT apps style with GTK
ufw
steam
Current supported kernels
Linux310 3.10.102
Linux312 3.12.61
Linux314 3.14.73
Linux316 3.16.36
Linux318 3.18.37
Linux319 3.19.8.23 [EOL]
Linux41 4.1.28
Linux42 4.2.8.13 [EOL]
Linux44 4.4.15
Linux45 4.5.7 [EOL]
Linux46 4.6.4
Linux47 4.7-rc7
Package changes
testing community i686: 213 new and 200 removed package(s)
testing community x86_64: 232 new and 219 removed package(s)
testing core i686: 27 new and 27 removed package(s)
testing core x86_64: 27 new and 27 removed package(s)
testing extra i686: 652 new and 647 removed package(s)
testing extra x86_64: 652 new and 647 removed package(s)
testing multilib x86_64: 13 new and 13 removed package(s)
Quelle
