Other than that, we updated some python, wine and manjaro desktop settings. Also some work went into polkit's pkexec to support theming. Please test also from starting apps from a terminal if you find any errors with our changes. Friends of the bleeding-edge can now test linux 4.7 series with all extramodules now availabel. Detailed package changes here.
Archlinux upstream fixes are now from: Wed Jun 29 07:40 CEST 2016.
Kind regards,
Troubleshoots
GTK3
You can install it with:
With QT 5.7 you need to install qt5-styleplugins and qt5ct and configure1 your system to have an unified look again.
ufw
steam
Current supported kernels
Linux310 3.10.102
Linux312 3.12.61
Linux314 3.14.73
Linux316 3.16.36
Linux318 3.18.36
Linux319 3.19.8.22
Linux41 4.1.27
Linux42 4.2.8.12
Linux44 4.4.14
Linux45 4.5.7 [EOL]
Linux46 4.6.3
Linux47 4.7-rc5
Quelle
