Archlinux upstream fixes are now from: Mon Jun 27 07:31 CEST 2016.
Kind regards,
Troubleshoots
GTK3
You can install it with:
ufw
steam
Current supported kernels
Linux310 3.10.102
Linux312 3.12.61
Linux314 3.14.73
Linux316 3.16.36
Linux318 3.18.36
Linux319 3.19.8.22
Linux41 4.1.27
Linux42 4.2.8.12
Linux44 4.4.14
Linux45 4.5.7 [EOL]
Linux46 4.6.3
Quelle
