Hello community,
Another testing branch update with some interesting updates for you!
Some of the Kernels got updated
Some Cinnamon and Deepin updates
Plasma5 got updated some more fixes for 5.19.2 5
The usual upstream updates including Perl rebuilds/updates by Arch
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev 1, which we build on a regular basis against kde-git master packages. Also check out our latest release Manjaro Lysia 20.0.3! XFCE, KDE 3 and Gnome
Upstream notice
Arch updated their default compression to zstd. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
sudo pacman -Syy
sudo pacman -S pacman-static
sudo pacman-static -Syyu
Our current supported kernels
linux44 4.4.228
linux49 4.9.228
linux414 4.14.185
linux419 4.19.129
linux54 5.4.49
linux56 5.6.19
linux57 5.7.6
linux54-rt 5.4.44_rt27
linux56-rt 5.6.17_rt9
Package Changes (Thu Jun 25 09:08:32 CEST 2020)
testing community x86_64: 594 new and 595 removed package(s)
testing core x86_64: 12 new and 12 removed package(s)
testing extra x86_64: 304 new and 305 removed package(s)
testing multilib x86_64: 6 new and 6 removed package(s)
Mehr dazu und Quelle des Updates gibt es hier.
[Testing Update] 2020-06-25 - Kernel, Plasma 5.19.2, Perl, Calamares, AMDVLK, Cinnamon, Deepin
Themen Author - Administrator
- CPU: Intel® Core™ i7-2630QM
- GPU: Intel UHD Graphics
- Kernel: 5.6
- Hat sich bedankt: 189 Mal
- Danksagung erhalten: 142 Mal
