2019-01-19-Kernels, Systemd, Mesa, Browsers, Nvidia, Deepin, Virtual [Testing Upd
Hatte keine Probleme.
4
100%
0
Keine Stimmen
0
Keine Stimmen
Insgesamt abgegebene Stimmen: 4
Hat sich bedankt: 189 Mal
Danksagung erhalten: 142 Mal
Hi community,
Welcome to our third testing update of 2019. With this we added a lot of new packages into the mix. This also includes the Systemd update to v240 series. Please keep close attention to this update and maybe create a backup of your current data before executing it. Please report any crash back you may have with this update. It is now our fifth try to update Systemd as needed, including all current v241 patches on top of it.
So what do we have with this one?
most Kernels got updated. Note that linux44 is currently frozen, as some proprietary drivers don’t build with 4.4.168+. We also removed linux417 and linux418. If you still use these series, please move on to linux419 series and uninstall them, as we won’t compile any extramodules for them from now on.
some updates to Cinnamon and Deepin
more git-commits of v241 series to Systemd
rebuilds against new readline
KDE Framework is now at 5.54.0
Mesa is now at 18.3.2
Palemoon is now at 28.3.0
Firefox is now at its eleventh beta release of v65 series
Virtualbox got its first stable point-release of v6.0 series
Nvidia got updated to 415.27
the regular python and haskell updates
We hope with all these changes Manjaro to be more efficient for you all.
Quelle
linuxkumpel
Kernel: 5.15 / 6.0
GPU Treiber: Intel i915
Hat sich bedankt: 15 Mal
Danksagung erhalten: 36 Mal
Re: 2019-01-19-Kernels, Systemd, Mesa, Browsers, Nvidia, Deepin, Virtual [Testing Upd
Beitrag von linuxkumpel »
War ein ganz schönes Paket, fast ein halber GB. ;) Ist jedoch alles gelaufen. Reboot und noch funktioniert alles. :)
Kernel: 6.1
Hat sich bedankt: 28 Mal
Danksagung erhalten: 149 Mal
Alles bestens!
linuxkumpel
Kernel: 5.15 / 6.0
Habe jetzt Budgie auch durch, läuft. Und, sogar Weathershow funktioniert jetzt. :D Sollte das nächste Update abwarten, war eine Empfehlung.
r0ll0
CPU: Intel i7-4770
GPU: Nvida GTX 1060
Kernel: 5.11
Desktop-Variante: KDE (Stable)
GPU Treiber: NVIDIA 460
Danksagung erhalten: 6 Mal
Beitrag von r0ll0 »
Alles tutti bisher.... :-*
Danke an das Manjaro-Team
Auch hier alles gut nach dem Update...... :)
Zurück zu „|Testing Releases|“
