We are happy to announce our second release candidate for Manjaro 16.06 (Daniella)!
Calamares got fixed to start also in Gnome and Deepin, the Andromeda theme got some new icons and manjaro-tools supports 3rd-party repositories once again. After a little struggle we decided to maintain MATE on our own, since Archlinux has no active maintainer anymore for this destkop environment.
The headline changes in MATE 1.14 are:
Improved GTK+3 support across the entire MATE Desktop.
Full GTK 3.20 support in all MATE themes.
Client Side Decorated applications render correctly in all themes.
Completely ported MATE System Monitor and Mozo to GTK+3 only (we ship v1.12 for gtk2 branch).
Touchpad configuration now supports edge and two-finger scrolling independently.
Python extensions in Caja can now be managed separately.
All three window focus modes are selectable.
MATE Panel now has the ability to change icon sizes for menubar and menu items.
MATE NetSpeed Applet has been merged into the MATE Applets package.
MATE Terminal support VTE 2.91 API when built for GTK+3.
Volume and Brightness OSD can now be enabled/disabled.
Translations are updated.
Archlinux upstream fixes are now from: Tue May 24 07:41:35 CEST 2016.
It is always good to check for updated packages, even we don't notify you about them. As usual people using our testing branch will help us to get snaps over to our stable branch almost smoothly. For notifications on daily bases please take a look at our mailing list.
Kind regards,
Philip M
Manjaro Update - 2016-05-24 (testing)
Themen Author - Moderator
- Kernel: 6.1
- Hat sich bedankt: 28 Mal
Zuletzt geändert von Blueriver am Freitag 27. Mai 2016, 14:37, insgesamt 1-mal geändert.
Kernel: 4.20
Kernel: 4.20
- Kernel: 6.1
Re: Manjaro Update - 2016-05-24 (testing)
Ohne Probleme!
Ist jetzt RC2
System:Â Â Host: dirk Kernel: 4.6.0-1-MANJARO x86_64 (64 bit gcc: 6.1.1)
     Desktop: Xfce 4.12.3 (Gtk 2.24.30) info: xfce4-panel dm: lightdm
     Distro: Manjaro Linux
Ist jetzt RC2
Zuletzt geändert von Blueriver am Dienstag 24. Mai 2016, 10:17, insgesamt 1-mal geändert.
Kernel: 4.20
Kernel: 4.20
- CPU: Intel Core i5 M 540
- GPU: Intel Core Processor Integrated Graphics
- Kernel: 5.6.1-artix1-1 x86_64
- Danksagung erhalten: 2 Mal
Ist bei mir auch sehr geschmeidig und reibungslos durchgelaufen
- Kernel: 5.15 / 6.0
- GPU Treiber: Intel i915
- Hat sich bedankt: 15 Mal
- Danksagung erhalten: 36 Mal
Problemlos erledigt.
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft!
