[Stable Update] 2021-02-28 - Kernels, Plasma 5.21.1, Frameworks 5.79, Firefox, Thunderbird, Python
Hatte keine Probleme.
11
73%
2
13%
2
13%
Insgesamt abgegebene Stimmen: 15
Kernel: 6.1
Hat sich bedankt: 28 Mal
Danksagung erhalten: 151 Mal
Hello community,
Another **stable** branch update with some usual updates for you.
*Get your Plasma desktop updated to the lastest stable release! #stayhome, #staysafe, #stayhealthy*
* Most of the **Kernels** got updated
* **Firefox** is now at [86.0](https://www.mozilla.org/en-US/firefox/8 ... easenotes/)
* **Thunderbird** got updated to [78.8.0 ](https://www.thunderbird.net/en-US/thund ... easenotes/)
* For fans of KDE Software we have now [Plasma 5.21.1 ](https://kde.org/announcements/plasma/5/5.21.1/) and [Frameworks 5.79 ](https://kde.org/announcements/frameworks/5/5.79.0/) added to our repos!
* Other regular upstream updates including **python** and **haskell**
Get our latest daily developer images now from Github: [Plasma ](https://github.com/manjaro-plasma/download/releases), [Gnome](https://github.com/manjaro-gnome/download/releases), [XFCE ](https://github.com/manjaro-xfce/download/releases). You can also help us with the [**Stable-Review** images ](https://github.com/manjaro/release-review/releases), so the upcoming installer ISOs are solid for Newcomers!
**Our current supported kernels**
* linux44 4.4.258
* linux49 4.9.258
* linux414 4.14.222
* linux419 4.19.177
* linux54 5.4.100
* linux59 5.9.16 [EOL]
* linux510 5.10.18
* linux511 5.11.1
* linux54-rt 5.4.93_rt51
* linux59-rt 5.9.1_rt19
**Packages Changes** (Wed Feb 24 11:47:21 CET 2021)
* stable community x86_64: 1412 new and 1390 removed package(s)
* stable core x86_64: 50 new and 49 removed package(s)
* stable extra x86_64: 575 new and 668 removed package(s)
* stable kde-unstable x86_64: 281 new and 253 removed package(s)
* stable multilib x86_64: 27 new and 27 removed package(s)
A detailed list of all package changes can be found https://gitlab.manjaro.org/-/snippets/596/raw.
Quelle
Re: [Stable Update] 2021-02-28 - Kernels, Plasma 5.21.1, Frameworks 5.79, Firefox, Thunderbird, Python
Update auf 6 ähnlichen Laptops durchgeführt. Auf 5 Optimus-Laptops keine Probleme, aber auf der Workstation Lenovo W530 mittels pamac:
Aktzalisierung optimus-manager 1.3.1-2 auf 1.6.0-1
copying optimus_manager/client/client_checks.py -> build/lib/optimus_manager/client
copying optimus_manager/client/args.py -> build/lib/optimus_manager/client
copying optimus_manager/client/__init__.py -> build/lib/optimus_manager/client
copying optimus_manager/client/utils.py -> build/lib/optimus_manager/client
copying optimus_manager/config_schema.json -> build/lib/optimus_manager
==> Betrete fakeroot Umgebung...
==> Beginne package()...
install: der Aufruf von stat für 'config/xsetup-intel.sh' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
==> FEHLER: Ein Fehler geschah in package().[Breche ab...
Alles läuft zwar wie vor, aber das Update hakt....
Hat sich bedankt: 63 Mal
Danksagung erhalten: 118 Mal
Der SM Player machte probleme beim vorspuhlen,lange Pause bevor es weiter ging.
Neu installation vom SM Player löste das problem.
Jean-Paul
CPU: --
GPU: --
Kernel: --
Desktop-Variante: --
GPU Treiber: --
Hat sich bedankt: 42 Mal
Danksagung erhalten: 48 Mal
Beitrag von Jean-Paul »
Update per Terminal. Alles Top, System läuft. 👍
nijila
CPU: AMD Ryzen 5 PRO 4650G
GPU: Integrated graphics – AMD Radeon RX Vega 7
Kernel: stable, actual
GPU Treiber: amdgpu
Hat sich bedankt: 16 Mal
Danksagung erhalten: 8 Mal
Beitrag von nijila »
djeli hat geschrieben: Montag 1. März 2021, 09:51 Der SM Player machte probleme beim vorspuhlen,lange Pause bevor es weiter ging.
Wurde der überhaupt geupdatet? Bei mir hat er auch gezickt, ich habe nun als "Multimediamodul" den mplayer als Lösung gewählt. Ich habe das Problem aber eher nicht mit dem Manjaro-Update in Verbindung gebracht.
Ich finde den SMPlayer sowieso ein "Sorgenkind". Permanent habe ich in den letzten Monaten dessen Ausgabetreiber wechseln müssen.
Und dabei läuft der mpv selber bei mir immer perfekt, habe auch mittlerweile eine vernünftige Steuerung, alle Media-Dateien im Verzeichnis werden zur Playlist automatisch beigefügt und abspielt, hinbekommen. Nur noch 2-3 kleine GUI Feinheiten, dann wird SMPlayer gekickt. ;)
Aber das geht in Richtung Offtopic, sorry dafür.
ONtopic:
Ich hatte null Probleme mit dem Update. Und die optische Neuerung mit dem neuen Plasma-Start-Menu gefällt mir schon mal. Geht in Richtung Mint/Cinnamon, was für mich bis dato Klassenbester ist. ;)
Hat sich bedankt: 189 Mal
Danksagung erhalten: 144 Mal
Ohne Probleme durch gelaufen. ;)
@ nijila
Der SM Player lief bei mir bis jetzt ohne Probleme,auf verschiedenen Rechnern.
Mir ist das verhalten nach dem update aufgefallen.
Hab nachgeschaut SM Player hatte kein update,pulseaudio und mpv hatten updates.
Aber egal ,das problem wurde ja gelöst.
Manfrago hat geschrieben: Sonntag 28. Februar 2021, 23:30 Alles läuft zwar wie vor, aber das [Optimus qt] Update hakt....
Seit heute funktioniert das Update, das Problem wurde gefixt.
Bleibt noch das Problem mit dem Kodi Update "PTV Simple Client Addon", welches wohl erst auf künftigen Kodi 19 Versionen ausführbar sein wird. :)
MichaelP
CPU: AMD Ryzen 9 5900X
GPU: NVIDIA GTX 3080 Ti
Kernel: 6.7.0
Desktop-Variante: KDE 5.27.10
GPU Treiber: NVIDIA 545.29.06
Hat sich bedankt: 17 Mal
Danksagung erhalten: 28 Mal
Beitrag von MichaelP »
Hi zusammen,
Update-Spielstand 3:1
Ein PC und zwei Notebooks ohne Beanstandung upgedatet.
Ein ITX Mini mit AMD Ryzen APU (Renoir 4650G) dagegen produziert unter Kernel 5.11.1 nur "bunte" und unleserliche Displays,
sieht aus wie Popart aus den 1970ern, Mischung aus Negativ und Solarisation - kurzfristig sehr hübsch ;D
Hab dann unter Kernel 5.10 neu gestartet, alles o.k.-- ist beliebig reproduzierbar.
Ist jemanden ein ähnliches Phänomen bekannt? Das sollten dann die Kernel-Devs wissen!
Gruß Michael
Thatsme
CPU: verschiedene
GPU: verschiedene
Kernel: LTS 5.4.105-1
Hat sich bedankt: 77 Mal
Danksagung erhalten: 23 Mal
Beitrag von Thatsme »
es gibt gleich mehrere Probleme.
Ich Dummie habe ausnahmsweise (und das 1. mal seit ich Manjaro nutze) das komplette Update mal über pamac gemacht. Ich lese oft, dass da keinerlei Probleme macht über pamac, statt tty + pacman.
Vermutlich dürfte das aber nicht der Grund für meine Probleme sein?
1. Es wird einfach immer wieder der Kernel 10 installiert (obwohl ich ihn deinstalliert hatte) und als "Startkernel" gesetzt, ohne dass ich das so wollte. Warum? Wie kann ich das verhindern?
Ich habe linux510 unter ignore im pamac gesetzt. Nutzt aber nichts.
2. Durch dasautomatische Laden (und ungefragtem Installieren) des 10-er verschweindet auch wieder das Grub Auswahlmenü beim Start.
Denn in /etc/default/grub wurde einfach wieder das
GRUB_TIMEOUT_STYLE=menu
in
GRUB_TIMEOUT_STYLE=hidden
geändert. Ohne dies allerdings als pacnew Datei anzuzeigen!
Das nervt!
Frage zum Verständnis:
Ich dachte Linux macht nur, was der User will. Und wenn ein Kernel der nicht installiert war ein Update braucht, ok. Aber dass der dann einfach als Standard-Bootkernel gesetzt wird, finde ich "unverschämt".
Am Eintrag
GRUB_SAVEDEFAULT=true
kann das nach meinem Verständnis nicht liegen? Denn das sagt ja, dass der letzte gewählte Eintrag genommen wird?
Ich möchte das abstellen, dass der Kernel 10 nach jedem Update immer wieder aktualisiert und dann auch noch ungefragt auf aktiv gesetzt wird.
Wie mache ich das?
Kann ich da was in grub, oder grub.cfg ändern?
2. Grafikproblem beim Start, das aber von alleine wieder verschwindet, nachdem durch Einstellung in Energieoptionen der Bildschirm nach xx Minuten auf schwarz geht und der Bildschirm dann wieder aktivert wird.
Ich hatte das hier schon geschrieben:
viewtopic.php?f=38&t=3191&p=19463&hilit ... mmt#p19463
https://de.manjaro.org/index.php?topic= ... 4#msg61634
Vermutlich hat mir das - verständlicher Weise! - keiner geglaubt. Klingt auch unglaublich.
Kann da bitte mal jemand rein schauen?
Thx vorab TM
EDIT:
Das Ändern in grub hat dieses mal nichts genutzt. Das Auswahlmenü erscheint trotzdem nicht.
Pamac wurde inzwischen auf die Version 10.0.4-3.1 angehoben und diese 10er Version scheint gemäß meiner Tests endlich fehlerfrei zu funktionieren.
MichaelP
Kernel: 6.7.0
die Grafikfehler mit Kernel 5.11.1 konnten beseitigt werden >> BIOS Update.
Betroffenes System / Mainboard:
Gigabyte Aorus B550I AX Pro: Bios alt F12, neu F13c
Gruß Michael
Thatsme
CPU: verschiedene
GPU: verschiedene
Danke @Manfrago
Ich habe wieder das selbe Dilemma wie nach dem anderen größeren Update.
failed to start load kernel modules
failed to mount /boot/efi
depency failed for load local file system
Ich bekomme das auch mit Grub restore nicht hin. Ich habe zu allen 3 Meldungen alles gelesen, was ich im Netz finden konnte.
Wichtig wäre mir diesen Kernel 510 endgültig aus allen künftigen Updates zu verbannen. Der verhagelt mir jedes mal mein System. Es nervt. Leider hatte ich noch keine Zeit, mich für eine andere Distri zu entscheiden und zu installieren.
Die Tage von Manjaro sind leider gezählt. Seit 30.12.20 permanent Probleme mit den Updates. Trotz extra angeschafftem neuen Laptop :( :(
Ich werde es mal mit Timeshift versuchen. Ich habe ganz brav auf dich gehört Manfrago ;)
Hallo Thatsme
Schon die "ignore" funktion getestet ?
Es sollte aber vorher ein anderer Kernel installiert sein.
Ich habs selber aber noch nie für einen Kernel gebraucht.
Info:https://bbs.archlinux.org/viewtopic.php?id=257808
Thatsme
CPU: verschiedene
GPU: verschiedene
Hi djeli,
djeli hat geschrieben: Donnerstag 4. März 2021, 10:24 Hallo Thatsme
Js, aber wie gesagt, nur über pamac.
Wie das über die Konsole geht, weiß ich nicht.
Allerdings vermute ich, dass ich auch linux-latest auf ignore setzen muss?
Ich verstehe nicht, warum ausgerechnet der 10er Kernel ausgerechnet auf meinem neuen Laptop mit intel GPU immer alles verhagelt. M. W. soll der doch bald als LTS raus kommen?
Wenn ich dann wenigstens das System mit einem Grub restore wieder in Gang bringen könnte. Aber nicht mal das klappt.
Wobei ich nicht ausschließen möchte, dass es an dieser bescheuerten miesen UEFI-Firmware liegt.
