2020-01-26 - Kernels, Pamac 9.3, GameMode, Brave, AMDVLK (Stable Update)
Hatte keine Probleme.
2
100%
0
Keine Stimmen
0
Keine Stimmen
Insgesamt abgegebene Stimmen: 2
Kernel: 6.1
Hat sich bedankt: 28 Mal
Danksagung erhalten: 149 Mal
Hello community,
here is another Stable Update ...
Some feature-updates:
Kernels got updated to their latest point-releases, including linux55 with latest RC
Linux54 got some fixes backported for i915 driver
gamemode got updated to 1.5
Pamac 9.3 got finally released
brave got updated
some KDE fixes
AMDVLK is now at 2020.Q1.1
manjaro-browser-settings should now respect changes made by the user
The usual upstream fixes
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev, which we build on a regular basis against kde-git master packages. Also check out our current 18.1.5 ISOs and give us the needed feedback. You might also want to give our latest spin with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch updated their default compression to zstd. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
wget https://pkgbuild.com/~eschwartz/repo/x8 ... man-static
chmod +x pacman-static
sudo ./pacman-static -Syyu
Our current supported kernels
linux316 3.16.81
linux44 4.4.211
linux49 4.9.211
linux414 4.14.167
linux419 4.19.98
linux53 5.3.18 [EOL]
linux54 5.4.14
linux55 5.5-rc7
linux419-rt 4.19.94_rt39
linux54-rt 5.4.10_rt5
Quelle
Kernel: 6.1
Re: 2020-01-26 - Kernels, Pamac 9.3, GameMode, Brave, AMDVLK (Stable Update)
Ohne Probleme! :)
MichaelP
CPU: AMD Ryzen 9 5900X
GPU: NVIDIA GTX 3080 Ti
Kernel: 6.7.0
Desktop-Variante: KDE 5.27.10
GPU Treiber: NVIDIA 545.29.06
Hat sich bedankt: 17 Mal
Danksagung erhalten: 28 Mal
Beitrag von MichaelP »
ohne Probleme :)
ManjaroHans
CPU: Intel Core i5-8600
GPU: Intel Onboard
Kernel: 6.1.55-1-MANJARO (64-bit)
Desktop-Variante: KDE Plasma 5.27.8
Hat sich bedankt: 26 Mal
Danksagung erhalten: 6 Mal
Beitrag von ManjaroHans »
...hab auch nach langer Pause endlich mal wieder ein Update installiert - alles gut! :)
_______
Grüßle,
Hans
