2018-08-18 - Kernels, Xorg-Server, Mesa, Deepin, MATE, Python (Stable Update)
Themen Author - Moderator
- Kernel: 6.1
- Hat sich bedankt: 28 Mal
Hi community,
Welcome to another stable update. So what do we have with this one?
renewed most of our kernels, incl. the L1TF 8 fixes
we updated our Xorg-Server to 1.20.1
mesa got updated to 18.1.6
xf86-video-ati we used the latest git-snapshot to fix some graphical glitches
Nvidia 304xx driver is dropped now.
Virtualbox got updated to 5.2.18
we backported a fix for kscreenlocker reducing the 100% CPU usage
we reverted commit 6f130e8 in systemd, which improves network speed 1
we pushed our rebuilds for python 3.7 and perl 5.28.
LibreOffice is now at 6.0.6
we added the latest MATE packages
added some new Deepin packages
Stefano updated our Adapta Themes
we updated some of our Grub themes
we fixed an issue with gpodder
updated firefox and thunderbird
updated dbus
we updated firefox-dev and firefox-kde and jdk8 to their latest versions
flameshot got a fix for zh_TW locale loading
small fixes to pamac-cli
the usual python/haskell rebuilds/updates
We hope with all these changes Manjaro to be more efficient for you all.
Currently we are working on a new Manjaro-Hardware project, the Bladebook Fall 2018. It will be powered by Manjaro KDE v18.0 and the latest Intel Apollo Lake Quad-Core HD APU. Having a fanless metal material (cassis either silver or gold-rose) and eMMC as storage (additional M2-SSD possible), it will have a long battery life. Find out more on our hardware page.
If you are curious about the latest state of development for the upcoming Manjaro-Illyria 18.0 release, you now have the opportunity to download a beta-build
of Manjaro-Xfce 18.0 including the latest xfce-gtk3 packages aswell as our most recent styling efforts. Our KDE fans may try our beta-build with the latest KDE v5.13 instead. And our GNOME fans may try our beta-build with the latest GNOME v3.28.
Latest information about the intel-cpu-bug risk and our efforts can be found here.
Current supported Kernels
linux316 3.16.57
linux318 3.18.119 [EOL]
linux41 4.1.52 [EOL]
linux44 4.4.149
linux49 4.9.121
linux414 4.14.64
linux415 4.15.18 [EOL]
linux416 4.16.18 [EOL]
linux417 4.17.16
linux418 4.18.2
linux419 4.19-rc0
linux414-rt 4.14.52_rt34
linux416-rt 4.16.18_rt11
Quelle
updated dbus
linux316 3.16.57
linux44 4.4.149
linux49 4.9.121
linux414 4.14.64
linux417 4.17.16
linux418 4.18.2
linux419 4.19-rc0
Quelle
Kernel: 4.20
Kernel: 4.20
- Kernel: 6.1
Re: 2018-08-18 - Kernels, Xorg-Server, Mesa, Deepin, MATE, Python (Stable Update)
Alles bestens!
 Host: dirk-pc Kernel: 4.18.2-1-MANJARO x86_64 bits: 64
 Desktop: Xfce 4.12.4 Distro: Manjaro Linux
 Host: asus-pc Kernel: 4.14.64-1-MANJARO x86_64 bits: 64
 Desktop: LXQt 0.13.0 Distro: Manjaro Linux
Kernel: 4.20
Kernel: 4.20
- Kernel: 5.15 / 6.0
- GPU Treiber: Intel i915
- Hat sich bedankt: 15 Mal
- Danksagung erhalten: 36 Mal
Entschuldigung, verrutscht, Ergebnis für testing.Â
Â
Alles gelaufen, wie man oben sieht.
OS: Manjaro 17.1.12 Hakoila
Kernel: x86_64 Linux 4.18.3-1-MANJARO
DE: Xfce4
Zuletzt geändert von linuxkumpel am Samstag 18. August 2018, 21:49, insgesamt 1-mal geändert.
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft!
- Kernel: 510
- Hat sich bedankt: 43 Mal
- Danksagung erhalten: 11 Mal
Auf meienm Desktop hat fast alles geklappt - Autokey musste ich nach Upfate neu installieren. Thunderbird - da ist Manjaro nicht für zuständig - geht einher mit dem Verlust von Lightning, dem Adressbuch und dem SoGo-Connector und wird dadurch für mich fast unbrauchbar. Jetzt hoffe ich sehr, dass das bis Ende nächster Woche wieder funktioniert, denn dann ist mein Urlaubsmodus auch beendet. Letzteres ist auch der Grund, warum es keine Nachrichten vom Laptop gibt.
@m-bostaurus, schau mal hier. Hatte mir geholfen. Teil der Add-ons bleibtallerdings trotzdem vorerst unbenutzbar.
Zuletzt geändert von linuxkumpel am Sonntag 19. August 2018, 19:43, insgesamt 1-mal geändert.
- CPU: Intel Core i5-6200U
- Hat sich bedankt: 5 Mal
- Danksagung erhalten: 1 Mal
[quote="m-bostaurus"]Thunderbird - da ist Manjaro nicht für zuständig - geht einher mit dem Verlust von Lightning, dem Adressbuch und dem SoGo-Connector und wird dadurch für mich fast unbrauchbar.[/quote]
Lightning sollte standardmäßig mitgeliefert werden! Sollte das stimmen, dass Lightning fehlt, werde ich nicht updaten! Können das noch andere User bestätigen, dass kein Lightning mehr verfügbar ist?
Hier wird noch etwas beschrieben, wie man Lightning evtl. aktivieren kann: https://www.thunderbird-mail.de/forum/t ... lightning/
Den Verlust des Sogo-Connectors versuche ich mit cardbook zu umgehen. https://addons.thunderbird.net/de/thund ... /cardbook/
Es ist allerdings ein extra Adressbuch. Zusätzlich zu dem von Thunderbird als Addon. Wird allerdings sehr gelobt. Musste mal googlen. Ich probiere auch gerade damit herum (bevor ich update). Es könnte auch eine Lösung sein für das nicht mehr funktionierende Thunderbirthday Addon.
Weiterhin hab ich hier noch was gefunden, was evtl. den Sogo-Connector ersetzt: https://www.thunderbird-mail.de/forum/t ... hr-tbsync/
[quote="Peter"]
Auf das Update verzichten wäre ein Weg, allerdings nicht unbedingt empfehlenswert. Mit ein wenig basteln läuft alles wieder. Oben, wie auch in deinem Beitrag, wurden ja einige Möglichkeiten beschrieben.
Die Add-ons können auch wieder freigeschaltet werden (WebExtensions auch bei Thunderbird 60). Funktionieren allerdings trotzdem nicht alle. Testen.
Da steht drin:linuxkumpel hat geschrieben: Gegebenenfalls wäre hier auch eine Lösung.
https://support.mozilla.org/en-US/kb/ca ... hunderbird
If you are using Linux and installed Thunderbird and/or Lightning by using the package manager of your distribution, then these how-tos are not applicable - please contact the support of your Linux distribution to get help.
Und der Link von dir funktioniert nicht:
linuxkumpel hat geschrieben: @m-bostaurus, schau mal hier. Hatte mir geholfen. Teil der Add-ons bleibtallerdings trotzdem vorerst unbenutzbar.
Zuletzt geändert von Peter am Sonntag 19. August 2018, 18:30, insgesamt 1-mal geändert.
- Kernel: 510
Okay, Lightning ist wieder da, wenn ach auf Englisch. Dank an Linuxkumpel und Peter ... Jetzt erst mal ab in den Urlaub ... In acht Tagen wird weitergemacht ...
[quote="Peter"]
Hier nochmal https://releases.mozilla.org/pub/calendar/lightning/candidates/6.2b6-candidates/build1/linux-x86_64/ Der ...de.xpiÂ
Oben ebenfalls korrigiert.
Zuletzt geändert von linuxkumpel am Sonntag 19. August 2018, 19:44, insgesamt 1-mal geändert.
Okay, Lightning ist wieder da, wenn ach auf Englisch.[/quote]
Sag mal noch kurz, was du gemacht hast. Mir steht das nämlich noch bevor.
Heute ging bei mir so ein komisches grünes Ding auf das mir sagte neuer Kernel vorhanden. Nun gut dann habe ich mir den 419 RC installiert. Den LTS Kernel lasse ich aber noch drauf da ich nicht weiß ob es Probleme gibt. Ansonsten bin ich mit einigen Abstrichen ( Updates und Prepiad Internet) zufrieden.
Hallo DPITTI,
[quote="DPITTI"]
[quote="DPITTI"]
Naja, kannst Du machen, ist kein Fehler. Aber Du musst auch nicht jeden neuen Kernel installieren, der dir von komischen grünen Dingen angeboten wird, zumal wenn es sich noch um "Release Candidate" = rc handelt. Das heisst, der Kernel ist noch in der Entwicklung und nächste Woche kommt dann wahrscheinlich 4.19-rc1, in 12 Tagen 4.19-rc2 usw.
Will dich nicht bremsen, aber gerade wenn das Download-Volumen begrenzt ist und Du sowieso einen gut laufenden LTS-Kernel benutzt...
[quote="DPITTI"]
weise Entscheidung
[quote="DPITTI"]
[quote="DPITTI"]
[quote="DPITTI"]
weise Entscheidung
Also mein Rechner läuft gut mit dem 419 Kernel. Das mache ich sowieso nicht das jeder Kernel auf mein PC kommt. Eventuell gehe ich zurück auf den 418 Kernel. Ich weiß ja wie ich nicht benötigte Kernel deinstallieren kann. Auch gebräuchliche Befehle habe ich mir schon als Datei angefertigt. Sprich mein System hat nur die Deutschen Morris und nicht die Weltweiten. Hat auch schon was gebracht da ich nun auch Torcs installieren konnte. Weshalb ich Trigger-Rally nicht installieren kann ist mir immer noch ein Rätsel. Wird immer mit einen Build Fehler breche ab beendet. Diesen Befehl mit den Keys habe ich auch gemacht. Kann ja mal per Terminal versuchen ob ich das Spiel installiert bekomme. Im Moment habe ich eine Windows Version per Wine zu laufen.
Zuletzt geändert von DPITTI am Dienstag 21. August 2018, 13:28, insgesamt 1-mal geändert.
