QuelleHello i686ers!
This is a bit of a weird update set given the issues with resetting the repos. Essentially, with this set the three branches are now re-aligned correctly; all packages should be caught up, and all the correct library versions should be in place.
There’s an update to the archlinux32-keyring package. If you haven’t added that to the SyncFirst field in /etc/pacman.conf then you should update that package before updating the rest of the system, e.g.:
sudo pacman -Syy archlinux32-keyring
sudo pacman -Syu
Everything else should be a pretty standard update.
Anyone who would like to help out testing the upstream packages, please read the archlinux32 thread for details about how they automate their testing process and how to get involved:
https://bbs.archlinux32.org/viewtopic.php?id=171
(running this in an archlinux32 VM would be fine, there will hopefully be a way of doing this directly from within manjaro32 in the future)
Available kernels
Series Version
linux316 3.16.56
linux41 4.1.51
linux44 4.4.127
linux49 4.9.93
linux414 4.14.34
archlinux32
Why aren’t the available packages/package versions the same as x86_64?
archlinux32 packages are based on Arch packages but may need editing to build correctly. Builds of less-popular packages are lower priority.
Manjaro-specific packages may lag behind x86_64 because there aren’t as many packagers. If you notice an important package is lagging please report it; at the moment it’s only me packaging for i686:
Manjaro Development
What about security updates?
What about installer images?
Manjaro Development
@philm decided it was high time that manjaro32 had some installer images so has been busy spinning Xfce, GNOME and KDE images. At this point, only Xfce works well enough to be considered for release, but that’s fine - Xfce is the most appropriate DE for any older machine. To get some wider testing before making this "fully " available, the image can be downloaded from: https://sourceforge.net/projects/manjar ... -rc2/xfce/ Be aware, 17.1.1-rc2 is built against t…
2018-04-15 - Kernel 4.14, GNOME 3.28.1, catch-up [Stable Update x32]
Themen Author - Moderator
- Kernel: 6.1
- Hat sich bedankt: 28 Mal
- Danksagung erhalten: 149 Mal
Kernel: 4.20
Kernel: 4.20
- Kernel: 510
- Hat sich bedankt: 42 Mal
- Danksagung erhalten: 11 Mal
Re: 2018-04-15 - Kernel 4.14, GNOME 3.28.1, catch-up [Stable Update x32]
Alle meine Rechner sind auf dem aktuellen Stable-Stand mit dem 4.16er Kernel. Alles gut ohne irgendwelche Zicken. Habe gerade überlegt, wann ich das letzte Mal ernsthafte Schwierigkeiten nach einem Update hatte - es ist sehr lange her. Manjaro ist ein fantastisches Betriebssystem. So geht IT! Ein herzliches Dankeschön an das Team!
