QuelleHello i686ers!
This is a decent-sized update (~400MB average) which includes the usual kernel updates, along with updates to OpenSSH and OpenSSL. Also just squeaking into this set is OpenJDK 10.
There’s also a change to the default top configuration. Feedback welcome.
Of particular note is the ICU update. This required many (many) packages to be rebuilt. As far as testing has shown there are no packages remaining but it’s not likely that every single package has been tested; please report any with issues as you find them.
Anyone who would like to help out testing the upstream packages, please read the archlinux32 thread for details about how they automate their testing process and how to get involved:
https://bbs.archlinux32.org/viewtopic.php?id=171
(running this in an archlinux32 VM would be fine, there will hopefully be a way of doing this directly from within manjaro32 in the future)
Available kernels
Series Version
linux316 3.16.56
linux41 4.1.51
linux44 4.4.126
linux49 4.9.92
linux414 4.14.32
archlinux32
Why aren’t the available packages/package versions the same as x86_64?
archlinux32 packages are based on Arch packages but may need editing to build correctly. Builds of less-popular packages are lower priority.
Manjaro-specific packages may lag behind x86_64 because there aren’t as many packagers. If you notice an important package is lagging please report it; at the moment it’s only me packaging for i686:
Manjaro Development
What about security updates?
What about installer images?
Manjaro Development
@philm decided it was high time that manjaro32 had some installer images so has been busy spinning Xfce, GNOME and KDE images. At this point, only Xfce works well enough to be considered for release, but that’s fine - Xfce is the most appropriate DE for any older machine. To get some wider testing before making this "fully " available, the image can be downloaded from: https://sourceforge.net/projects/manjar ... -rc2/xfce/ Be aware, 17.1.1-rc2 is built against t…
2018-04-08 - Kernels, ICU and rebuilds, OpenSSH, OpenSSL [Stable Update x32]
Themen Author - Moderator
- Kernel: 6.1
- Hat sich bedankt: 28 Mal
Kernel: 4.20
Kernel: 4.20
