QuelleHello i686ers!
This is a very large update set which updates kernels 3.16, 4.4, 4.9, and 4.14 (with extramodules), KDE, LibreOffice, Haskell packages, Python modules, MATE, Palemoon, … it’s pretty massive.
This set is based on a custom “combined source” repo that combines packages from the archlinux32 stable and testing repos. This means we get packages more quickly, and can help with testing packages as they move through our branches. I’m hoping there will be no issues once they hit x32-stable but only time will tell.
Anyone who would like to help out testing the upstream packages, please read the archlinux32 thread for details about how they automate their testing process and how to get involved:
https://bbs.archlinux32.org/viewtopic.php?id=171
(running this in an archlinux32 VM would be fine)
Available kernels
Series Version
linux316 3.16.55
linux41 4.1.49
linux44 4.4.120
linux49 4.9.86
linux414 4.14.24
archlinux32
Why aren’t the available packages/package versions the same as x86_64?
archlinux32 packages are based on Arch packages but may need editing to build correctly. Builds of less-popular packages are lower priority.
Manjaro-specific packages may lag behind x86_64 because there aren’t as many packagers. If you notice an important package is lagging please report it; at the moment it’s only me packaging for i686:
Manjaro Development
What about security updates?
What about installer images?
Manjaro Development
2018-03-06 - Kernels, KDE, LibreOffice, Haskell, Python MATE [Stable Update x32]
Themen Author - Moderator
- Kernel: 6.1
- Hat sich bedankt: 28 Mal
- Danksagung erhalten: 149 Mal
Kernel: 4.20
Kernel: 4.20
