QuelleHello i686ers!
This is a much smaller set than the last one and updates kernels 3.16, 4.4, 4.9, and 4.14 and the Intel microcode. There’s also an update to LightDM which should enable autologin1.
Main changes
Updated kernels, extramodules rebuilt as necessary
Updated Intel microcode package
Available kernels
Series Version
linux316 3.16.53
linux41 4.1.48
linux44 4.4.111
linux49 4.9.76
linux414 4.14.13
archlinux32
How do I get it?
These steps should no longer be necessary
If you’re already running a 32-bit installation, and haven’t already migrated, you should shortly get a manjaro-system update which will transition you to the new setup (it should automate the following steps).
Otherwise, edit your /etc/pacman-mirrors.conf and change (or set):
Branch = x32-stable
making sure there is no comment marker (#) at the start of the line. Then, update your mirror list, install the keyring package, and update:
pacman-mirrors -c all
pacman -Sy archlinux32-keyring-transition
pacman -S archlinux32-keyring
pacman -Syu
archlinux32-keyring-transition is signed by the Arch devs and allows you to install archlinux32-keyring which contains the keys that sign all archlinux32 packages.
archlinux32-keyring replaces archlinux32-keyring-transition.
What about package updates?
Manjaro-specific packages may lag behind x86_64 because there aren’t as many packagers. I may also trim the supported package list to save effort, depending on frequency of updates to packages and packagers who volunteer to help out. If you notice an important package is lagging please report it; at the moment it’s only me packaging for i686:
Manjaro Development
What about security updates?
What about installer images?
Manjaro Development
2018-01-13 - Kernels, Intel microcode [Stable Update x32]
Themen Author - Moderator
- Kernel: 6.1
- Hat sich bedankt: 28 Mal
- Danksagung erhalten: 149 Mal
Kernel: 4.20
Kernel: 4.20
