2018-01-09 - Kernels, many (many) upstream packages updated [Stable Update x32]
Kernel: 6.1
Hat sich bedankt: 28 Mal
Danksagung erhalten: 151 Mal
Hello i686ers!
This set of updates bumps kernels 4.4, 4.9 and 4.14 to include the current KPTI fixes. More is sure to come with the next kernel updates.
However, the main thing of note is the number of upstream changes with a huge number of core packages updated, and another load of packages rebuilt due to MESA, Xorg, Python, Ruby, Qt5 and Haskell updates.
This is a large set of updates.
Main changes
Updated kernels, extramodules rebuilt as necessary
Firefox and Thunderbird updates
Many, many upstream changes, including:
systemd
xorg-server
mesa
KDE
LibreOffice
Available kernels
Series Version
linux316 3.16.52
linux41 4.1.48
linux44 4.4.110
linux49 4.9.75
linux414 4.14.12
archlinux32
If you find manjaro32 useful please consider donating to, or helping out with, archlinux32
. It’s a small team taking on a huge project and any help will no doubt be very much appreciated.
How do I get it?
These steps should no longer be necessary
If you’re already running a 32-bit installation, and haven’t already migrated, you should shortly get a manjaro-system update which will transition you to the new setup (it should automate the following steps).
Otherwise, edit your /etc/pacman-mirrors.conf and change (or set):
Branch = x32-stable
making sure there is no comment marker (#) at the start of the line. Then, update your mirror list, install the keyring package, and update:
pacman-mirrors -c all
pacman -Sy archlinux32-keyring-transition
pacman -S archlinux32-keyring
pacman -Syu
archlinux32-keyring-transition is signed by the Arch devs and allows you to install archlinux32-keyring which contains the keys that sign all archlinux32 packages.
archlinux32-keyring replaces archlinux32-keyring-transition.
What about package updates?
Manjaro-specific packages may lag behind x86_64 because there aren’t as many packagers. I may also trim the supported package list to save effort, depending on frequency of updates to packages and packagers who volunteer to help out. If you notice an important package is lagging please report it; at the moment it’s only me packaging for i686:
Manjaro Development
What about security updates?
What about installer images?
Manjaro Development
This stable update set will form the basis for the 17.1.1 release once I work out how to do it. :slight_smile:
Quelle
Kernel: 4.20
