Hello i686ers!
This set of updates bumps kernels 3.16, 4.4, 4.9 and 4.14 (with the 4-series kernels including the KPTI patch). There’s a fix to the Xfce desktop settings that allows for correct setting of the session, and a TLP patch that should fix desktops being detected as laptops2.
I also need to say I’m very happy that Manjaro users are finding and reporting issues in upstream projects.
Please note that there is an update to archlinux32-keyring: you may need to install that first (or add it to SyncFirst in /etc/pacman.conf).
Main changes
Updated kernels
All extramodules rebuilt
New archlinux32-keyring package
TLP patch to fix desktops being detected as laptops
Fix to .xinitrc for Xfce users
Available kernels
Series Version
linux316 3.16.52
linux41 4.1.48
linux44 4.4.109
linux49 4.9.74
linux414 4.14.11
archlinux32
How do I get it?
These steps should no longer be necessary
If you’re already running a 32-bit installation, and haven’t already migrated, you should shortly get a manjaro-system update which will transition you to the new setup (it should automate the following steps).
Otherwise, edit your /etc/pacman-mirrors.conf and change (or set):
Branch = x32-stable
making sure there is no comment marker (#) at the start of the line. Then, update your mirror list, install the keyring package, and update:
pacman-mirrors -c all
pacman -Sy archlinux32-keyring-transition
pacman -S archlinux32-keyring
pacman -Syu
archlinux32-keyring-transition is signed by the Arch devs and allows you to install archlinux32-keyring which contains the keys that sign all archlinux32 packages.
archlinux32-keyring replaces archlinux32-keyring-transition.
What about package updates?
Manjaro-specific packages may lag behind x86_64 because there aren’t as many packagers. I may also trim the supported package list to save effort, depending on frequency of updates to packages and packagers who volunteer to help out. If you notice an important package is lagging please report it; at the moment it’s only me packaging for i686:
Manjaro Development
What about security updates?
What about installer images?
I’ll be looking into creating an Xfce installer. but have no plans to offer a full set of editions. I hope once manjaro32 is completely off-the-ground and proven the current maintainers might spin a 32-bit iso of their editions, but as this represents doubling the amount of work to prepare an edition the demand would have to be quite high to justify it.
After this point, x32-unstable should be regarded as untested and may break at any time, so should definitely be used by people who like finding and fixing problems.
Quelle
2018-01-06 - Kernels, keyring, TLP, Desktop settings [Stable Update x32]
Themen Author - Moderator
- Kernel: 6.1
- Hat sich bedankt: 28 Mal
Kernel: 4.20
Kernel: 4.20
