2017-12-16 - Kernels, Mesa, Deepin, Firefox, Python, Haskell (Stable Update)
<t>Hattet ihr Probleme mit dem Update?</t>
Hatte keine Probleme.
2
100%
0
Keine Stimmen
0
Keine Stimmen
Insgesamt abgegebene Stimmen: 2
Kernel: 6.1
Hat sich bedankt: 28 Mal
Danksagung erhalten: 151 Mal
Hi community,
Normally you calm down a little in December, however it is a little busy for us getting Manjaro v17.1 ready before ending this year. So with this update you get new install medias to try out. Also we worked on improving our graphical installer and started to ship the architect installer also with our medias.
For friends of Office we also used our own Jade-Application-Kit to provide MS Office Online as native linux apps (you need still internet to get it working).
So what else changed so far? We had updated some of our themes, pushed out some new deepin packages, had the usual haskell and python updates, most kernels got renewed, firefox got some security updates and mesa got updated to v17.3.
So please report back and give us feedback for given changes made to our repositories. Users of our 32-bit Distro should read this
Distro Releases
XFCE v17.1-rc1
Current supported Kernels
linux316 3.16.51
linux318 3.18.87 [EOL]
linux41 4.1.47
linux44 4.4.105
linux49 4.9.68
linux412 4.12.14 [EOL]
linux413 4.13.16 [EOL]
linux414 4.14.5
linux415 4.15-rc3
linux-RT-LTS 4.9.65_rt56
linux-RT 4.11.12_rt16
Package Updates (Wed Dec 13 13:39:07 CET 2017)
stable community x86_64: 1070 new and 1009 removed package(s)
stable core x86_64: 44 new and 40 removed package(s)
stable extra x86_64: 409 new and 407 removed package(s)
stable multilib x86_64: 13 new and 22 removed package(s)
A list of packages can be found here.
Quelle
Zuletzt geändert von Blueriver am Samstag 16. Dezember 2017, 21:50, insgesamt 1-mal geändert.
Kernel: 4.20
Hat sich bedankt: 189 Mal
Danksagung erhalten: 144 Mal
Re: 2017-12-16 - Kernels, Mesa, Deepin, Firefox, Python, Haskell (Stable Update)
Leider geht nach dem Update der VLC Player bei mir nicht mehr?! Startet kurz und beendet dann nach wenigen Sekunden von selbst. Jemand selbiges Problem inklusive Lösung?  >:(
o0sandfish0o
Beitrag von o0sandfish0o »
bei mir wollen die Netzwerkverbindugen nicht mit Kernel: Linux version 4.15.0-1-MANJARO und 4.14  >:D
Quinix
Beitrag von Quinix »
schaut doch mal bitte nach bei dem beigefügtem link "Quelle"...  dort sind die lösungen unlängst parat. ist zwar in englisch, aber das sollte doch wirklich kein so großes problem sein.  ;-)
dort ist zB bekannt daß man das netzwerk problem, welches mit den neuen aktuellen kernel einhergeht, eventuell lösen kann wenn man einen älteren kernel benutzt. wie zB den 4.13 oder 4.9.
AFAIK die erste lösung. oder aber, wie dort auf der anderen seite beschrieben, ein downgrade diverse pakete.
VLC funktioniert wieder, nach diesem Update:
sudo pacman -U https://mirror.netzspielplatz.de/manjaro/packages/unstable/community/x86_64/vlc-nightly-3.0.0v20171216-1-x86_64.pkg.tar.xz
Im Terminal ein geben......
Kernel: 6.1
Bei mir ist alles gut.
System:    Host: dirk-pc Kernel: 4.14.5-1-MANJARO x86_64 bits: 64
           Desktop: Xfce 4.12.4 Distro: Manjaro Linux
           Network:   Card: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8168
Kernel: 4.20
